I'm sorry if someone has covered this but I have done a lot of digging and can't find the answer I need.
Right here goes, I select an emulator and I am presented with the relevant list of games available for it, I select one and the emu loads up fullscreen etc etc just without the rom file., Ihave to bring my mouse out (I'm running a cab) and navigate to the roms in the usual windows fashion, which obviously negates the whole purpose of me cab!!! (how terribly embarrasing)
I'm sure its a simple config issue and yes I have tried the command = exampleemu.exe "[Rompath]\[RomFile]"
any help would be great thanks!
What emu are you using first of all...
No one can help with the little info you supplied. Chances are good someone here has it going correctly.
Try taking off the quotes
BTW: Welcome to the board :)
Sorry, I should have mentioned I've been trying, Gens, Gens+, Fusion and snes9x. all with the same result
and I have tried it without the quotes
Mame works just great by the way!
Try using the show desktop option :)
I use ZSNES It works well.
I am posting my configs..
----------------[Emulator_10]
STARTPAGENAME=Sega Genesis
TITLETEXT=Sega Genesis
StartPageLogo=genesis
ROMFilter=*.zip
RomPath=C:\Games\genesis
SnapPath=
TitlePath=
BoxPath=
CartPath=
ManualPath=
WorkingPath=C:\Console\Genesis
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=True
Debug=False
MAPFile=
AlsoLaunch=
Command=gens.exe "[ROMPath]\[RomFile]"
OLDatZip=
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
SelectionMusicFolder=
PCGame=
DATABASE=
GamesIn7Zips=
PlayInScreenSaver=True
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
------------------------[Emulator_7]
STARTPAGENAME=Nintendo SNES games
TITLETEXT=SNES
StartPageLogo=snes
ROMFilter=*.zip
RomPath=C:\Games\SNES
SnapPath=
TitlePath=
BoxPath=C:\Console\consoleart\Boxscans_SNES_(USA)_28May04\Boxscans_SNES_(USA)_28May04
CartPath=C:\Console\consoleart\CartScans_SNES_USA\CartScans SNES USA
ManualPath=
WorkingPath=C:\Console\snes
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
ShowDesktop=False
Debug=False
MAPFile=
AlsoLaunch=
Command=zsnesw.exe "[ROMPath]\[RomFile]"
OLDatZip=C:\Program Files\OfflineList0.7\datas\snes_OL.zip
LaunchBefore=
LaunchAfter=
configFile=
ExcludedFiles=
PlayMusic=
DontShowInfo=
PlaySelectionMusic=
PCGame=False
DATABASE=SNES
GamesIn7Zips=False
ShowMostPlayed=
RandomMostPlayed=
CDCheck=
CDCheckFile=
[GENERAL]
DumbyValue=
you could also try adding a PAUSE to the end of "runitgame.bat" in the "GameEx\DATA\" folder then run the batch file and see if it's giving you any error or it might even be obvious what the problem is when you see the command being sent... runitgame.bat will run the last game GameEX tried to run
Stu
See, if these were set up like Mame, with the option to cmd it in whatever way also (which I think it does, already), these things I think wouldn't be issues for people.
There's Advanced Config files to load to get around these problems. Most (if not all) systems you use are represented.
Go to Advanced Config -> Emulator ## -> Load Config
