I just bought a new 500gb External drive I am going to dump my entire arcade collection on there. My question is can I install GAMMEX on this external drive, then bring it over to a friends house and boot gameex and my games up from his PC or is there going to be an issue with windows registry etc. I dont want to set up all these directories and such in gameex to find its not going to work.
Sorry it will not work....
However Copy the intstaller to it as well. Once its all setup copy the gameex directory from the program files folder the the external drive..
When you get to your friends install GE (let it create all the reg keys and associations) then over write the gameex folder. Now you will have all your configs. ^_^
This is the easy way and might promote your friend to register the program for them selves
Ok, Yea it wasn't about the register thing I was trying to bypass it was just the reconfiguring of it all. I want to just pop and play. Well If I can just copy my installed gameex directory over the fresh install and it will know my paths which I can just
set in Control Panel- admin- computer managemnt then that sounds easy enough to me. thanks
