Hi, sorry for bumping an old topic I finally was able to get Nulldc working in GE but now each time I try to load a game I hear a Windows error sound and exit out of GE and there is a little window saying "configure cdrom" or something like that. So I load up Nulldc and set the drive again and it does the same thing,. Any ideas? thanks!
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
http://www.gameex.info/forums/index.php?s=...ost&p=30527
This thread will show you how to use with Deamon tools and without.
Have fun
Thanks! I got Nulldc working in GameEx thanks to your guide. everytime I load a DC game in GameEx it goes to DC audio cd menu but when I try to load anoy other games after that it'll give me a configure first error any ideas? :(
Well I haven't a clue off the bat...but lets get some data.
1. What build of nullDC are you using?
2. Did you make sure you have the latest DX9 build installed?
3. Did you use the nullDC installer or did you use a zip archive?
4. What do the contents of your nullDC.cfg look like?
5. What OS & Service Pack are you running?
6. Are you using CDI rips or GDI + CUE or other?
7. Are you using Brians CLI or a Loader?...if a Loader whos?
8. Are you using a Virtual Drive? & if so whats the make and build? with what options?
Heh more info goes a long ways. :)
Well from the symptoms Id say he's trying to use the deamon tools methond... I really don't recommend that one.
Heres the deal. Your running a cmd to mount a game dump in deamontools. The emu is loading faster. Hence its bringing you to the dreamcasts dashboard.
In a few the cd loads and you can go into game. Upon loading another game is isnt unmounting the original and giving you an error.
I'd check deamon tools settings to be sure to not show warnings and stuff. (cant remember exact options.)
Personally I'd recommend this configuration and skip the whole dtools thing.
In the above thread montioned a few lines that need to be enabled on the nulldc cfg. Like autostart emulation, fullscreen, and another.
Check to be sure you did that step. Then make your emu config look like mine. Its works perfectly.
There are really quite a few wrappers floating around here and alot of confusion. This should get things going for you
[Emulator_18]
STARTPAGENAME=Sega Dreamcast
TITLETEXT=Dreamcast
StartPageLogo=
ROMFilter=*.cdi
RomPath=C:\Emulation\Games\Dreamcast
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
WorkingPath=C:\Emulation\Console\Dreamcast\nulldc_100b1_6
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=nulldc_100b1_6.exe -config ImageReader:DefaultImage="[rompath]/[romfile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=nes
ExcludedFiles=
CustomBackground=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=[Console] Sega Dreamcast
GamesIn7Zips=
PlayInScreenSaver=True
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
I think I was using the Dtools method I tried your settings and got the same result :( I'm running Windows XP Professional SP2 1gb ram Core2Duo @3ghz x1950 Radeon I'm using nullDC_100b1_6 Here is my .cfg
;; nullDC config file;;
[imagereader]
defaultimage=defualt.cdi
PatchRegion=0
LoadDefaultImage=1
[nullDC]
Dynarec.Enabled=1
Dynarec.DoConstantPropagation=1
