A couple of updates ago a bug was introduced that GameEx interface looks a little stretched out of screen and much brighter when I am back from MAME (not always, but most of the time). This only happened after a bug was fixed when I'd come back from CPS3 games (on mame) and gameex used to crash with a directx error (that was reported to Tom using that Log screen).
After I exit GameEx, it goes back to the right resoltuoin.
I'm using Vista Ultimate, my video card is a GeForce 5200 and I'm using a LG 1080i LCD tv as output. The resolution I'm using is 1360x768 32bits.
If I could only check what resolution gameex comes back to...
Btw, thanks for this great software and all the updates! :lol:
Could you post your log after this happens please.
Also, this is most likely a Vista issue, I get all kinds of video issues. Are you using the latest nvidia drivers?
Something that might help, is telling GameEx not to set the resolution under display settings in advanced configuration.
I am not using the latest drivers, I'll update now. But it was working before a couple of GameEx updates with these drivers.
Here is a log for opening 19xx, waiting a few seconds, and pressing back on my remote to come back to GameEx. It has worked, but the resolution was wrong.
When I was trying to reproduce that I found another bug which I had forgot. If I get into a game with my xbox 360 wireless controller turned OFF and quit MAME using the remote's back button, GameEx won't recognize I've quit MAME.
I use my Hauppauge PVR-150 remote's back button to quit mame and go back to GameEx. I'm not sure if it has been that way before or if this was introduced in the latest mame/gameex update.
I've included both logs here, but I'm not sure they have any useful information...
Wrong resolution:
1:06:26.8 18/07/2007: GameEx: Version 8.53: Starting Log
11:06:26.8 18/07/2007: Operating System Platform: Win32NT
11:06:26.8 18/07/2007: Operating System Name: Windows Vista
11:06:26.8 18/07/2007: Operating System Version: 6.0.6000
11:06:26.8 18/07/2007: Vista Aero NOT running
11:06:26.8 18/07/2007: Initializing Vista volume control
11:06:26.9 18/07/2007: Checking for versions of .net Framework installed
11:06:26.9 18/07/2007: .net Framework 2.0 Installed
11:06:26.9 18/07/2007: AMD Athlon 64 Processor 3000+
11:06:26.9 18/07/2007: 1,8Ghz
11:06:27.0 18/07/2007: Running Randomize()
11:06:27.0 18/07/2007: Loading PlugIns
11:06:27.0 18/07/2007: Checking for applications to Launch On Startup
11:06:27.0 18/07/2007: Running Misc startup tasks
11:06:27.0 18/07/2007: Setting Menu types
11:06:27.0 18/07/2007: Opening Configuration File
11:06:27.0 18/07/2007: Getting Configuration Values
11:06:27.0 18/07/2007: Using Theme: Default - Media Center
11:06:27.0 18/07/2007: Checking for alternate Image Directory for Theme: Default - Media Center
11:06:27.0 18/07/2007: Launching HideOS.exe
11:06:27.0 18/07/2007: Initialising Video/MNG DLL's
11:06:27.0 18/07/2007: Hiding Taskbar
11:06:27.0 18/07/2007: Is Media Center running?
