After a fresh install of WinXP MCE I installed gameex again and cofigured the easy config as before but when launching gameex it stops and give me this log.
20:54:36.5 28-7-2005: GameEx: Version 4.69: Starting Log
20:54:36.5 28-7-2005: Operating System Platform: Win32NT
20:54:36.5 28-7-2005: Operating System Name: Windows XP
20:54:36.5 28-7-2005: Operating System Version: 5.1.2600
20:54:36.5 28-7-2005: Running Randomize()
20:54:36.5 28-7-2005: Running Misc startup tasks
20:54:36.5 28-7-2005: Hiding Cursor
20:54:36.5 28-7-2005: Setting Menu types
20:54:36.5 28-7-2005: Opening Configuration File
20:54:36.5 28-7-2005: Getting Configuration Values
20:54:36.5 28-7-2005: Using Theme: Default - GameEx - Animated
20:54:36.5 28-7-2005: Checking for alternate Image Directory for Theme: Default - GameEx - Animated
20:54:36.5 28-7-2005: Using Images from theme: Default - GameEx\MEDIA\
20:54:36.5 28-7-2005: Text/Language: English
20:54:36.5 28-7-2005: Applying Language/Text
20:54:36.6 28-7-2005: Creating Scancodes.txt (List of DirectInput scan codes)
20:54:36.6 28-7-2005: Snap Delay set to: 1
20:54:36.6 28-7-2005: Is Media Center running?
20:54:36.6 28-7-2005: Media Center is running
20:54:36.6 28-7-2005: Check Media Center Exit/Start Mode
20:54:36.6 28-7-2005: Media Center Mode 2
20:54:36.7 28-7-2005: Closing Media Center
20:54:41.7 28-7-2005: Checking for applications to Launch On Startup
20:54:41.7 28-7-2005: Get other settings
20:54:41.7 28-7-2005: Launching HideOS.exe
20:54:42.0 28-7-2005: Hiding Taskbar
20:54:42.0 28-7-2005: Start work for Form
20:54:42.0 28-7-2005: Getting Original Screen Size
20:54:42.0 28-7-2005: Loading ICON
20:54:42.0 28-7-2005: Initializing Component
20:54:42.1 28-7-2005: Initialising Bass Audio Library
20:54:44.8 28-7-2005: ERRORS DETECTED: EXITING
I have uninstalled and installed again but it won't start.
Also when launching the gamex configuaration (not the easy one) its all blanc.
All (windows) updates and driver updates are installed so who will give me the answer.
Which version of the .net framework are you running?
I'm sorry, I dont have any ideas at the moment.
Which version of MCE are you using?
Have you checked you sound card?
I'm using MCE 2005.
My soundcard is onboard, a realtek card with the latest drivers from the realtek site (A 3.74)
Like I said after a fresh instaal it won't work. It worked before with the same hardware and software. Uninstalling and installing again won't solve it. The only thing that is changed since the last time is a bios update for my A8V deluxe board (1014.008 final)
Is it doing any checking of the Windows Media Library around that time? Maybe you could try disabling your sound card in device manager, just to see if that allows you through? (Might help narrow down the problem)
-- Rob
-- Rob
Soundcard disabled but still the same log.
I don't get it. It used to work fine with all the same hard and software.
Im having a similar problem as well in MCE with the new version. I have everything up to date. I tried to reinstall as well. Didnt work.
17:52:09.5 7/29/2005: GameEx: Version 4.69: Starting Log
17:52:09.5 7/29/2005: Operating System Platform: Win32NT
17:52:09.5 7/29/2005: Operating System Name: Windows XP
17:52:09.5 7/29/2005: Operating System Version: 5.1.2600
17:52:09.5 7/29/2005: Running Randomize()
17:52:09.6 7/29/2005: Running Misc startup tasks
17:52:09.6 7/29/2005: Hiding Cursor
17:52:09.6 7/29/2005: Setting Menu types
17:52:09.6 7/29/2005: Opening Configuration File
17:52:09.6 7/29/2005: Getting Configuration Values
17:52:09.6 7/29/2005: Using Theme: Default - BlueEx - MCE1024x768
17:52:09.6 7/29/2005: Checking for alternate Image Directory for Theme: Default - BlueEx - MCE1024x768
17:52:09.6 7/29/2005: Text/Language: English
17:52:09.7 7/29/2005: Applying Language/Text
17:52:09.8 7/29/2005: Creating Scancodes.txt (List of DirectInput scan codes)
17:52:09.8 7/29/2005: Snap Delay set to: 4
17:52:09.8 7/29/2005: Is Media Center running?
