Hey, first post! I've been looking around trying to find a nice front end, and I really like the looks of GameEx, but I'm having a lot of trouble getting it working on Windows 98 SE (Fresh copy). Running the GameEx installer it managed to download and install Windows Media Player, MDAC, .net Framework etc fine, but in the actual installation, right near the end it gave me an error "Unable to register the DLL/OCX: LoadLibrary failed; code 31. A device attached to the system is not functioning." Finding no way around this error I simply clicked ignore, and then it gave me 4-5 errors in a row, all point to an error in mscoree.dll. I've tried reinstalling .net Framework to no avail, and am stuck (the log is blank). Any ideas?
Check that you have the most current drivers for your OS... This might be a little diffacult...
Good luck
Brian Hoffman
You need to post your log file (c:\Program Files\GameEx\LOG\) containing the error if you want better help than just generic "check your system" responses. Most of the time, you will be able to get a response within minutes of posting the error!
See that's the weird thing the log's blank, well not really blank:
16:58:12.8 17/08/2007: GameEx: Version 8.75: Starting Log
16:58:12.9 17/08/2007: Operating System Platform: Win32NT
16:58:12.9 17/08/2007: Operating System Name: Windows XP
16:58:12.9 17/08/2007: Operating System Version: 5.1.2600
16:58:12.9 17/08/2007: Checking for versions of .net Framework installed
16:58:12.9 17/08/2007: .net Framework 2.0 Installed
16:58:12.9 17/08/2007: Intel® Xeon® CPU E5320 @ 1.86GHz, 3326MB
16:58:12.9 17/08/2007: 1.86Ghz - 4 Cores or CPU's
16:58:12.9 17/08/2007: Running Randomize()
16:58:12.9 17/08/2007: Loading PlugIns
16:58:13.2 17/08/2007: Checking for applications to Launch On Startup
16:58:13.2 17/08/2007: Running Misc startup tasks
16:58:13.2 17/08/2007: Setting Menu types
16:58:13.2 17/08/2007: Opening Configuration File
16:58:13.2 17/08/2007: Getting Configuration Values
16:58:13.2 17/08/2007: Using Theme: Default - Media Center
16:58:13.2 17/08/2007: Checking for alternate Image Directory for Theme: Default - Media Center
16:58:13.2 17/08/2007: Launching HideOS.exe
16:58:13.2 17/08/2007: Initialising Video/MNG DLL's
16:58:13.2 17/08/2007: Hiding Taskbar
16:58:13.2 17/08/2007: Is Media Center running?
16:58:13.2 17/08/2007: Checking/Creating LCD Registry values
16:58:13.2 17/08/2007: Check Media Center Exit/Start Mode
16:58:13.2 17/08/2007: Media Center Mode 2
16:58:13.2 17/08/2007: Video previews on. Warning: Only recommended on modern systems
16:58:13.2 17/08/2007: Snap Delay set to: 2
16:58:13.2 17/08/2007: Get other settings
16:58:13.3 17/08/2007: Desktop set to Hide ICONS and set Background to Black
16:58:13.3 17/08/2007: Backing up Registry Wallpaper Settings
16:58:13.3 17/08/2007: Set: Find emulator artwork on best match basis
16:58:13.3 17/08/2007: Start work for Form
16:58:13.3 17/08/2007: Getting Original Screen Size
16:58:13.4 17/08/2007: Opening Database Connection
16:58:14.1 17/08/2007: Initializing Component
16:58:14.3 17/08/2007: Retrieving resolution setting
16:58:14.3 17/08/2007: Creating Radio Station Genres
16:58:14.4 17/08/2007: Succesfully created station genres
16:58:14.4 17/08/2007: Initialising Windows Media Player Component
16:58:14.5 17/08/2007: MAME Path is: G:\MAME32
16:58:14.5 17/08/2007: MAME EXE file is: Mame32.exe
16:58:14.5 17/08/2007: ROM Path is: G:\-DATA-\-MAME ROMS-
16:58:14.5 17/08/2007: Catver.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\catver.ini
16:58:14.5 17/08/2007: controls.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\data\controls.ini
16:58:14.5 17/08/2007: History.dat is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\history.dat
