I recently updated from GameEx 8.07 (?) to 8.40. And I updated Mame from .94 to 1.17. I had a few little things to fix and all are fine now except I no longer have sound while playing a game. I hear everything fine in GameEx so I assume it's something Mame related. I am attaching my mame.ini file. I can post my GameEx log of whatever if that will help.
I tried changing the "volume" line from 0 to 1 then to 76 (random number) but it didn't help. Was there a change between .94 and 1.17 related to this issue? I follow most of the updates and don't remember sound being listed. Any suggestions on what I need to look for? I've tried pressing = while in a game to increase the volume with no effect either.
Thanks!
ok### mame.ini ###
### Frontend Related ###
clones 1
### Windows path and directory options ###
rompath roms
samplepath samples
# inipath <NULL> (not set)
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
hiscore_directory hi
state_directory sta
artwork_directory artwork
snapshot_directory snap
diff_directory diff
ctrlr_directory ctrlr
cheat_file cheat.dat
history_file history.dat
mameinfo_file mameinfo.dat
### Windows video options ###
autoframeskip 1
frameskip 0
waitvsync 0
triplebuffer 0
window 0
ddraw 1
direct3d 0
hwstretch 1
# screen <NULL> (not set)
cleanstretch auto
resolution auto
refresh 0
scanlines 0
switchres 0k
switchbpp 1
maximize 1
keepaspect 1
matchrefresh 0
syncrefresh 0
throttle 1
full_screen_brightness 0.000000
frames_to_run 0
effect none
screen_aspect 4:3
### Windows Direct3D 2D video options ###
zoom 2
d3dtexmanage 1
d3dfilter 1
d3dfeedback 0
d3dscan 100
d3deffectrotate 1
d3dprescale auto
d3deffect none
# d3dcustom <NULL> (not set)
# d3dexpert <NULL> (not set)
### Windows misc options ###
sleep 1
rdtsc 0
high_priority 0
### Windows sound options ###
audio_latency 1
# wavwrite <NULL> (not set)
### Input device options ###
mouse 1
joystick 1
lightgun 0
dual_lightgun 0
offscreen_reload 0
steadykey 0
keyboard_leds 1
led_mode ps/2
a2d_deadzone 0.300000
# ctrlr <NULL> (not set)
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
digital none
### Mame CORE video options ###
norotate 0
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
debug_resolution auto
gamma 1.000000
brightness 1.000000
pause_brightness 0.650000
### Mame CORE vector game options ###
antialias 1
translucency 1
beam 1.000000
flicker 0.000000
intensity 1.500000
### Mame CORE sound options ###
samplerate 44100
samples 1
resamplefilter 1
sound 1
volume 76
### Mame CORE misc options ###
artwork 1
use_backdrops 1
use_overlays 1
use_bezels 0
artwork_crop 0
artwork_resolution 0
cheat 0
debug 0
# playback <NULL> (not set)
# record <NULL> (not set)
log 0
maxlogsize 10000
oslog 0
skip_disclaimer 1
skip_gameinfo 1
skip_validitychecks 1
crconly 0
bios default
# state <NULL> (not set)
### Configuration options ###
readconfig 1
verbose 0
Before I can help, can you please try GameEx 8.47
Cheers.
Updated again.
And I found MY error and it's my fault. Somehow I changed it the MAME AUDIO MODE to Play MAME with no sound. Sorry for the idiocy on my part.
One question or suggestion. Is it possible to change it so that when using a drop down, the options are fully displayed? On my cabinet, I have a tv so I thought it was just my resolution that prevented me from reading all of the text on a given line. When I installed GameEx on my family pc to read the choices, I realized that I couldn't read it all there either.
Again, sorry for the problems. I should have looked at that before posting.
Thanks for great program.