17:52:09.8 7/29/2005: Check Media Center Exit/Start Mode
17:52:09.8 7/29/2005: Media Center Mode 0
17:52:09.8 7/29/2005: Checking for applications to Launch On Startup
17:52:09.8 7/29/2005: Get other settings
17:52:09.9 7/29/2005: Launching HideOS.exe
17:52:11.6 7/29/2005: Hiding Taskbar
17:52:11.8 7/29/2005: Start work for Form
17:52:11.8 7/29/2005: Getting Original Screen Size
17:52:11.8 7/29/2005: Loading ICON
17:52:11.8 7/29/2005: Initializing Component
17:52:11.9 7/29/2005: Initialising Bass Audio Library
17:52:12.7 7/29/2005: Using General Font: Trebuchet MS
17:52:12.8 7/29/2005: Using Title Font: Joystix
17:52:12.8 7/29/2005: Initialising DirectDraw
17:52:12.8 7/29/2005: Applying GameEx is Loading Image
17:52:13.1 7/29/2005: Creating DirectDraw Device
17:52:13.1 7/29/2005: Using Device: RADEON 7000 SERIES
17:52:13.2 7/29/2005: Setting Resolution to 800x600 32 bit color
17:52:13.2 7/29/2005: Creating DirectDraw Surfaces
17:52:13.2 7/29/2005: Creating Primary Surface - Full Screen Mode
17:52:13.3 7/29/2005: Creating Back Buffer
17:52:13.3 7/29/2005: Loading graphic surfaces
17:52:13.4 7/29/2005: Creating Surfaces Misc and Dialogs
17:52:16.3 7/29/2005: ERRORS DETECTED: EXITING
Can you try the default theme.
I'm using MCE 2005.
I think basically you have a bad Windows XP or .net framework install for some reason. Coul you try the version just uploaded, I am thinking it will be failing on the item after initializing bass. If so it has to be something up with your install. I dont think its to do with your hardware. I think someohow you got a bad install of Win XP or .net framework.
Let me know.
Let me know.
I uninstalled net.framework 1.1 and yes gameex did work.
I reinstalled net. framework and it didn't work anymore so its the framework trouble.
Do I really need the net framework for other things?
this is the log with framework 1.1 and the latest release of gameex.
23:14:41.3 31-7-2005: GameEx: Version 4.71: Starting Log
23:14:41.3 31-7-2005: Operating System Platform: Win32NT
23:14:41.3 31-7-2005: Operating System Name: Windows XP
23:14:41.3 31-7-2005: Operating System Version: 5.1.2600
23:14:41.3 31-7-2005: Running Randomize()
23:14:41.4 31-7-2005: Running Misc startup tasks
23:14:41.4 31-7-2005: Hiding Cursor
23:14:41.4 31-7-2005: Setting Menu types
23:14:41.4 31-7-2005: Opening Configuration File
23:14:41.4 31-7-2005: Getting Configuration Values
23:14:41.4 31-7-2005: Using Theme: Default - Default
23:14:41.4 31-7-2005: Checking for alternate Image Directory for Theme: Default - Default
23:14:41.4 31-7-2005: Text/Language: English
23:14:41.4 31-7-2005: Applying Language/Text
23:14:41.5 31-7-2005: Creating Scancodes.txt (List of DirectInput scan codes)
23:14:41.5 31-7-2005: Snap Delay set to: 1
23:14:41.5 31-7-2005: Is Media Center running?
23:14:41.5 31-7-2005: Media Center is running
23:14:41.5 31-7-2005: Check Media Center Exit/Start Mode
23:14:41.6 31-7-2005: Media Center Mode 2
23:14:41.6 31-7-2005: Closing Media Center
23:14:46.6 31-7-2005: Checking for applications to Launch On Startup
23:14:46.6 31-7-2005: Get other settings
23:14:46.6 31-7-2005: Launching HideOS.exe
23:14:49.3 31-7-2005: Hiding Taskbar
23:14:49.3 31-7-2005: Start work for Form
23:14:49.3 31-7-2005: Getting Original Screen Size
23:14:49.3 31-7-2005: Loading ICON
23:14:49.4 31-7-2005: Initializing Component
23:14:49.4 31-7-2005: Initialising Bass Audio Library
23:14:49.6 31-7-2005: Loading default loading screen
23:14:52.3 31-7-2005: ERRORS DETECTED: EXITING
GameEx wont run without the Framework installed. As I said I think you have a bad Windows/Framework install.
It works now!
I did some repairs for gameex.exe and configuration.exe in the net framework configuration 1.1 and all problems are gone.
strange problem but ok it works so I'm happy now. :D
It works now!
Great.
Thanks for posting back Heula. I'll note this for future problems.
Thanks,
Tom