Dynarec.UnderclockFpu=0
Dreamcast.Cable=0
Dreamcast.RTC=1543277099
Emulator.AutoStart=1
[nullDC_plugins]
GUI=nullDC_GUI_Win32.dll
Current_PVR=nullPvr_Win32.dll
Current_GDR=zNullGD_Win32.dll
Current_AICA=nullAica_Win32.dll
Current_ExtDevice=nullExtDev_Win32.dll
Current_maple0_5=drkMapleDevices_Win32.dll:0
Current_maple1_5=NULL
Current_maple2_5=NULL
Current_maple3_5=NULL
Current_maple0_0=drkMapleDevices_Win32.dll:2
Current_maple0_1=drkMapleDevices_Win32.dll:2
Current_maple0_2=NULL
Current_maple0_3=NULL
Current_maple0_4=NULL
[drkpvr]
Emulation.AlphaSortMode=1
Emulation.PaletteMode=1
Emulation.ModVolMode=1
OSD.ShowFPS=0
OSD.ShowStats=0
Fullscreen.Enabled=1
Fullscreen.Res_X=1024
Fullscreen.Res_Y=768
Fullscreen.Refresh_Rate=60
Enhancements.MultiSampleCount=0
Enhancements.MultiSampleQuality=0
Enhancements.AspectRatioMode=1
[nullAica]
BufferSize=1024
LimitFPS=1
HW_mixing=0
SoundRenderer=1
GlobalFocus=1
BufferCount=1
CDDAMute=0
GlobalMute=0
[nullExtDev]
mode=0
adapter=0
[ndc_hookjoy]
PortA_CONT_C=66
PortA_CONT_B=88
PortA_CONT_A=86
PortA_CONT_START=16
PortA_CONT_DPAD_UP=38
PortA_CONT_DPAD_DOWN=40
PortA_CONT_DPAD_LEFT=37
PortA_CONT_DPAD_RIGHT=39
PortA_CONT_Z=77
PortA_CONT_Y=90
PortA_CONT_X=67
PortA_CONT_DPAD2_UP=0
PortA_CONT_DPAD2_DOWN=0
PortA_CONT_DPAD2_LEFT=0
PortA_CONT_DPAD2_RIGHT=0
PortA_CONT_ANALOG_UP=73
PortA_CONT_ANALOG_DOWN=75
PortA_CONT_ANALOG_LEFT=74
PortA_CONT_ANALOG_RIGHT=76
PortA_CONT_LSLIDER=65
PortA_CONT_RSLIDER=83
PortB_CONT_C=66
PortB_CONT_B=88
PortB_CONT_A=86
PortB_CONT_START=16
PortB_CONT_DPAD_UP=38
PortB_CONT_DPAD_DOWN=40
PortB_CONT_DPAD_LEFT=37
PortB_CONT_DPAD_RIGHT=39
PortB_CONT_Z=77
PortB_CONT_Y=90
PortB_CONT_X=67
PortB_CONT_DPAD2_UP=0
PortB_CONT_DPAD2_DOWN=0
PortB_CONT_DPAD2_LEFT=0
PortB_CONT_DPAD2_RIGHT=0
PortB_CONT_ANALOG_UP=73
PortB_CONT_ANALOG_DOWN=75
PortB_CONT_ANALOG_LEFT=74
PortB_CONT_ANALOG_RIGHT=76
PortB_CONT_LSLIDER=65
PortB_CONT_RSLIDER=83
PortC_CONT_C=66
PortC_CONT_B=88
PortC_CONT_A=86
PortC_CONT_START=16
PortC_CONT_DPAD_UP=38
PortC_CONT_DPAD_DOWN=40
PortC_CONT_DPAD_LEFT=37
PortC_CONT_DPAD_RIGHT=39
PortC_CONT_Z=77
PortC_CONT_Y=90
PortC_CONT_X=67
PortC_CONT_DPAD2_UP=0
PortC_CONT_DPAD2_DOWN=0
PortC_CONT_DPAD2_LEFT=0
PortC_CONT_DPAD2_RIGHT=0
PortC_CONT_ANALOG_UP=73
PortC_CONT_ANALOG_DOWN=75
PortC_CONT_ANALOG_LEFT=74
PortC_CONT_ANALOG_RIGHT=76
PortC_CONT_LSLIDER=65
PortC_CONT_RSLIDER=83
PortD_CONT_C=66
PortD_CONT_B=88
PortD_CONT_A=86
PortD_CONT_START=16
PortD_CONT_DPAD_UP=38
PortD_CONT_DPAD_DOWN=40
PortD_CONT_DPAD_LEFT=37
PortD_CONT_DPAD_RIGHT=39
PortD_CONT_Z=77
PortD_CONT_Y=90
PortD_CONT_X=67
PortD_CONT_DPAD2_UP=0
PortD_CONT_DPAD2_DOWN=0
PortD_CONT_DPAD2_LEFT=0
PortD_CONT_DPAD2_RIGHT=0
PortD_CONT_ANALOG_UP=73
PortD_CONT_ANALOG_DOWN=75
PortD_CONT_ANALOG_LEFT=74
PortD_CONT_ANALOG_RIGHT=76
PortD_CONT_LSLIDER=65
PortD_CONT_RSLIDER=83
local_port=0
server_addr=192.168.1.33
server_port=11122
[nullMaple]
ConfigMap.Count=0
ConfigMap[1].Guid={6F1D2B60-D5A0-11CF-BFC7-444553540000}
ConfigMap[1].Name=Mouse
ConfigMap[1].DeviceGuid={6F1D2B60-D5A0-11CF-BFC7-444553540000}
ConfigMap[1].DeviceName=Mouse
ConfigMap[1].State=0
ConfigMap[1].Map[0].Type=0
ConfigMap[1].Map[0].Source=0
ConfigMap[1].Map[1].Type=0
ConfigMap[1].Map[1].Source=0
