Heres our regular Night`s first theme. I say first as I hope to see more :) .
This theme also contains a lot of good logos, night kindly did, that you can use with other themes if you wanted to.
Night is also working on some backgrounds for various emulators. I hope to work with him soon and add support for GameEx to have different backgrounds for different emulators. Its actually me that's holding thing up on this. Keep on the forums for more news.
http://uploads.tomspeirs.com/files/Default...20Theme%201.zip
Install to your themes directory. Normally
C:\program files\gameex\themes
Thanks Night!
Tom.
thx Tom :)
i hope you all like my first attempt and please feel free to PM/reply to me about changes/suggestions or what you like/dont like my goal are to make it as good as possible
i will add more previews later as i get more done but there are still ALOT so that will take some time to complete :P
How about a snap of it thanks ???
Sure here it is :
but to be honest to biggest thing are all the logoes or each emulator what i think are worth it even if you dont like the theme itself you can always use the logoes for another theme :)
How do i load a different theme thanks ??
run GameExConfig.exe and look under "display settings"
the first one there called Theme there you can change your themes just remember to copy all your new themes in the "themes" folder ..
OR
find the line in the "GameEx.ini" saying :
# Current Theme
Theme=Default - Default
and change it...
