17th July 2005
- GameEx 4.61 - Your getting spoilt!
  • Should fix MAME game focus
    issues. If not please report on the forums.
  • New setting to disable the
    ability to exit GameEx with the escape key.
  • Four new settings to launch
    files on starting and exit of GameEx.
"New setting to disable the ability to exit GameEx with the escape key."
thank you very much Tom, will upgrade right now even though its 3AM :P
Same here actually. Are you British Smiff?
yup fraid so. thought you must be either brit or australian.. we still tend to stick out on the American 'net ;)
and the launch on start/exit should allow me to take care of almost all my startup/shutdown probs.. thanks a lot.
small bug or im not sure if its just i edit the configs by hand.. it keeps renabling "Play dvd" even though i disabled that to use my own dvd player.
omg do you ever sleep :D this must be the must busy weekend for Game-Ex :lol:
tho its 4:51 here at night here been working like crazyyyyy to improve the theme and alot of improvements have been made allready :)
anyway Toms activeness on it kinda makes me work alittle harder on the theme my goal are all will use it when done nah J/K :P:)
also ack
logoff option has dissappeared because the exit gameex option has reappeared (using noexitonescape) and i use flatstartpage.
probably you should allow those other options to show up with flatstartpage?
but no matter, i can now run a script on exit to standby the system anyway... just gotta work out how to restart it.. anyway bedtime 4AM
also ack
logoff option has dissappeared because the exit gameex option has reappeared (using hideescape) and i use flatstartpage.
Not really sure what you mean there!? Are you sure you set the settings right?
Its DisableEscape not hideescape. And all it does is not run code if the escape key is pressed it does not affect anyting displaying on the start page. At least it shouldnt.
Go do a sanity check!
Its not a bug, but deliberate I re-enable it every time in the install application.
That's good to know, be sure to let me know when its done.
i sure will i dunno if i should post previews like i did before i guess those confuse more than do good :)
Just a suggestion...Is it possible, when you have your settings so it pauses the GameEx playlist and plays MAME (or another emulator), that when you exit the game it continues with the song that was playing previous to the game selection? That may not be possible, or feasible (I am by no means a programmer), but it seems like it would give the whole experience more continuity. Not a big deal, just a suggestion. I am continually amazed at what you have done with this so far! :blink:
Along the same lines as my last post, the other thing that would be nice is if there was an option to have the jukebox play in conjuction with other emulators. So it wouldn't pause during, say Pinmame, it would continue to play through with the sound from the game either on or off. Don't know the technical involvement, so forgive me if that is suggesting too much. Heck, the damn program is pretty darn sweet as-is.
Wow! I go camping for a couple days and Tom is still busy!
The exit-on-home stuff is working great so far!
-- Rob