ConfigMap[1].Map[2].Type=0
ConfigMap[1].Map[2].Source=0
ConfigMap[1].Map[3].Type=0
ConfigMap[1].Map[3].Source=0
ConfigMap[1].Map[4].Type=0
ConfigMap[1].Map[4].Source=0
ConfigMap[1].Map[5].Type=0
ConfigMap[1].Map[5].Source=0
ConfigMap[1].Map[6].Type=0
ConfigMap[1].Map[6].Source=0
ConfigMap[1].Map[7].Type=0
ConfigMap[1].Map[7].Source=0
ConfigMap[1].Map[8].Type=0
ConfigMap[1].Map[8].Source=0
ConfigMap[1].Map[9].Type=0
ConfigMap[1].Map[9].Source=0
ConfigMap[1].Map[10].Type=0
ConfigMap[1].Map[10].Source=0
ConfigMap[1].Map[11].Type=0
ConfigMap[1].Map[11].Source=0
ConfigMap[1].Map[12].Type=0
ConfigMap[1].Map[12].Source=0
ConfigMap[1].Map[13].Type=0
ConfigMap[1].Map[13].Source=0
ConfigMap[1].Map[14].Type=0
ConfigMap[1].Map[14].Source=0
ConfigMap[1].Map[15].Type=0
ConfigMap[1].Map[15].Source=0
ConfigMap[1].Map[16].Type=0
ConfigMap[1].Map[16].Source=0
ConfigMap[1].Map[17].Type=0
ConfigMap[1].Map[17].Source=0
ConfigMap[1].Map[18].Type=0
ConfigMap[1].Map[18].Source=0
ConfigMap[1].Map[19].Type=0
ConfigMap[1].Map[19].Source=0
ConfigMap[1].Map[20].Type=0
ConfigMap[1].Map[20].Source=0
ConfigMap[1].Map[21].Type=0
ConfigMap[1].Map[21].Source=0
ConfigMap[1].Map[22].Type=0
ConfigMap[1].Map[22].Source=0
ConfigMap[1].Map[23].Type=0
ConfigMap[1].Map[23].Source=0
ConfigMap[1].Map[24].Type=0
ConfigMap[1].Map[24].Source=0
ConfigMap[1].Map[25].Type=0
ConfigMap[1].Map[25].Source=0
ConfigMap[2].Guid={6F1D2B61-D5A0-11CF-BFC7-444553540000}
ConfigMap[2].Name=Keyboard
ConfigMap[2].DeviceGuid={6F1D2B61-D5A0-11CF-BFC7-444553540000}
ConfigMap[2].DeviceName=Keyboard
ConfigMap[2].State=0
ConfigMap[2].Map[0].Type=0
ConfigMap[2].Map[0].Source=0
ConfigMap[2].Map[1].Type=0
ConfigMap[2].Map[1].Source=0
ConfigMap[2].Map[2].Type=0
ConfigMap[2].Map[2].Source=0
ConfigMap[2].Map[3].Type=0
ConfigMap[2].Map[3].Source=0
ConfigMap[2].Map[4].Type=0
ConfigMap[2].Map[4].Source=0
ConfigMap[2].Map[5].Type=0
ConfigMap[2].Map[5].Source=0
ConfigMap[2].Map[6].Type=0
ConfigMap[2].Map[6].Source=0
ConfigMap[2].Map[7].Type=0
ConfigMap[2].Map[7].Source=0
ConfigMap[2].Map[8].Type=0
ConfigMap[2].Map[8].Source=0
ConfigMap[2].Map[9].Type=0
ConfigMap[2].Map[9].Source=0
ConfigMap[2].Map[10].Type=0
ConfigMap[2].Map[10].Source=0
ConfigMap[2].Map[11].Type=0
ConfigMap[2].Map[11].Source=0
ConfigMap[2].Map[12].Type=0
ConfigMap[2].Map[12].Source=0
ConfigMap[2].Map[13].Type=0
ConfigMap[2].Map[13].Source=0
ConfigMap[2].Map[14].Type=0
ConfigMap[2].Map[14].Source=0
ConfigMap[2].Map[15].Type=0
ConfigMap[2].Map[15].Source=0
ConfigMap[2].Map[16].Type=0
ConfigMap[2].Map[16].Source=0
ConfigMap[2].Map[17].Type=0
ConfigMap[2].Map[17].Source=0
ConfigMap[2].Map[18].Type=0
ConfigMap[2].Map[18].Source=0
ConfigMap[2].Map[19].Type=0
ConfigMap[2].Map[19].Source=0
ConfigMap[2].Map[20].Type=0
ConfigMap[2].Map[20].Source=0
ConfigMap[2].Map[21].Type=0
ConfigMap[2].Map[21].Source=0
ConfigMap[2].Map[22].Type=0
ConfigMap[2].Map[22].Source=0
ConfigMap[2].Map[23].Type=0
ConfigMap[2].Map[23].Source=0
ConfigMap[2].Map[24].Type=0
ConfigMap[2].Map[24].Source=0
ConfigMap[2].Map[25].Type=0
ConfigMap[2].Map[25].Source=0
ConfigMap[3].Guid={2EDC31B0-625F-11DC-8005-444553540000}
ConfigMap[3].Name=?
ConfigMap[3].DeviceGuid={8D9119FA-0000-0000-0000-504944564944}
ConfigMap[3].DeviceName=?