16:58:14.5 17/08/2007: nplayers.ini is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\nplayers.ini
16:58:14.5 17/08/2007: MAMEinfo.dat is located at: G:\-DATA-\-MY PROJECTS-\GameEx - VB.net\bin\DATA\mameinfo.dat
16:58:14.5 17/08/2007: Loading Controls.ini map file
16:58:14.6 17/08/2007: Snap Path: Not Found
16:58:14.6 17/08/2007: AVI Snap Path is: G:\Mame32\MAMEMNG\ingame
16:58:14.6 17/08/2007: Flyer Path: Not Found
16:58:14.6 17/08/2007: Cabinet Path: Not Found
16:58:14.6 17/08/2007: Title Path: Not Found
16:58:14.6 17/08/2007: Panel Path: Not Found
16:58:14.6 17/08/2007: Manual Path: Not Found
16:58:14.6 17/08/2007: Icon Path: Not Found
16:58:14.6 17/08/2007: Marquee Path: Not Found
16:58:14.6 17/08/2007: Loading Custom Emulators
16:58:14.8 17/08/2007: Using 2D Animations
16:58:14.8 17/08/2007: Using General Font: Trebuchet MS
16:58:14.8 17/08/2007: Using Title Font: Trebuchet MS
16:58:14.8 17/08/2007: MAME CMD options: -triplebuffer -nowindow -joy
16:58:14.8 17/08/2007: Attempting to load game list
16:58:15.3 17/08/2007: Initialising DirectDraw
16:58:15.4 17/08/2007: Applying GameEx is Loading Image
16:58:15.5 17/08/2007: Creating DirectDraw Device
16:58:15.5 17/08/2007: Using Device: Primary Display Driver
16:58:16.4 17/08/2007: 0mb video memory available
16:58:16.8 17/08/2007: Setting Resolution to 800x600 32 bit color
16:58:16.9 17/08/2007: Cannot Set Resolution to: 800x600 32 bit color
16:58:16.9 17/08/2007: Error in the application.
16:58:16.9 17/08/2007: Trying current windows resolution
16:58:17.0 17/08/2007: Creating DirectDraw Surfaces
16:58:17.0 17/08/2007: Creating Primary Surface - Full Screen Mode
16:58:17.0 17/08/2007: Creating Back Buffer
16:58:17.0 17/08/2007: Loading graphic Surfaces
16:58:17.0 17/08/2007: Display is running at: 1280x720 16bit color, 42hz
16:58:17.0 17/08/2007: Creating Surfaces Misc and Dialogs
16:58:17.2 17/08/2007: Creating Surfaces Volume
16:58:17.2 17/08/2007: Creating Surfaces Arrows
16:58:17.3 17/08/2007: Creating Surfaces GameEXlogo Text
16:58:17.3 17/08/2007: Creating Surfaces Toolbar
16:58:17.5 17/08/2007: Creating Surfaces Backgrounds
16:58:22.1 17/08/2007: Creating Surfaces Toolbar Controls
16:58:22.2 17/08/2007: Creating Surfaces GameEx Logo
16:58:22.2 17/08/2007: Creating Surfaces Home & Exit
16:58:22.3 17/08/2007: Creating Surfaces Snaps
16:58:22.3 17/08/2007: Creating Surfaces Menu and List Bars
16:58:22.5 17/08/2007: Creating Fonts
16:58:22.5 17/08/2007: Creating Menu Font
16:58:22.6 17/08/2007: Restoring Menu Font From Cache
16:58:22.7 17/08/2007: Creating Game Font
16:58:22.8 17/08/2007: Creating Font Black
16:58:22.9 17/08/2007: Creating Font Black Small
16:58:22.9 17/08/2007: Creating Game Font Faded
16:58:23.0 17/08/2007: Creating Title Font
16:58:23.0 17/08/2007: Restoring Title Font From Cache
16:58:23.8 17/08/2007: Fonts Created Succesfully
16:58:23.8 17/08/2007: 0mb video memory left available
16:58:23.8 17/08/2007: Creating instance of global keyboard hook
16:58:23.8 17/08/2007: Starting GameExtender Publisher
16:58:23.9 17/08/2007: Text/Language: English
16:58:23.9 17/08/2007: Applying Language/Text
16:58:23.9 17/08/2007: Initialising Bass Audio Library
16:58:24.1 17/08/2007: Loading last used Game List
16:58:24.1 17/08/2007: Setting Music Volume
16:58:24.2 17/08/2007: Creating DirectSound Device
16:58:24.2 17/08/2007: Trying: Primary Sound Driver
16:58:24.2 17/08/2007: Loading Sound Files
16:58:24.3 17/08/2007: DirectSound Device Created Successfully
16:58:24.3 17/08/2007: Initialising DirectInput for Gamepad support
16:58:24.3 17/08/2007: Unable to create a joystick device
16:58:24.3 17/08/2007: Playing intro sound file
16:58:24.4 17/08/2007: Initializing MCE Remote
16:58:24.4 17/08/2007: Initialization OK! Starting GameEx!