11:06:27.0 18/07/2007: Checking/Creating LCD Registry values
11:06:27.0 18/07/2007: Check Media Center Exit/Start Mode
11:06:27.0 18/07/2007: Media Center Mode 2
11:06:27.0 18/07/2007: Video previews on. Warning: Only recommended on modern systems
11:06:27.1 18/07/2007: Snap Delay set to: 2
11:06:27.1 18/07/2007: Get other settings
11:06:27.1 18/07/2007: Set: Find emulator artwork on best match basis
11:06:27.1 18/07/2007: Start work for Form
11:06:27.1 18/07/2007: Getting Original Screen Size
11:06:27.2 18/07/2007: Compacting Database
11:06:27.7 18/07/2007: Opening Database Connection
11:06:27.7 18/07/2007: Initializing Component
11:06:27.8 18/07/2007: Retrieving resolution setting
11:06:27.8 18/07/2007: Creating Radio Station Genres
11:06:27.9 18/07/2007: Succesfully created station genres
11:06:27.9 18/07/2007: MAME Path is: C:\Emulators\Mame32
11:06:27.9 18/07/2007: daphne Path is: C:\Emulators\Daphne
11:06:27.9 18/07/2007: daphne EXE file is: Daphne.exe
11:06:27.9 18/07/2007: Use daphne on. Daphne.exe will launch games
11:06:27.9 18/07/2007: MAME EXE file is: mame.exe
11:06:27.9 18/07/2007: ROM Path is: C:\Emulators\ROMs\MAME
11:06:27.9 18/07/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
11:06:27.9 18/07/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
11:06:27.9 18/07/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
11:06:27.9 18/07/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
11:06:27.9 18/07/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
11:06:28.0 18/07/2007: Loading Controls.ini map file
11:06:28.0 18/07/2007: Snap Path: Not Found
11:06:28.0 18/07/2007: AVI Snap Path: Not Found
11:06:28.0 18/07/2007: Flyer Path: Not Found
11:06:28.0 18/07/2007: Cabinet Path: Not Found
11:06:28.0 18/07/2007: Title Path: Not Found
11:06:28.0 18/07/2007: Panel Path: Not Found
11:06:28.0 18/07/2007: Manual Path: Not Found
11:06:28.0 18/07/2007: Icon Path: Not Found
11:06:28.0 18/07/2007: Marquee Path: Not Found
11:06:28.0 18/07/2007: Loading Custom Emulators
11:06:28.0 18/07/2007: Loading Emulator 1: Nintendo N64 (Project 64)
11:06:28.1 18/07/2007: Loading Emulator 2: Nintendo SNES games
11:06:28.2 18/07/2007: Loading Emulator 4: Nintendo NES (NEStopia)
11:06:28.2 18/07/2007: Loading Emulator 8: NEC TurboGrafx 16 (MagicEngine)
11:06:28.3 18/07/2007: Loading Emulator 9: Sony Playstation (ePSXe)
11:06:28.4 18/07/2007: Loading Emulator 11: Sega Genesis (Fusion)
11:06:28.5 18/07/2007: Loading Emulator 12: Atari 2600 (Stella)
11:06:28.9 18/07/2007: Using 2D Animations
11:06:28.9 18/07/2007: Using General Font: Trebuchet MS
11:06:28.9 18/07/2007: Using Title Font: Trebuchet MS
11:06:28.9 18/07/2007: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo
11:06:28.9 18/07/2007: Attempting to load game list
11:06:28.9 18/07/2007: Initialising DirectDraw
11:06:29.0 18/07/2007: Applying GameEx is Loading Image
11:06:29.0 18/07/2007: Creating DirectDraw Device
11:06:29.0 18/07/2007: Using Device: NVIDIA GeForce 6200 TurboCache (Microsoft Corporation - WDDM)
11:06:29.1 18/07/2007: 374mb video memory available
11:06:29.2 18/07/2007: Setting Resolution to 1360x768 32 bit color
11:06:29.2 18/07/2007: Creating DirectDraw Surfaces
11:06:29.2 18/07/2007: Creating Primary Surface - Full Screen Mode
11:06:29.2 18/07/2007: Creating Back Buffer
11:06:29.3 18/07/2007: Loading graphic Surfaces
11:06:29.3 18/07/2007: Creating Surfaces Misc and Dialogs
11:06:29.4 18/07/2007: Creating Surfaces Volume
11:06:29.4 18/07/2007: Creating Surfaces Arrows
11:06:29.4 18/07/2007: Creating Surfaces GameEXlogo Text
11:06:29.4 18/07/2007: Creating Surfaces Toolbar
11:06:29.4 18/07/2007: Creating Surfaces Backgrounds
