I just reformatted a hard drive to dedicate to my front end and cabinet, I have gameex installed on my old hard drive still with all my configs/paths etc, the way I like it.
I have freshly installed gameex on this new drive, What do I copy over to my new install from the old one for it to know my settings, I know I have to change paths, but I dont want to re enter all that DAPHNE information etc and dont want to corrupt my new install by just dumping old install files over it.
thanks!
Nick
Actually normally you copy over the whole of the original install folder, then install over top of it, and skip the Setup Wizard...that is unless you want to add some thing new...
Ok I will uninstall and then do it that way. Thanks for the tip