16:58:24.4 17/08/2007: Testing Main Loop Once: Processing Frame
16:58:24.7 17/08/2007: Testing Main Loop Once: Main Loop ran successfully
16:58:36.2 17/08/2007: Exiting GameEx!
16:58:36.2 17/08/2007: Saving Settings
16:58:38.1 17/08/2007: Disposing Plugins
16:58:38.1 17/08/2007: Closing database connection
16:58:38.1 17/08/2007: Checking for applications to Launch On Exit
But that's not my system that it's referring to. So bizarre. The main difficulty with drivers etc is that this is a Dell PC built for windows XP, but I'm running 98 on it. I was able to get drivers for everything, apart from the sound card in the PC, so I installed a separate PCI one for that. I'm pretty stumped, because it was actually loading to the registration screen when the PC was running 98, but it would freeze when it tried to actually go into the front end. But now with second edition, I've go no clue, I'm thinking I might have to bite the bullet and use XP...thanks for the replies so far though!
Liam
That doent look good..
Tell gameex in the advanced config not to change resolutions...
Also disable your ESC key exit in the config... Just in case there is a stuck key or somthing
I can't get into the setup to even do that :P. I've already tried reinstalling windows 98 over top of it, but I'm loathe to go to XP. The main thing for me is boot times, are they comparable? Thanks for the help so far!
the gameex advanced config is not within the gameex app itself.. Its a seprate EXE located the in programs group on start menu..
Your very welcome....
BTW what are your system specs
Actually, I've found that for pretty much any system, Win98 runs slower than WinXP. As long as you have a minimal system that can boot XP, I would DEFINITELY go that route. Also, the boot time for XP is highly dependent on what software you are running. If you have a bunch of junk loading up, it will take a while to boot. If you choose to shell your machine to boot straight into GameEx, it boots pretty quickly.
I can't run any program in the folder, even uninstall! All my other programs work fine, it's pretty weird. At this point I think I'm just going to give in, and install windows XP, if I have any more problems I'll be sure to post back here, but thanks anyways, out.
Liam
Hi. I was just reading an earlier post that Tom replied to and it seems the gameex log is reporting 0 Mb memory available on your graphics card, so i'd look along the graphics card/driver side of things.
Another Thing is you say your running 98Se...But you have 3gigs memory and dualcore cpus.. 98 does not support more than a gig...let alone dualcore cpus.
This might also be the root of your problems
Brian Hoffman
No I mean, that's not my computer in the log, I've got a single core 2.8 celeron d, and 512 mb of ram. That log is really not mine! Haha, in any case I've made the move to windows XP, seems to be working just fine (not really that much longer loadup). I absolutely love GameEx, will probably be donating shortly, but one quick question. With the instantsheller program found on this site, or through different means is there any way to have an animated XP boot logo? Thanks
There is a program called bootskin by stardock
In the FAQ there is a bunch of shelling info...
Youll like it...Its a wealth of info
Brian Hoffman
Check out the BootLogo program, it allows you to create a boot logo with animated bar. It includes a Mame logo in the archive.
http://www.gameex.net/Download/MediaandIma...86/Default.aspx
Hi, just to clear things up, thats the default log included with gameex install. Its actually the log of my development pc.
Not many folks have a quad core Xeon, and 4GB Ram :)
The 0mb video memory is because it was last run under a remote desktop session.