11:06:29.7 18/07/2007: Creating Surfaces Toolbar Controls
11:06:29.7 18/07/2007: Creating Surfaces GameEx Logo
11:06:29.7 18/07/2007: Creating Surfaces Home & Exit
11:06:29.7 18/07/2007: Creating Surfaces Snaps
11:06:29.7 18/07/2007: Creating Surfaces Menu and List Bars
11:06:29.9 18/07/2007: Creating Fonts
11:06:29.9 18/07/2007: Creating Menu Font
11:06:29.9 18/07/2007: Restoring Menu Font From Cache
11:06:29.9 18/07/2007: Creating Game Font
11:06:30.0 18/07/2007: Creating Font Black
11:06:30.4 18/07/2007: Creating Font Black Small
11:06:30.5 18/07/2007: Creating Game Font Faded
11:06:30.6 18/07/2007: Creating Title Font
11:06:30.6 18/07/2007: Restoring Title Font From Cache
11:06:30.8 18/07/2007: Fonts Created Succesfully
11:06:30.8 18/07/2007: 302mb video memory left available
11:06:30.8 18/07/2007: Creating instance of global keyboard hook
11:06:30.8 18/07/2007: Starting GameExtender Publisher
11:06:31.0 18/07/2007: Text/Language: English
11:06:31.0 18/07/2007: Applying Language/Text
11:06:31.1 18/07/2007: Initialising Bass Audio Library
11:06:31.2 18/07/2007: Loading last used Game List
11:06:31.2 18/07/2007: Setting Music Volume
11:06:31.2 18/07/2007: Cannot Load Play List. Check Path and filename
11:06:31.2 18/07/2007: Creating DirectSound Device
11:06:31.3 18/07/2007: Trying: Primary Sound Driver
11:06:31.3 18/07/2007: Loading Sound Files
11:06:31.3 18/07/2007: DirectSound Device Created Successfully
11:06:31.3 18/07/2007: Initialising DirectInput for Gamepad support
11:06:31.5 18/07/2007: Using Device Controller (Xbox 360 Wireless Receiver for Windows)
11:06:31.6 18/07/2007: Initializing MCE Remote
11:06:31.6 18/07/2007: Initialization OK! Starting GameEx!
11:06:31.6 18/07/2007: Testing Main Loop Once: Processing Frame
11:06:32.1 18/07/2007: Testing Main Loop Once: Main Loop ran successfully
11:06:50.0 18/07/2007: Running: cmd.exe /c C: C:\Emulators\Mame32\mame.exe 19xx -rompath C:\Emulators\ROMs\MAME -triplebuffer -nowindow -joy -skip_gameinfo
11:07:46.4 18/07/2007: Exiting GameEx!
11:07:46.4 18/07/2007: Saving Settings
11:07:49.4 18/07/2007: Disposing Plugins
11:07:49.4 18/07/2007: Closing database connection
11:07:49.4 18/07/2007: Checking for applications to Launch On Exit
11:07:49.4 18/07/2007: Media Center was not open when starting GameEx, so not launching
Log for a time which it would not recognize when I've quit mame. I had to force close GameEx.
10:56:18.7 18/07/2007: GameEx: Version 8.53: Starting Log
10:56:18.7 18/07/2007: Operating System Platform: Win32NT
10:56:18.7 18/07/2007: Operating System Name: Windows Vista
10:56:18.7 18/07/2007: Operating System Version: 6.0.6000
10:56:18.7 18/07/2007: Vista Aero NOT running
10:56:18.7 18/07/2007: Initializing Vista volume control
10:56:18.7 18/07/2007: Checking for versions of .net Framework installed
10:56:18.7 18/07/2007: .net Framework 2.0 Installed
10:56:18.7 18/07/2007: AMD Athlon 64 Processor 3000+
10:56:18.7 18/07/2007: 1,8Ghz
10:56:18.7 18/07/2007: Running Randomize()
10:56:18.7 18/07/2007: Loading PlugIns
10:56:18.7 18/07/2007: Checking for applications to Launch On Startup
10:56:18.8 18/07/2007: Running Misc startup tasks
10:56:18.8 18/07/2007: Setting Menu types
10:56:18.8 18/07/2007: Opening Configuration File
10:56:18.8 18/07/2007: Getting Configuration Values
10:56:18.8 18/07/2007: Using Theme: Default - Media Center
10:56:18.8 18/07/2007: Checking for alternate Image Directory for Theme: Default - Media Center
10:56:18.8 18/07/2007: Launching HideOS.exe
10:56:18.8 18/07/2007: Initialising Video/MNG DLL's
10:56:18.8 18/07/2007: Hiding Taskbar
10:56:18.8 18/07/2007: Is Media Center running?