ConfigMap[3].State=0
ConfigMap[3].Map[0].Type=0
ConfigMap[3].Map[0].Source=0
ConfigMap[3].Map[1].Type=0
ConfigMap[3].Map[1].Source=0
ConfigMap[3].Map[2].Type=0
ConfigMap[3].Map[2].Source=0
ConfigMap[3].Map[3].Type=0
ConfigMap[3].Map[3].Source=0
ConfigMap[3].Map[4].Type=0
ConfigMap[3].Map[4].Source=0
ConfigMap[3].Map[5].Type=0
ConfigMap[3].Map[5].Source=0
ConfigMap[3].Map[6].Type=0
ConfigMap[3].Map[6].Source=0
ConfigMap[3].Map[7].Type=0
ConfigMap[3].Map[7].Source=0
ConfigMap[3].Map[8].Type=0
ConfigMap[3].Map[8].Source=0
ConfigMap[3].Map[9].Type=0
ConfigMap[3].Map[9].Source=0
ConfigMap[3].Map[10].Type=0
ConfigMap[3].Map[10].Source=0
ConfigMap[3].Map[11].Type=0
ConfigMap[3].Map[11].Source=0
ConfigMap[3].Map[12].Type=0
ConfigMap[3].Map[12].Source=0
ConfigMap[3].Map[13].Type=0
ConfigMap[3].Map[13].Source=0
ConfigMap[3].Map[14].Type=0
ConfigMap[3].Map[14].Source=0
ConfigMap[3].Map[15].Type=0
ConfigMap[3].Map[15].Source=0
ConfigMap[3].Map[16].Type=0
ConfigMap[3].Map[16].Source=0
ConfigMap[3].Map[17].Type=0
ConfigMap[3].Map[17].Source=0
ConfigMap[3].Map[18].Type=0
ConfigMap[3].Map[18].Source=0
ConfigMap[3].Map[19].Type=0
ConfigMap[3].Map[19].Source=0
ConfigMap[3].Map[20].Type=0
ConfigMap[3].Map[20].Source=0
ConfigMap[3].Map[21].Type=0
ConfigMap[3].Map[21].Source=0
ConfigMap[3].Map[22].Type=0
ConfigMap[3].Map[22].Source=0
ConfigMap[3].Map[23].Type=0
ConfigMap[3].Map[23].Source=0
ConfigMap[3].Map[24].Type=0
ConfigMap[3].Map[24].Source=0
ConfigMap[3].Map[25].Type=0
ConfigMap[3].Map[25].Source=0
ConfigMap[4].Guid={2EDC31B0-625F-11DC-8006-444553540000}
ConfigMap[4].Name=?
ConfigMap[4].DeviceGuid={8D9119FA-0000-0000-0000-504944564944}
ConfigMap[4].DeviceName=?
ConfigMap[4].State=0
ConfigMap[4].Map[0].Type=0
ConfigMap[4].Map[0].Source=0
ConfigMap[4].Map[1].Type=0
ConfigMap[4].Map[1].Source=0
ConfigMap[4].Map[2].Type=0
ConfigMap[4].Map[2].Source=0
ConfigMap[4].Map[3].Type=0
ConfigMap[4].Map[3].Source=0
ConfigMap[4].Map[4].Type=0
ConfigMap[4].Map[4].Source=0
ConfigMap[4].Map[5].Type=0
ConfigMap[4].Map[5].Source=0
ConfigMap[4].Map[6].Type=0
ConfigMap[4].Map[6].Source=0
ConfigMap[4].Map[7].Type=0
ConfigMap[4].Map[7].Source=0
ConfigMap[4].Map[8].Type=0
ConfigMap[4].Map[8].Source=0
ConfigMap[4].Map[9].Type=0
ConfigMap[4].Map[9].Source=0
ConfigMap[4].Map[10].Type=0
ConfigMap[4].Map[10].Source=0
ConfigMap[4].Map[11].Type=0
ConfigMap[4].Map[11].Source=0
ConfigMap[4].Map[12].Type=0
ConfigMap[4].Map[12].Source=0
ConfigMap[4].Map[13].Type=0
ConfigMap[4].Map[13].Source=0
ConfigMap[4].Map[14].Type=0
ConfigMap[4].Map[14].Source=0
ConfigMap[4].Map[15].Type=0
ConfigMap[4].Map[15].Source=0
ConfigMap[4].Map[16].Type=0
ConfigMap[4].Map[16].Source=0
ConfigMap[4].Map[17].Type=0
ConfigMap[4].Map[17].Source=0
ConfigMap[4].Map[18].Type=0
ConfigMap[4].Map[18].Source=0
ConfigMap[4].Map[19].Type=0
ConfigMap[4].Map[19].Source=0
ConfigMap[4].Map[20].Type=0
ConfigMap[4].Map[20].Source=0
ConfigMap[4].Map[21].Type=0
ConfigMap[4].Map[21].Source=0
ConfigMap[4].Map[22].Type=0
ConfigMap[4].Map[22].Source=0
ConfigMap[4].Map[23].Type=0
ConfigMap[4].Map[23].Source=0
ConfigMap[4].Map[24].Type=0
ConfigMap[4].Map[24].Source=0
ConfigMap[4].Map[25].Type=0
ConfigMap[4].Map[25].Source=0
ConfigMap[5].Guid={2EDC31B0-625F-11DC-8007-444553540000}
ConfigMap[5].Name=?
