I got Future Pinball loaded in Gameex, working fine. Problem is I don't have any screenshots or snaps for the games.
Anywhere I can download them?
Thansk!
You can create them :)
then share them...
Unfortunatly the sites I can think of to D/L also provide roms....
So no go im afraid.
Just to throw this out there.. HK wrote a program to extract all of this automaticaly for you. It extracts the tables, scripts, music, pictures, SCREENSHOTS, everything needed! They extract into individual folders. Just point GameEx to the newly created "snap" folder after the program exits, and you're done! One thing I should mention though, this program only works on a specific set of tables. Without giving away any names or website addresses, I'll tell you this much; it's on a very popular gaming bit torrent site, and their "official name" hs the initials PD. If you know what I'm talking about, great. If not, try google or something, cause we can't give out that information.
Here's the link to the program: http://www.gameex.info/forums/index.php?ac...ost&id=2372
Pretty cryptic there Han.....
Ill take it one step further.....
The program is called Pleasure extractor...
HMMM......
Why not just do it in Morse Code? ;)
Heh heh!!
  • 5 months later...
Does this even work? Do I need some other utility? I'm slamming the OK down trying to get it to do something with my Future Pinball files and it is doing absolutely nothing.
The program only works with a particular set. Hence all the cryptic nonsense in this thread. It's against the rules to link to where you can get this from, so unless you figure it out your out of luck I'm afraid.
First time I've seen this thread....It was before I started hanging out here.
Pretty funny stuff...If I had been around, I would have added that I don't use the abbreviation, I call it "petey" ;)
If HK's tool doesn't work with your set, you can grab the .jpg files by doing a search on the top level of your FuturePinball tables folder, and searching for "screenshot.jpg".. as long as you've not disabled it, XP/Vista will search in .zip files by default. You can just select/copy the list of matching files, and copy them to a folder. You'll probably need to do some renaming though, although I think GameEx can do some "best match" type guesses for the screenshots.
(PD stands for PORN DEPOT btw)
