Love the latest round of updates. All in all the system is running much better. I am experiencing a new issue though using the Vahalla theme. It is as if the menu transitions stopped working after the last update and the finstare ultra small almost out of whack with the background. So small that you cannot clcik on them to select anything.
Nothing else on the cab changed other than the update...any ideas?
Gratefull user,
CP
Gratefull user,
CP
Have you tried telling gameex not to switch resolutions? Or a choosing a default theme?
That comes first to mind...
Also a little more info about your hardware would be helpfull.
Thanks..pasted in the log. I have been a long time gamex user. I have not started to mess with any of the settings yet as this a function of the upgrade not anything on my side. At least I think. In regards to the hardware...there is more than enough here to handle gamex at the moment but you will see that in the logg...thanks for looking
21:16:14.5 7/19/2007: GameEx: Version 8.57: Starting Log
21:16:14.5 7/19/2007: Operating System Platform: Win32NT
21:16:14.5 7/19/2007: Operating System Name: Windows XP
21:16:14.5 7/19/2007: Operating System Version: 5.1.2600
21:16:14.5 7/19/2007: Checking for versions of .net Framework installed
21:16:14.5 7/19/2007: .net Framework 1.0 Installed
21:16:14.5 7/19/2007: .net Framework 1.1 Installed
21:16:14.5 7/19/2007: .net Framework 2.0 Installed
21:16:14.5 7/19/2007: Intel® Pentium® 4 CPU 2.80GHz
21:16:14.5 7/19/2007: 2.8Ghz - 2 Cores or CPU's
21:16:14.5 7/19/2007: Running Randomize()
21:16:14.5 7/19/2007: Loading PlugIns
21:16:14.6 7/19/2007: Loaded Plugin:"Exit GameEx" Version 1.0 By Ben Baker
21:16:14.7 7/19/2007: PlugIn: "Exit GameEx" Initialized OK
21:16:14.8 7/19/2007: Loaded Plugin:"Speak Game Name" Version 1.4 By Tom Speirs
21:16:14.8 7/19/2007: PlugIn: "Speak Game Name" Initialized OK
21:16:14.8 7/19/2007: Checking for applications to Launch On Startup
21:16:14.8 7/19/2007: Running Misc startup tasks
21:16:14.8 7/19/2007: Setting Menu types
21:16:14.8 7/19/2007: Opening Configuration File
21:16:14.8 7/19/2007: Getting Configuration Values
21:16:14.8 7/19/2007: Using Theme: Default - Valhalla Default 1024x768
21:16:14.8 7/19/2007: Checking for alternate Image Directory for Theme: Default - Valhalla Default 1024x768
21:16:14.8 7/19/2007: Launching HideOS.exe
21:16:14.8 7/19/2007: Initialising Video/MNG DLL's
21:16:14.8 7/19/2007: Hiding Taskbar
21:16:14.8 7/19/2007: Using Cabinet Friendly Control System
21:16:14.8 7/19/2007: Is Media Center running?
21:16:14.8 7/19/2007: Checking/Creating LCD Registry values
21:16:14.8 7/19/2007: Check Media Center Exit/Start Mode
21:16:14.8 7/19/2007: Media Center Mode 0
21:16:14.8 7/19/2007: Video previews on. Warning: Only recommended on modern systems
21:16:14.8 7/19/2007: Snap Delay set to: 6
21:16:14.8 7/19/2007: Get other settings
21:16:14.9 7/19/2007: Desktop set to Hide ICONS and set Background to Black
21:16:14.9 7/19/2007: Backing up Registry Wallpaper Settings
21:16:14.9 7/19/2007: Set: Find emulator artwork on best match basis
21:16:14.9 7/19/2007: SlikStik support enabled
21:16:14.9 7/19/2007: Using DirectInput for keyboard input
21:16:14.9 7/19/2007: Start work for Form
21:16:14.9 7/19/2007: Getting Original Screen Size
21:16:14.9 7/19/2007: Opening Database Connection
21:16:15.0 7/19/2007: Initializing Component
21:16:15.1 7/19/2007: Retrieving resolution setting
21:16:15.1 7/19/2007: Creating Radio Station Genres
