hi there,
all is cool and very nice, however i have a problem with some kind of built in
screen saver or something.
when i play jukebox, music plays great, but then the screen goes black, totally
like a blank screen saver.
i have no screen saver settings in gameex, and it is disabled in windows.
also after 5 mins of moving mouse, i did manage to see a black box with
the windows title -quick
whats -quick??????????????????????
thanks
hi there,
thanks
Could it be some kind of malware? Do you have Attract mode timer set to 0 in GameEx. This disables the GameEx screensaver. Could it be powersave?
no malware
power saving is set at 40 mins then turn monitor off
as for: Attract mode timer set to 0 in GameEx
were is that setting exactly?
cheers tom
no malware
cheers tom
Advanced MAME
thanks tom,
but nope that aint it. i think it is trying to go on the internet
to get covers or something daft.
well i have firewall's 2 of and they aint going to let it onto the internet
and have an open port to the outside world.
is there anyway to disable this?????
im sure i can manage to get my own album covers, if i knew were they are
to be saved to.
does this sound like a firewall thing, as it is allways with the jukebox only
section.?
thanks again
thanks tom,
to be saved to.
section.?
thanks again
hmm, could be.I want not sure previously it was a Jukebox only issue. You can disable it, I cant remember off hand where the setting is but its in the config app. I suspect under Audio settings
yayyyyyyyyyyyy
cool tom, found that setting and set it to not download
problem is solved.
bug it is allso a bug you now know about.
bums out on firewall. if denied access.
so where do i save the cover art, what format, does it do front n back?
keep up the good work. i will send a little donation with paypal
i dont have alot but i would like to show my gratitude for the program and its support.
:D
