:( Hello,
I just upraded from 3.7 to 4.68 and now I have a weird problem: the OK button on my remote control and the enter button on my keyboard don't work in GameEx 4.68. For instance, if I want to go into the programm menu nothing happens. however, when I click the left mouse button it does! So with my mouse everything is as it should be, but not with the remote control or the keyboard.
when I try it in GameEx 3.7 (which I still have installed) the remote control and the keyboard are working properly.
I tried the setting of the DirectInput as True and as False but that makes no difference.
What is going on?
Greetings,
poldermamer
:D Problem solved, but not sure how. I ran the config through and changed this setting:
EnableCustomInput=False (it was true at first). Then I started Gamex and now the OK button on the remote works.
NICE!