21:16:15.3 7/19/2007: Succesfully created station genres
21:16:15.3 7/19/2007: Initialising Windows Media Player Component
21:16:15.4 7/19/2007: MAME Path is: D:\mame 1.00\Mame 100.4\Mame32
21:16:15.4 7/19/2007: daphne Path is: C:\Daphne
21:16:15.4 7/19/2007: daphne EXE file is: Daphne.exe
21:16:15.4 7/19/2007: Use daphne on. Daphne.exe will launch games
21:16:15.4 7/19/2007: Model 2 Path Path is: C:\Model2v0.1\autorun
21:16:15.4 7/19/2007: Model 2 EXE file is: emulator.exe
21:16:15.4 7/19/2007: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
21:16:15.4 7/19/2007: ZiNc Path is: C:\Zinc_v1.1\
21:16:15.4 7/19/2007: ZiNc EXE file is: ZiNc.exe
21:16:15.4 7/19/2007: Use ZiNc on. ZiNc.exe will launch PSX games
21:16:15.4 7/19/2007: MAME EXE file is: Mame32.exe
21:16:15.4 7/19/2007: ROM Path is: D:\mame 1.00\Mame 100.4\Mame32\roms
21:16:15.4 7/19/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
21:16:15.4 7/19/2007: controls.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\controls.ini
21:16:15.4 7/19/2007: History.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\history.dat
21:16:15.4 7/19/2007: nplayers.ini is located at: D:\mame 1.00\Mame 100.4\Mame32\nplayers32.txt
21:16:15.4 7/19/2007: MAMEinfo.dat is located at: D:\mame 1.00\Mame 100.4\Mame32\mameinfo.dat
21:16:15.4 7/19/2007: Loading Controls.ini map file
21:16:15.4 7/19/2007: Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\snap
21:16:15.4 7/19/2007: AVI Snap Path is: D:\mame 1.00\Mame 100.4\Mame32\video
21:16:15.4 7/19/2007: Flyer Path is: D:\mame 1.00\Mame 100.4\Mame32\flyers
21:16:15.4 7/19/2007: Cabinet Path is: D:\mame 1.00\Mame 100.4\Mame32\cabinets
21:16:15.4 7/19/2007: Title Path is: D:\mame 1.00\Mame 100.4\Mame32\titles
21:16:15.4 7/19/2007: Panel Path is: D:\mame 1.00\Mame 100.4\Mame32\cpanel
21:16:15.4 7/19/2007: Manual Path: Not Found
21:16:15.4 7/19/2007: Icon Path is: D:\mame 1.00\Mame 100.4\Mame32\icons
21:16:15.4 7/19/2007: Marquee Path is: D:\mame 1.00\Mame 100.4\Mame32\marquees
21:16:15.4 7/19/2007: Loading Custom Emulators
21:16:15.4 7/19/2007: Loading Emulator 1: MAME MisFit
21:16:15.5 7/19/2007: Loading Emulator 2: Nintendo SNES
21:16:15.5 7/19/2007: Loading Emulator 3: Pinball (Visual Pinball)
21:16:15.6 7/19/2007: Loading Emulator 4: Nintendo NES
21:16:15.6 7/19/2007: Loading Emulator 5: Atari 2600
21:16:15.7 7/19/2007: Loading Emulator 6: Coleco Vision
21:16:15.7 7/19/2007: Loading Emulator 7: Sega Genesis
21:16:15.7 7/19/2007: Loading Emulator 8: Intellivision Games
21:16:15.8 7/19/2007: Loading Emulator 10: Nintendo 64
21:16:15.9 7/19/2007: Loading Emulator 11: Atari 7800
21:16:15.9 7/19/2007: Loading Emulator 12: NEC TurboGrafx 16
21:16:16.0 7/19/2007: Loading Emulator 13: Nintendo Virtual Boy (Reality Boy)
21:16:16.1 7/19/2007: Using 3D Alpha Blended Animations. This could be slow
21:16:16.1 7/19/2007: Using General Font: Trebuchet MS
21:16:16.1 7/19/2007: Using Title Font: Trebuchet MS
21:16:16.1 7/19/2007: MAME CMD options: -nowindow -joy
21:16:16.1 7/19/2007: Attempting to load game list
21:16:16.3 7/19/2007: Initialising DirectDraw
21:16:16.3 7/19/2007: Creating DirectDraw Device
21:16:16.3 7/19/2007: Using Device: Ultimarc ArcadeVGA2
21:16:16.3 7/19/2007: 133mb video memory available
21:16:16.7 7/19/2007: Setting Resolution to 800x600 32 bit color
21:16:16.7 7/19/2007: Creating DirectDraw Surfaces
21:16:16.7 7/19/2007: Creating Primary Surface - Full Screen Mode
21:16:16.7 7/19/2007: Creating Back Buffer
21:16:16.7 7/19/2007: Version 2 Theme being used. Loading.
