This is not a specific GameEx question, but I thought I'd post it here...
I am trying to run the Galaga ROM.
The game was not recognized in GameEx so I tried to run directly in MAME (Command Line and WIndows)
I ams using MAME 0.117 and continually get a missing file error like the following:
C:\MAME>mame galaga
gg1-1b.3p NOT FOUND
gg1-2b.3m NOT FOUND
gg1-4b.2l NOT FOUND
gg1-5b.3f NOT FOUND
gg1-7b.2c NOT FOUND
54xx.bin NOT FOUND
prom-4.2n NOT FOUND
prom-3.1c NOT FOUND
prom-1.1d NOT FOUND
prom-2.5c NOT FOUND
ERROR: required files are missing, the game cannot be run.
I've downloaded the ROM from a number of different sites and also tried numerous versions (Midway, Namco, etc)
I understand that MAME dictates the expected contents of the ROMS (which is listed above), but the downloaded ZIP files contain this:
04d_g06.bin
04e_g05.bin
04h_g04.bin
04j_g03.bin
04k_g02.bin
04m_g01.bin
07e_g10.bin
07h_g09.bin
07m_g08.bin
1c.bin
1d.bin
2n.bin
5c.bin
5n.bin
Does anyone know what the issue is here? Is this a newer version of the ROM being published? Is MAME's database wrong?
I've experienced this type of issue with other ROMS, but I coould always seem to locate a working version somewhere...
C:\MAME>mame galaga
gg1-1b.3p NOT FOUND
gg1-2b.3m NOT FOUND
gg1-4b.2l NOT FOUND
gg1-5b.3f NOT FOUND
gg1-7b.2c NOT FOUND
54xx.bin NOT FOUND
prom-4.2n NOT FOUND
prom-3.1c NOT FOUND
prom-1.1d NOT FOUND
prom-2.5c NOT FOUND
the one i have contains those files there you sure its not an old rom dump becouse many roms gets redumped over time....
tho im not the expect just a thought :)
Night
you have two problems..
1. Your romset is incorrect. Use CLRMAME to audit it... Read how to use it first.
2. gallaga is an IMPERFECT game.. It has wrong colors and by default gameex will filter out imperfect games..Add it to the donot filter list..Update game list and It should be selectable.
Thanks - that did it!