10:56:18.8 18/07/2007: Checking/Creating LCD Registry values
10:56:18.8 18/07/2007: Check Media Center Exit/Start Mode
10:56:18.8 18/07/2007: Media Center Mode 2
10:56:18.8 18/07/2007: Video previews on. Warning: Only recommended on modern systems
10:56:18.8 18/07/2007: Snap Delay set to: 2
10:56:18.8 18/07/2007: Get other settings
10:56:18.9 18/07/2007: Set: Find emulator artwork on best match basis
10:56:18.9 18/07/2007: Start work for Form
10:56:18.9 18/07/2007: Getting Original Screen Size
10:56:18.9 18/07/2007: Opening Database Connection
10:56:19.1 18/07/2007: Initializing Component
10:56:19.2 18/07/2007: Retrieving resolution setting
10:56:19.2 18/07/2007: Creating Radio Station Genres
10:56:19.3 18/07/2007: Succesfully created station genres
10:56:19.3 18/07/2007: MAME Path is: C:\Emulators\Mame32
10:56:19.4 18/07/2007: daphne Path is: C:\Emulators\Daphne
10:56:19.4 18/07/2007: daphne EXE file is: Daphne.exe
10:56:19.4 18/07/2007: Use daphne on. Daphne.exe will launch games
10:56:19.4 18/07/2007: MAME EXE file is: mame.exe
10:56:19.4 18/07/2007: ROM Path is: C:\Emulators\ROMs\MAME
10:56:19.4 18/07/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
10:56:19.4 18/07/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
10:56:19.4 18/07/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
10:56:19.4 18/07/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
10:56:19.4 18/07/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
10:56:19.4 18/07/2007: Loading Controls.ini map file
10:56:19.4 18/07/2007: Snap Path: Not Found
10:56:19.4 18/07/2007: AVI Snap Path: Not Found
10:56:19.4 18/07/2007: Flyer Path: Not Found
10:56:19.4 18/07/2007: Cabinet Path: Not Found
10:56:19.4 18/07/2007: Title Path: Not Found
10:56:19.4 18/07/2007: Panel Path: Not Found
10:56:19.4 18/07/2007: Manual Path: Not Found
10:56:19.4 18/07/2007: Icon Path: Not Found
10:56:19.4 18/07/2007: Marquee Path: Not Found
10:56:19.5 18/07/2007: Loading Custom Emulators
10:56:19.5 18/07/2007: Loading Emulator 1: Nintendo N64 (Project 64)
10:56:19.6 18/07/2007: Loading Emulator 2: Nintendo SNES games
10:56:19.8 18/07/2007: Loading Emulator 4: Nintendo NES (NEStopia)
10:56:19.8 18/07/2007: Loading Emulator 8: NEC TurboGrafx 16 (MagicEngine)
10:56:19.9 18/07/2007: Loading Emulator 9: Sony Playstation (ePSXe)
10:56:20.0 18/07/2007: Loading Emulator 11: Sega Genesis (Fusion)
10:56:20.0 18/07/2007: Loading Emulator 12: Atari 2600 (Stella)
10:56:20.3 18/07/2007: Using 2D Animations
10:56:20.3 18/07/2007: Using General Font: Trebuchet MS
10:56:20.3 18/07/2007: Using Title Font: Trebuchet MS
10:56:20.3 18/07/2007: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo
10:56:20.3 18/07/2007: Attempting to load game list
10:56:20.3 18/07/2007: Initialising DirectDraw
10:56:20.4 18/07/2007: Applying GameEx is Loading Image
