Hi Tom,
Just downloaded version 4.60 and when executing Lunar Lander it just shows a blank screen. If I bring up the task manager I can see Lunar Lander running. I end task the Lunar Lander and it focuses properly and then exits back.
I haven't found any other games that do this but then again, I haven't had time to go through a whole bunch.
The lastest versions have made a big improvement on speed!
Hi Tom,
Hi,
I think that's a side effect of the speed enhancments. Thanks for reporting. Ill look at it. Need to enjoy myself a bit now its the weekend first.
No doubt... you've only made 7 different releases this week. Please take a few days off. The last thing any of us want is for you to get burnt out. :)
I do actually get plenty of sleep, it just seems like I don't!
I really also dont like leaving GameEx in a buggy state. Once its stable, I will take a bit of a break.
Anyway please try this updated GameEx.exe see if its OK.
Cheers.
GameEx.zip
Tom, I downloaded version 4.61 and that did the trick. Lunar Lander comes up fine now.
Speed is still fantastic.
Thank you once again for an excellent front end.