ConfigMap[5].DeviceGuid={8D9119FA-0000-0000-0000-504944564944}
ConfigMap[5].DeviceName=?
ConfigMap[5].State=0
ConfigMap[5].Map[0].Type=0
ConfigMap[5].Map[0].Source=0
ConfigMap[5].Map[1].Type=0
ConfigMap[5].Map[1].Source=0
ConfigMap[5].Map[2].Type=0
ConfigMap[5].Map[2].Source=0
ConfigMap[5].Map[3].Type=0
ConfigMap[5].Map[3].Source=0
ConfigMap[5].Map[4].Type=0
ConfigMap[5].Map[4].Source=0
ConfigMap[5].Map[5].Type=0
ConfigMap[5].Map[5].Source=0
ConfigMap[5].Map[6].Type=0
ConfigMap[5].Map[6].Source=0
ConfigMap[5].Map[7].Type=0
ConfigMap[5].Map[7].Source=0
ConfigMap[5].Map[8].Type=0
ConfigMap[5].Map[8].Source=0
ConfigMap[5].Map[9].Type=0
ConfigMap[5].Map[9].Source=0
ConfigMap[5].Map[10].Type=0
ConfigMap[5].Map[10].Source=0
ConfigMap[5].Map[11].Type=0
ConfigMap[5].Map[11].Source=0
ConfigMap[5].Map[12].Type=0
ConfigMap[5].Map[12].Source=0
ConfigMap[5].Map[13].Type=0
ConfigMap[5].Map[13].Source=0
ConfigMap[5].Map[14].Type=0
ConfigMap[5].Map[14].Source=0
ConfigMap[5].Map[15].Type=0
ConfigMap[5].Map[15].Source=0
ConfigMap[5].Map[16].Type=0
ConfigMap[5].Map[16].Source=0
ConfigMap[5].Map[17].Type=0
ConfigMap[5].Map[17].Source=0
ConfigMap[5].Map[18].Type=0
ConfigMap[5].Map[18].Source=0
ConfigMap[5].Map[19].Type=0
ConfigMap[5].Map[19].Source=0
ConfigMap[5].Map[20].Type=0
ConfigMap[5].Map[20].Source=0
ConfigMap[5].Map[21].Type=0
ConfigMap[5].Map[21].Source=0
ConfigMap[5].Map[22].Type=0
ConfigMap[5].Map[22].Source=0
ConfigMap[5].Map[23].Type=0
ConfigMap[5].Map[23].Source=0
ConfigMap[5].Map[24].Type=0
ConfigMap[5].Map[24].Source=0
ConfigMap[5].Map[25].Type=0
ConfigMap[5].Map[25].Source=0
ConfigMap[6].Guid={2EDC31B0-625F-11DC-8008-444553540000}
ConfigMap[6].Name=?
ConfigMap[6].DeviceGuid={8D9119FA-0000-0000-0000-504944564944}
ConfigMap[6].DeviceName=?
ConfigMap[6].State=0
ConfigMap[6].Map[0].Type=0
ConfigMap[6].Map[0].Source=0
ConfigMap[6].Map[1].Type=0
ConfigMap[6].Map[1].Source=0
ConfigMap[6].Map[2].Type=0
ConfigMap[6].Map[2].Source=0
ConfigMap[6].Map[3].Type=0
ConfigMap[6].Map[3].Source=0
ConfigMap[6].Map[4].Type=0
ConfigMap[6].Map[4].Source=0
ConfigMap[6].Map[5].Type=0
ConfigMap[6].Map[5].Source=0
ConfigMap[6].Map[6].Type=0
ConfigMap[6].Map[6].Source=0
ConfigMap[6].Map[7].Type=0
ConfigMap[6].Map[7].Source=0
ConfigMap[6].Map[8].Type=0
ConfigMap[6].Map[8].Source=0
ConfigMap[6].Map[9].Type=0
ConfigMap[6].Map[9].Source=0
ConfigMap[6].Map[10].Type=0
ConfigMap[6].Map[10].Source=0
ConfigMap[6].Map[11].Type=0
ConfigMap[6].Map[11].Source=0
ConfigMap[6].Map[12].Type=0
ConfigMap[6].Map[12].Source=0
ConfigMap[6].Map[13].Type=0
ConfigMap[6].Map[13].Source=0
ConfigMap[6].Map[14].Type=0
ConfigMap[6].Map[14].Source=0
ConfigMap[6].Map[15].Type=0
ConfigMap[6].Map[15].Source=0
ConfigMap[6].Map[16].Type=0
ConfigMap[6].Map[16].Source=0
ConfigMap[6].Map[17].Type=0
ConfigMap[6].Map[17].Source=0
ConfigMap[6].Map[18].Type=0
ConfigMap[6].Map[18].Source=0
ConfigMap[6].Map[19].Type=0
ConfigMap[6].Map[19].Source=0
ConfigMap[6].Map[20].Type=0
ConfigMap[6].Map[20].Source=0
ConfigMap[6].Map[21].Type=0
ConfigMap[6].Map[21].Source=0
ConfigMap[6].Map[22].Type=0
ConfigMap[6].Map[22].Source=0
ConfigMap[6].Map[23].Type=0
ConfigMap[6].Map[23].Source=0
ConfigMap[6].Map[24].Type=0
ConfigMap[6].Map[24].Source=0
ConfigMap[6].Map[25].Type=0
ConfigMap[6].Map[25].Source=0
I'm also using mostly CDI images I had one working last night which was Virtua Fighter 3 then after all that I kept configure controls errors and going to the CD player menu pretty strange :(
Ok I'd delete the nulldc.cfg and run the app again.
