could someone pls post their config for n64 emu, as i am not getting any roms to show up let alone launch
(i am using Project64 1.6)
cheers
Capp
Here you go. :D
[Emulator_1]
StartPageName=Nintendo 64 Games
TitleText=N64
StartPageLogo=n64
RomFilter=*.zip
RomsInFolders=False
ROMPath=C:\Program Files\Emulators\Nintendo 64\roms\USA
SnapPath=C:\Program Files\Emulators\Nintendo 64\Artwork\Snap Scans (Nintendo 64)
WorkingPath=C:\Program Files\Emulators\Nintendo 64
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=False
AlsoLaunch=
ShowDesktop=False
Debug=False
MapFile=n64
OLDatZip=
Command=Project64.exe [ROMPath]\[RomFile]
TitlePath=C:\Program Files\Emulators\Nintendo 64\Artwork\Title Scans (Nintendo 64)
BoxPath=C:\Program Files\Emulators\Nintendo 64\Artwork\Box Scans (Nintendo 64)
LaunchBefore=
LaunchAfter=
CartPath=C:\Program Files\Emulators\Nintendo 64\Artwork\Cart Scans (Nintendo 64)
thanx for the quick reply
i have set it up exact like yours, but the thing is that it just launches project 64 and not the rom
are your ROMs showing up in the GameEX menu?
do you have the paths right? are your roms in folders (if so, take them out)
the only thing you need to do in project64 options is make it start fullscreen (and config the plugins to your liking).
do i need to unzip the roms? as they arent showing up now in Game Ex
just another question on the map file? what is that, and where is it located?
[Emulator_1]
TitleText=N64
StartPageLogo=n64
RomFilter=*.zip
RomsInFolders=False
ROMPath=C:\Nintendo 64 ROM Set
SnapPath=C:\Project64 1.6\Screenshots
WorkingPath=C:\Project64 1.6
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=n64
OLDatZip=C:\Program Files\OfflineList0.7\datas\n64_OL.zip
TitlePath=
BoxPath=C:\Project64 1.6\Screenshots
LaunchBefore=
LaunchAfter=
CartPath=
ok got the roms showing in game ex
had to change the rom filter to *.7z
upon launching them in game ex it goes to desktop and says "File loaded does not appear to be a valid Nintendo64 ROM
verify your ROMS with GoodN64
I know that Cruisn USA works as i have played it when i unzipped the .7z file
do i have to unzip all the roms, or change them to zip files?
I don't think project64 supports 7z files, only zip files. It sounds like you have a full GoodMerge set for n64. There's usually multiple roms in one 7z (ie, the US version and the Japanese version) to save space. You should extract the n64 games you want to want to play, and change the GameEx rom filter to .z64
I don't think project64 supports 7z files.......You should extract the n64 games you want to want to play, and change the GameEx rom filter to .z64......
right!
un .7z then just .zip then .zip work also in project 64 under file there is chose rom DIR and make sure it point to your roms
starting from the command line, the rom browser isn't even loaded (until/unless you end emulation). so rom browser settings don't matter. (this is how pj boots games pretty fast using command line...).
but yep the only compression supported currently is plain old .zip, from zlib.dll
Also Capp you can set ShowDesktop=False, pj is a dx app and it looks neater this way (wfm anyway).
thanx guys for all your help
got it up and running , unzipped them all, got rid of the multiple files and runs sweet
:D:D:D