10:56:20.5 18/07/2007: Creating DirectDraw Device
10:56:20.5 18/07/2007: Using Device: NVIDIA GeForce 6200 TurboCache (Microsoft Corporation - WDDM)
10:56:20.5 18/07/2007: 374mb video memory available
10:56:20.7 18/07/2007: Setting Resolution to 1360x768 32 bit color
10:56:20.7 18/07/2007: Creating DirectDraw Surfaces
10:56:20.7 18/07/2007: Creating Primary Surface - Full Screen Mode
10:56:20.7 18/07/2007: Creating Back Buffer
10:56:20.7 18/07/2007: Loading graphic Surfaces
10:56:20.8 18/07/2007: Creating Surfaces Misc and Dialogs
10:56:20.8 18/07/2007: Creating Surfaces Volume
10:56:20.8 18/07/2007: Creating Surfaces Arrows
10:56:20.8 18/07/2007: Creating Surfaces GameEXlogo Text
10:56:20.8 18/07/2007: Creating Surfaces Toolbar
10:56:20.9 18/07/2007: Creating Surfaces Backgrounds
10:56:21.1 18/07/2007: Creating Surfaces Toolbar Controls
10:56:21.1 18/07/2007: Creating Surfaces GameEx Logo
10:56:21.2 18/07/2007: Creating Surfaces Home & Exit
10:56:21.2 18/07/2007: Creating Surfaces Snaps
10:56:21.2 18/07/2007: Creating Surfaces Menu and List Bars
10:56:21.3 18/07/2007: Creating Fonts
10:56:21.3 18/07/2007: Creating Menu Font
10:56:21.3 18/07/2007: Restoring Menu Font From Cache
10:56:21.4 18/07/2007: Creating Game Font
10:56:21.4 18/07/2007: Creating Font Black
10:56:21.6 18/07/2007: Creating Font Black Small
10:56:21.8 18/07/2007: Creating Game Font Faded
10:56:21.8 18/07/2007: Creating Title Font
10:56:21.9 18/07/2007: Restoring Title Font From Cache
10:56:22.0 18/07/2007: Fonts Created Succesfully
10:56:22.0 18/07/2007: 302mb video memory left available
10:56:22.0 18/07/2007: Creating instance of global keyboard hook
10:56:22.1 18/07/2007: Starting GameExtender Publisher
10:56:22.1 18/07/2007: Text/Language: English
10:56:22.1 18/07/2007: Applying Language/Text
10:56:22.2 18/07/2007: Initialising Bass Audio Library
10:56:22.4 18/07/2007: Loading last used Game List
10:56:22.4 18/07/2007: Setting Music Volume
10:56:22.4 18/07/2007: Cannot Load Play List. Check Path and filename
10:56:22.4 18/07/2007: Creating DirectSound Device
10:56:22.4 18/07/2007: Trying: Primary Sound Driver
10:56:22.4 18/07/2007: Loading Sound Files
10:56:22.5 18/07/2007: DirectSound Device Created Successfully
10:56:22.5 18/07/2007: Initialising DirectInput for Gamepad support
10:56:22.7 18/07/2007: Unable to create a joystick device
10:56:22.7 18/07/2007: Initializing MCE Remote
10:56:22.7 18/07/2007: Initialization OK! Starting GameEx!
10:56:22.7 18/07/2007: Testing Main Loop Once: Processing Frame
10:56:23.2 18/07/2007: Testing Main Loop Once: Main Loop ran successfully
10:56:43.3 18/07/2007: Running: cmd.exe /c C: C:\Emulators\Mame32\mame.exe sfiiiu -rompath C:\Emulators\ROMs\MAME -triplebuffer -nowindow -joy -skip_gameinfo
11:03:28.4 18/07/2007: Exiting GameEx!