This will create a new nulldc config. In the config file itself. You'll notice that there is a section for default image. Right now I see that it is default.cdi. When you have the setting enabled like LoadDefaultImage=1 ,Emulator.AutoStart=1. What happens is the emulator once run will autostart the default image which is default.cdi.
What the CLI does is inject the "[ROMPATH]"/"[ROMFILE]" into the default image field. so it will look like this
defaultimage="c:\mygames\dreamcast\mvc2.cdi" so essentially it will auto load marvelvscapcom2 on startup.
Once ended and you choose another game it will change the config accordingly.
So either your config is messed up. Or your dcflash.bin
It maybe a good idea to replace your bioses.
Other simple troubleshooting techniques including running the RUNLASTGAME.BAT that you will find located in the programs group on the start menu. This way you can reproduce the commad that gameex is using to launch nulldc ourside gameex for trouble shooting.
Also export and post your nulldc config.
Hope this helps
I replaced the bios and deleted the .cfg file and re-loaded nullDC and it reproduced a .cfg file heres the file untouched should I add anything before I load it up in GameEx again? Thanks again for all your help! :D
[nullDC]
Dynarec.Enabled=1
Dreamcast.Cable=3
Dreamcast.RTC=1830437346
Emulator.AutoStart=0
[nullDC_plugins]
Current_GDR=nullGDR_Win32.dll
Current_maple0_5=NULL
[drkpvr]
OSD.ShowFPS=0
OSD.ShowStats=0
Fullscreen.Enabled=0
Fullscreen.Res_X=640
Fullscreen.Res_Y=480
[imageReader]
PatchRegion=0
LoadDefaultImage=0
DefaultImage=defualt.cdi
[nullAica]
BufferSize=1024
LimitFPS=1
HW_mixing=0
SoundRenderer=1
GlobalFocus=1
BufferCount=1
CDDAMute=0
GlobalMute=0
[nullExtDev]
mode=0
adapter=0
[ndc_hookjoy]
PortA_CONT_C=66
PortA_CONT_B=88
PortA_CONT_A=86
PortA_CONT_START=16
PortA_CONT_Z=77
PortA_CONT_Y=90
PortA_CONT_X=67
PortB_CONT_C=66
PortB_CONT_B=88
PortB_CONT_A=86
PortB_CONT_START=16
PortB_CONT_Z=77
PortB_CONT_Y=90
PortB_CONT_X=67
PortC_CONT_C=66
PortC_CONT_B=88
PortC_CONT_A=86
PortC_CONT_START=16
PortC_CONT_Z=77
PortC_CONT_Y=90
PortC_CONT_X=67
PortD_CONT_C=66
PortD_CONT_B=88
PortD_CONT_A=86
PortD_CONT_START=16
PortD_CONT_Z=77
PortD_CONT_Y=90
PortD_CONT_X=67
local_port=0
server_port=11122
[nullMaple]
ConfigMap.Count=6
ConfigMap[3].Name=?
ConfigMap[4].Name=?
ConfigMap[5].Name=?
ConfigMap[6].Name=?
Port0={481E6345-C2DA-4EF5-B819-5DF87D64E9E2}
Port1={481E6345-C2DA-4EF5-B819-5DF87D64E9E2}
Port2={481E6345-C2DA-4EF5-B819-5DF87D64E9E2}
Port3={481E6345-C2DA-4EF5-B819-5DF87D64E9E2}
[nullDC]
Dynarec.Enabled=1
Dreamcast.Cable=3
[nullDC_plugins]
[drkpvr]
OSD.ShowFPS=0
OSD.ShowStats=0
[imageReader]
PatchRegion=0
LoadDefaultImage=1
Didn't seem to work, I know I'm starting to sound annoying :( I could just use Chankast but I know nullDC is a much better DC emulator any more ideas? Maybe I'm doing something wrong? Thanks again for all your help!!