21:16:16.7 7/19/2007: Loading Button Data
21:16:16.7 7/19/2007: Loading Font Data
21:16:16.7 7/19/2007: Loading Layout Data
21:16:16.8 7/19/2007: Loading Taskbar Data
21:16:16.8 7/19/2007: Loading graphic Surfaces
21:16:16.8 7/19/2007: Creating Surfaces Misc and Dialogs
21:16:16.9 7/19/2007: Creating Surfaces Volume
21:16:16.9 7/19/2007: Creating Surfaces Arrows
21:16:16.9 7/19/2007: Creating Surfaces GameEXlogo Text
21:16:16.9 7/19/2007: Creating Surfaces Toolbar
21:16:17.0 7/19/2007: Creating Surfaces Backgrounds
21:16:17.2 7/19/2007: Creating Surfaces Toolbar Controls
21:16:17.2 7/19/2007: Creating Surfaces GameEx Logo
21:16:17.3 7/19/2007: Creating Surfaces Home & Exit
21:16:17.3 7/19/2007: Creating Surfaces Snaps
21:16:17.3 7/19/2007: Creating Surfaces Menu and List Bars
21:16:17.4 7/19/2007: Creating Fonts
21:16:17.4 7/19/2007: Creating Menu Font
21:16:17.4 7/19/2007: Restoring Menu Font From Cache
21:16:17.5 7/19/2007: Creating Game Font
21:16:17.6 7/19/2007: Creating Font Black
21:16:17.7 7/19/2007: Creating Font Black Small
21:16:17.8 7/19/2007: Creating Game Font Faded
21:16:17.9 7/19/2007: Creating Title Font
21:16:18.4 7/19/2007: Fonts Created Succesfully
21:16:18.4 7/19/2007: 109mb video memory left available
21:16:18.4 7/19/2007: Creating instance of global keyboard hook
21:16:18.4 7/19/2007: Text/Language: English
21:16:18.4 7/19/2007: Applying Language/Text
21:16:18.4 7/19/2007: Initialising Bass Audio Library
21:16:18.7 7/19/2007: Loading last used Game List
21:16:18.7 7/19/2007: Setting Music Volume
21:16:18.7 7/19/2007: Loading music on thread
21:16:18.7 7/19/2007: Creating DirectSound Device
21:16:18.7 7/19/2007: Trying: Primary Sound Driver
21:16:18.7 7/19/2007: Loading Sound Files
21:16:18.7 7/19/2007: DirectSound Device Created Successfully
21:16:18.7 7/19/2007: Creating ICONS
21:16:18.8 7/19/2007: Restoring Cached ICONS from File
21:16:19.1 7/19/2007: Initialising DirectInput for Gamepad support
21:16:19.1 7/19/2007: Unable to create a joystick device
21:16:19.1 7/19/2007: Initialising DirectInput for Keyboard support
21:16:19.2 7/19/2007: Playing Startup Video
21:16:50.1 7/19/2007: Playing intro sound file
21:16:50.1 7/19/2007: Initializing MCE Remote
21:16:50.1 7/19/2007: Initialization OK! Starting GameEx!
21:16:50.1 7/19/2007: Testing Main Loop Once: Processing Frame
21:16:51.0 7/19/2007: Testing Main Loop Once: Main Loop ran successfully
21:17:23.7 7/19/2007: Exiting GameEx!
21:17:23.7 7/19/2007: Saving Settings
21:17:25.3 7/19/2007: Disposing Plugins
21:17:25.3 7/19/2007: Closing database connection
21:17:25.3 7/19/2007: Checking for applications to Launch On Exit
Nice system slilkstic/Ultimarc ArcadeVGA2
This is what points to me first.
1) First there is the fact Valhalla theme is 1024 by 768. You can look at the top of the log.
2)Then toward the bottom you see this Device: Ultimarc ArcadeVGA2
This is probably the culprit... Change the theme to one that is 800x600 and SEE if it works.
I'am not thinking you changed your hardware config.. Tom has recently changed the way gameex changes resolutions to be more accurate especially when going from one emu to the next..
Anyways let me know if that works and we will go from there.
Within the Vahalla theme there is a config file that sets it to 800 X600,,,,granteed the theme is named diffrently. Theme has been set using this config file to the 800 X 600. I will change it for kicks...nope same thing menu do not display untill fire buttons are hit on controller one and then mini me menu appear.
It is something happening in the menu windowing and transition not sure how else to explain it.
Bummer..It sounded resonable..
Too bad i dont have one of those to help troubleshoot.. I just use svideo out from my geforce into my tv @800x600 I havent had any problems tho... :huh:
Guys...did a windows rollback to a working version and menus camu up fine as they should in gamex...when I accpeted the latest update..gamex came back in with the screen tillted the wrong way I corrected it and the menu was blank as in the attached picture after clicking on the screen a minuture menu appears in the middle.
Not sure what is going on but I think something in one of the latest release is not interacting correctly with myy system any ideas on how to track it down?
Don't know if this will help or not but restore point was as of last Sunday night...CP
Is it only this theme that has the problem?
Try deleting all the cached bitmaps from the data directory.
Also, can you post your gameex.ini file so I can try and duplicate the poblem.
Can you try turning off the 3D transitions.
Tom:
must be something in that vicinty. I could now see the clock and graphics for the game titles but they were way off center on the screen all the way to the right and nothing else was on the screen. Still not working correctly though
Tom:
Can you replace GameEx.exe with the attached. Launch and post the log.
Thanks.
GameEx.zip
No luck here is the log.
Thank you
As I suspected I can see the problem. Its an issue with ArcadeVGA cards. The other post in the forum with the same issue is also running an ArcadeVGA card.
i expect its buggy drivers, but the card is reporting that its running at a refresh rate of 200hz!!!
I can patch this in GameEx easily, and will do so now, but do you want to try and see if you can get newer drivers from Ultimarc?
Checked Ultimarc's or Andy's site there are no new drivers at this point for the card> If I am not mistaken he has a special driver he has written. I will take parts of this string and e-mail Andy. He has always been very helpful in the past had both his cards and other products...just great stuff in general.
Thanks,
Geoff
Thanks,
Geoff
I agree completely. Its probably just a small driver bug.
Heres the specifics:
DirectDraw Display mode is reporting a refresh rate of 200hz.
(Im uploading the release with the patch now)