11:03:28.4 18/07/2007: Saving Settings
11:03:30.0 18/07/2007: Disposing Plugins
11:03:30.0 18/07/2007: Closing database connection
11:03:30.0 18/07/2007: Checking for applications to Launch On Exit
11:03:30.0 18/07/2007: Media Center was not open when starting GameEx, so not launching
Thanks Tom! Are both bugs fixed?
That's one of the reasons I registered this software: great support! :D
I'm going to check the updates when I get home (but get bomberman downloading on live arcade first, but that's a different forum ;) )
I downloaded the latest update pushed and the resolution bug is still there. Now whenever I quit a CPS3 game, even if the controller was connected, it won't go back to GameEx. I had to force quit GameEx after returning from SF3.
Is there anything I could do to help?
09:44:58.7 19/07/2007: GameEx: Version 8.54: Starting Log
09:44:58.7 19/07/2007: Operating System Platform: Win32NT
09:44:58.7 19/07/2007: Operating System Name: Windows Vista
09:44:58.7 19/07/2007: Operating System Version: 6.0.6000
09:44:58.7 19/07/2007: Vista Aero running
09:44:58.7 19/07/2007: Initializing Vista volume control
09:44:58.7 19/07/2007: Checking for versions of .net Framework installed
09:44:58.7 19/07/2007: .net Framework 2.0 Installed
09:44:58.7 19/07/2007: AMD Athlon 64 Processor 3000+
09:44:58.7 19/07/2007: 1,8Ghz
09:44:58.7 19/07/2007: Running Randomize()
09:44:58.7 19/07/2007: Loading PlugIns
09:44:58.7 19/07/2007: Checking for applications to Launch On Startup
09:44:58.7 19/07/2007: Running Misc startup tasks
09:44:58.7 19/07/2007: Setting Menu types
09:44:58.7 19/07/2007: Opening Configuration File
09:44:58.7 19/07/2007: Getting Configuration Values
09:44:58.7 19/07/2007: Using Theme: Default - Media Center
09:44:58.7 19/07/2007: Checking for alternate Image Directory for Theme: Default - Media Center
09:44:58.8 19/07/2007: Launching HideOS.exe
09:44:58.8 19/07/2007: Initialising Video/MNG DLL's
09:44:58.8 19/07/2007: Hiding Taskbar
09:44:58.8 19/07/2007: Is Media Center running?
09:44:58.8 19/07/2007: Media Center is running
09:44:58.8 19/07/2007: Checking/Creating LCD Registry values
09:44:58.8 19/07/2007: Check Media Center Exit/Start Mode
09:44:58.8 19/07/2007: Media Center Mode 2
09:44:58.8 19/07/2007: Closing Media Center
09:44:59.3 19/07/2007: Video previews on. Warning: Only recommended on modern systems
09:44:59.3 19/07/2007: Snap Delay set to: 2
09:44:59.3 19/07/2007: Get other settings
09:44:59.3 19/07/2007: Set: Find emulator artwork on best match basis
09:44:59.3 19/07/2007: Start work for Form
09:44:59.3 19/07/2007: Getting Original Screen Size
09:44:59.3 19/07/2007: Opening Database Connection
09:44:59.4 19/07/2007: Initializing Component
09:44:59.9 19/07/2007: Retrieving resolution setting
09:44:59.9 19/07/2007: Creating Radio Station Genres
09:45:00.1 19/07/2007: Succesfully created station genres
09:45:00.1 19/07/2007: MAME Path is: C:\Emulators\Mame32
09:45:00.1 19/07/2007: daphne Path is: C:\Emulators\Daphne
09:45:00.1 19/07/2007: daphne EXE file is: Daphne.exe
09:45:00.1 19/07/2007: Use daphne on. Daphne.exe will launch games
09:45:00.1 19/07/2007: MAME EXE file is: mame.exe