Images are loaded through the GDROM.ini file...I have a loader coded up for this emu in the 101 reasons thread.
Oh and sorry for being slow to reply...its been one of those days where your just to tied up with different odd ball things...that something is bound to slip through the cracks. :(
Brian Hoffman was kind enough to help me configure and get nullDC running in GameEx via a remote connection and everything is working perfectly! I even learned some new things about nullDC and GameEx and learned about some really cool programs too. Thanks a lot for the help Brian and everyone else. I am definitely going to be donating to Tom very soon. GameEx is an amazing app! Thanks again guys!!! :)
Brian (or anyone!)
I can't seem to get NullDC working. It works great outside of GameEx, but when I run it inside, I just see the desktop. I have your 2 loader files in the correct directory, and I have the config file set as you have it listed, except I don't know what this line is:
configFile=nes
here is my config file
[Emulator_32]
DumbyValue=
STARTPAGENAME=Sega Dreamcast NullDC
TITLETEXT=Dreamcast NullDC
StartPageLogo=
ROMFilter=*.cdi;*.nrg
RomsInFolders=
RomPath=D:\dreamcast
SnapPath=D:\dreamcast\snap
TitlePath=
BoxPath=
CartPath=
WorkingPath=D:\nulldc
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=Command=nulldc_100b1_6.exe -config ImageReader:DefaultImage="[rompath]/[romfile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=dreamcast
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
GamesIn7Zips=
ManualPath=
ControlPanelPath=
DontShowInfo=
PlaySelectionMusic=
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
lastgame=
here is my nullDC config:
[nullDC]
Dynarec.Enabled=1
Dreamcast.Cable=1
Dreamcast.RTC=1543452494
[nullDC_plugins]
Current_maple0_5=nullMaple_Win32.dll:0
Current_maple0_1=NULL
[drkpvr]
OSD.ShowFPS=0
OSD.ShowStats=0
Enhancements.AspectRatioMode=0
[imageReader]
PatchRegion=0
LoadDefaultImage=1
[nullAica]
BufferSize=1024
LimitFPS=1
HW_mixing=0
SoundRenderer=1
GlobalFocus=1
BufferCount=1
CDDAMute=0
GlobalMute=0
[nullExtDev]
mode=0
adapter=0
[ndc_hookjoy]
PortA_CONT_C=66
PortA_CONT_B=88
PortA_CONT_A=86
PortA_CONT_START=16
PortA_CONT_DPAD_UP=1
PortA_CONT_Z=77
PortA_CONT_Y=90
PortA_CONT_X=67
PortB_CONT_C=66
PortB_CONT_B=88
PortB_CONT_A=86
PortB_CONT_START=16
PortB_CONT_Z=77
PortB_CONT_Y=90
PortB_CONT_X=67
PortC_CONT_C=66
PortC_CONT_B=88
PortC_CONT_A=86
PortC_CONT_START=16
PortC_CONT_Z=77
PortC_CONT_Y=90
PortC_CONT_X=67
PortD_CONT_C=66
PortD_CONT_B=88
PortD_CONT_A=86
PortD_CONT_START=16
PortD_CONT_Z=77
PortD_CONT_Y=90
PortD_CONT_X=67
local_port=0
server_port=11122
[nullMaple]
ConfigMap.Count=3
ConfigMap[3].Guid={CB3144F0-B487-11DB-8003-444553540000}
ConfigMap[3].Name=Microsoft SideWinder game pad
ConfigMap[3].DeviceGuid={0003045E-0000-0000-0000-504944564944}
ConfigMap[3].DeviceName=Microsoft SideWinder game pad
ConfigMap[3].Map[0].Type=1
ConfigMap[3].Map[0].Source=4
ConfigMap[3].Map[1].Type=1
ConfigMap[3].Map[1].Source=4
ConfigMap[3].Map[2].Type=1
ConfigMap[3].Map[2].Source=3
ConfigMap[3].Map[3].Type=1
ConfigMap[3].Map[3].Source=10
ConfigMap[3].Map[4].Type=3
ConfigMap[3].Map[4].Source=1
ConfigMap[3].Map[5].Type=2
ConfigMap[3].Map[5].Source=1
ConfigMap[3].Map[6].Type=3
ConfigMap[3].Map[7].Type=2
ConfigMap[3].Map[8].Type=1
ConfigMap[3].Map[8].Source=7
ConfigMap[3].Map[9].Type=1
ConfigMap[3].Map[9].Source=6
ConfigMap[3].Map[10].Type=1
ConfigMap[3].Map[10].Source=5
ConfigMap[3].Map[16].Type=1
ConfigMap[3].Map[16].Source=9
ConfigMap[3].Map[17].Type=1
ConfigMap[3].Map[17].Source=8
ConfigMap[3].Map[18].Type=2
ConfigMap[3].Map[19].Type=3
ConfigMap[3].Map[20].Type=2
ConfigMap[3].Map[20].Source=1
ConfigMap[3].Map[21].Type=3
ConfigMap[3].Map[21].Source=1
Port0={CB3144F0-B487-11DB-8003-444553540000}
I am running WinXP home
Any help would be greatly appreciated!
