20h July 2005
- GameEx 4.65
  • Fixed Desktop focus issue
    when exiting GameEx full screen
  • Fixed issue where MapKeys was
    always turned on
19h July 2005
- GameEx 4.64
  • Ability to set custom input
    for Keyboard and/or Gamepad instead of both at
    once.
  • Now also exits if green
    button pressed in video/dvd//create
    snap/picture/slideshow.
  • Fixed and updated vpauto.exe.
  • Configuration application
    should now list and select correct game devices.
hey tom, just wanted to say thanks for putting in the customizable controls. it brings a whole new life to my arcade machine, and now the interface is intuitive for people who just walk up and want to start playing (instead of me having to tell them what buttons do what). you rule!
Your welome sloan, long overdue wasnt it :) I appreciate the feedback.
seems fine so far, haven't tried the custom input for Keyb/pad yet though.
thanks again Tom.
edit: saw a problem once where after tabbing back into GameEx gamepad navigation didn't work - had to restart GamEx. not sure where the fault is there?