09:45:00.1 19/07/2007: ROM Path is: C:\Emulators\ROMs\MAME
09:45:00.1 19/07/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
09:45:00.1 19/07/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
09:45:00.1 19/07/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
09:45:00.1 19/07/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
09:45:00.1 19/07/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
09:45:00.2 19/07/2007: Loading Controls.ini map file
09:45:00.2 19/07/2007: Snap Path: Not Found
09:45:00.2 19/07/2007: AVI Snap Path: Not Found
09:45:00.2 19/07/2007: Flyer Path: Not Found
09:45:00.2 19/07/2007: Cabinet Path: Not Found
09:45:00.2 19/07/2007: Title Path: Not Found
09:45:00.2 19/07/2007: Panel Path: Not Found
09:45:00.2 19/07/2007: Manual Path: Not Found
09:45:00.2 19/07/2007: Icon Path: Not Found
09:45:00.2 19/07/2007: Marquee Path: Not Found
09:45:00.3 19/07/2007: Loading Custom Emulators
09:45:00.3 19/07/2007: Loading Emulator 1: Nintendo N64 (Project 64)
09:45:00.4 19/07/2007: Loading Emulator 2: Nintendo SNES games
09:45:00.4 19/07/2007: Loading Emulator 4: Nintendo NES (NEStopia)
09:45:00.5 19/07/2007: Loading Emulator 8: NEC TurboGrafx 16 (MagicEngine)
09:45:00.5 19/07/2007: Loading Emulator 9: Sony Playstation (ePSXe)
09:45:00.6 19/07/2007: Loading Emulator 11: Sega Genesis (Fusion)
09:45:00.6 19/07/2007: Loading Emulator 12: Atari 2600 (Stella)
09:45:00.8 19/07/2007: Using 2D Animations
09:45:00.9 19/07/2007: Using General Font: Trebuchet MS
09:45:00.9 19/07/2007: Using Title Font: Trebuchet MS
09:45:00.9 19/07/2007: MAME CMD options: -triplebuffer -nowindow -joy -skip_gameinfo
09:45:00.9 19/07/2007: Attempting to load game list
09:45:00.9 19/07/2007: Waiting for Media Center to close
09:45:02.0 19/07/2007: Initialising DirectDraw
09:45:02.0 19/07/2007: Applying GameEx is Loading Image
09:45:02.4 19/07/2007: Creating DirectDraw Device
09:45:02.4 19/07/2007: Using Device: NVIDIA GeForce 6200 TurboCache (Microsoft Corporation - WDDM)
09:45:02.5 19/07/2007: 374mb video memory available
09:45:02.8 19/07/2007: Setting Resolution to 1360x768 32 bit color
09:45:02.8 19/07/2007: Creating DirectDraw Surfaces
09:45:02.8 19/07/2007: Creating Primary Surface - Full Screen Mode
09:45:02.9 19/07/2007: Creating Back Buffer
09:45:02.9 19/07/2007: Loading graphic Surfaces
09:45:03.0 19/07/2007: Creating Surfaces Misc and Dialogs
09:45:03.0 19/07/2007: Creating Surfaces Volume
09:45:03.0 19/07/2007: Creating Surfaces Arrows
09:45:03.1 19/07/2007: Creating Surfaces GameEXlogo Text
09:45:03.1 19/07/2007: Creating Surfaces Toolbar
09:45:03.1 19/07/2007: Creating Surfaces Backgrounds
09:45:03.3 19/07/2007: Creating Surfaces Toolbar Controls
09:45:03.3 19/07/2007: Creating Surfaces GameEx Logo
09:45:03.4 19/07/2007: Creating Surfaces Home & Exit
09:45:03.4 19/07/2007: Creating Surfaces Snaps
09:45:03.4 19/07/2007: Creating Surfaces Menu and List Bars
09:45:03.4 19/07/2007: Creating Fonts
09:45:03.4 19/07/2007: Creating Menu Font
09:45:03.5 19/07/2007: Restoring Menu Font From Cache
09:45:03.5 19/07/2007: Creating Game Font
09:45:03.6 19/07/2007: Creating Font Black
09:45:03.8 19/07/2007: Creating Font Black Small