Your null dc config is slightly diffrent than mine.. You also do not need loaders with this method.
Delete you nulldc.cfg and run the app again... Manually edit the sections in RED that Ive referred to in a few other posts and try it again..
If you have any problems just respond. I have not had anyone not get this methond working.
  Brian Hoffman said:
Your null dc config is slightly doffrent than mine.. You also do not need loaders with this method.
Thanks for the reply Brian.
I deleted my nulldc config, and then ran it. I then edited and saved the 3 lines you mentioned. I still get the same exact problem, just a desktop. When I hit escape, I return to GameEx. As I mentioned before, your GameEx config posted in this thread has the following line:
configFile=nes
I don not have any file named that in my GameEx install. Could this be my problem? I will post my GameEx config and my NullDC config again below:
GameEx
[Emulator_32]
DumbyValue=
StartPageLogo=
RomsInFolders=
TitlePath=
BoxPath=
CartPath=
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
OLDatZip=
LaunchBefore=
LaunchAfter=
ExcludedFiles=
CustomBackground=
PlayMusic=
PCGame=
GamesIn7Zips=
ManualPath=
ControlPanelPath=
DontShowInfo=
PlaySelectionMusic=
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
lastgame=
NullDC Config
[nullDC]
Dynarec.Enabled=1
Dreamcast.Cable=3
Dreamcast.RTC=1831052263
[nullDC_plugins]
[drkpvr]
OSD.ShowFPS=0
OSD.ShowStats=0
[imageReader]
PatchRegion=0
LoadDefaultImage=1
[nullAica]
BufferSize=1024
LimitFPS=1
HW_mixing=0
SoundRenderer=1
GlobalFocus=1
BufferCount=1
CDDAMute=0
GlobalMute=0
[nullExtDev]
mode=0
adapter=0
[ndc_hookjoy]
PortA_CONT_C=66
PortA_CONT_B=88
PortA_CONT_A=86
PortA_CONT_START=16
PortA_CONT_Z=77
PortA_CONT_Y=90
PortA_CONT_X=67
PortB_CONT_C=66
PortB_CONT_B=88
PortB_CONT_A=86
PortB_CONT_START=16
PortB_CONT_Z=77
PortB_CONT_Y=90
PortB_CONT_X=67
PortC_CONT_C=66
PortC_CONT_B=88
PortC_CONT_A=86
PortC_CONT_START=16
PortC_CONT_Z=77
PortC_CONT_Y=90
PortC_CONT_X=67
PortD_CONT_C=66
PortD_CONT_B=88
PortD_CONT_A=86
PortD_CONT_START=16
PortD_CONT_Z=77
PortD_CONT_Y=90
PortD_CONT_X=67
local_port=0
server_port=11122
[nullMaple]
ConfigMap.Count=3
another thing I just noticed when I now try to run NullDC outside of GameEx. I now get an error message saying "Default Image "AEEa" failed to load.
  Brian Hoffman said:
I dont believe nulldc supports native NRG files..
Let me know when you can be available online and we can go through this.
It runs them fine outside of GameEx. Where is this default.cdi supposed to be? I don't see this anywhere either.
Its a placeholder in the nulldc config.. What my command does is inject the path and romname into that field..
This is why once you set to loaddefault to 1 it loads the game selected. Then autostarts emulation.
Im sure this problem is in your command line/ config
Thanks Brian!
The problem was my command line and config, I really appreciate all your help!
Everything works great now.
  • 2 months later...
Hello ...again as this being my second post and I must say I love the GameEX front-end. I just donated and got the registration key but I didn't want to install the program until I fully know how to put emulators and roms on it so I am still using the so-called "trial" version. Ok, as I was reading post after post after post from 8am to now it's a quarter to 5, I too have NullDC and don't have the slightest idea of how to get it on GameEX. I haven't done anything to even get started and was hoping a step-by-step processes on how to do it. I would hate to screw something up if I'm doing it by myself. I feel good saying this to you guys because as I can see you all have patience which your community ...thanks and much apprec.
Oh and by the way, hello I'm BlackMage (no magic required, unless otherwise) and I am a Newbie ...just don't throw me in my locker with "newbie" marks all over my face cause I'm new.
Registered users don't get a different version of the program, so there's no reason to hold off. All you get is some new features that make some things a lot nicer (automatic updates is awesome)!