09:45:03.9 19/07/2007: Creating Game Font Faded
09:45:03.9 19/07/2007: Creating Title Font
09:45:04.0 19/07/2007: Restoring Title Font From Cache
09:45:04.1 19/07/2007: Fonts Created Succesfully
09:45:04.1 19/07/2007: 302mb video memory left available
09:45:04.1 19/07/2007: Creating instance of global keyboard hook
09:45:04.1 19/07/2007: Starting GameExtender Publisher
09:45:04.9 19/07/2007: Text/Language: English
09:45:04.9 19/07/2007: Applying Language/Text
09:45:04.9 19/07/2007: Initialising Bass Audio Library
09:45:05.1 19/07/2007: Loading last used Game List
09:45:05.1 19/07/2007: Setting Music Volume
09:45:05.1 19/07/2007: Cannot Load Play List. Check Path and filename
09:45:05.1 19/07/2007: Creating DirectSound Device
09:45:05.1 19/07/2007: Trying: Primary Sound Driver
09:45:05.1 19/07/2007: Loading Sound Files
09:45:05.1 19/07/2007: DirectSound Device Created Successfully
09:45:05.1 19/07/2007: Initialising DirectInput for Gamepad support
09:45:05.3 19/07/2007: Using Device Controller (Xbox 360 Wireless Receiver for Windows)
09:45:05.4 19/07/2007: Initializing MCE Remote
09:45:05.4 19/07/2007: Initialization OK! Starting GameEx!
09:45:05.4 19/07/2007: Testing Main Loop Once: Processing Frame
09:45:05.8 19/07/2007: Testing Main Loop Once: Main Loop ran successfully
09:45:26.2 19/07/2007: Running: cmd.exe /c C: C:\Emulators\Mame32\mame.exe 19xx -rompath C:\Emulators\ROMs\MAME -triplebuffer -nowindow -joy -skip_gameinfo
09:47:18.3 19/07/2007: Running: cmd.exe /c C: C:\Emulators\Mame32\mame.exe sfiiiu -rompath C:\Emulators\ROMs\MAME -triplebuffer -nowindow -joy -skip_gameinfo
09:52:00.6 19/07/2007: Exiting GameEx!
09:52:00.6 19/07/2007: Saving Settings
09:52:02.3 19/07/2007: Disposing Plugins
09:52:02.3 19/07/2007: Closing database connection
09:52:02.3 19/07/2007: Checking for applications to Launch On Exit
09:52:02.3 19/07/2007: Launching Media Center
Yeah, your right. Im looking at it now.
I dont know about the CPS3 issue though. Your log shows gameex exiting cleanly. Can you give a bit more detail around exactly whats happening with that.
That's because I had to force-quit it.
When I exit MAME, it goes back to the Desktop - the task bar is hidden except for the windows logo. GameEx is still running, but won't show up, as if it didn't recognize MAME had already ended. I've tried waiting for a few minutes, but nothing happens, so I hit ctrl+alt+del and choose END TASK on GameEx (which has "Playing:Street Fighter 3...." still in it's title bar). If I try to ALT+TAB to GameEx from the Desktop, it only shows a black screen.
This used to happen only when the controller was not connected, now it happens everytime I try SFIII.
If its only affecting certain MAME games, ie just CPS3 games its nothing to do with GameEx, and not a lot I can do about it. it must be some kind of MAME issue.
Is it only CPS3 or certain games?
I'll try every game again when I get home but, so far, the only one that had this problem is SFIII, but I haven't tested any other CPS3 game.
Btw, when I try it calling mame by the command line, everything goes fine. The issue seems to be GameEx recognizing that MAME has ended.
