Hey guys, things have been amazing over with my new machine. Recently I have had issues with my 3rd player controls, all 4 players work fine but 1 of the buttons on player 3 opens up the control panel display feature. Ive been all over this trying to find how to disable the feature entirely but no luck. I must just be missing something right in front of me.
-Nynja,
-Nynja,
Hi Nynja. You'll need to give more info on your setup for people on the forum to help you (not saying i can by any means but if you be more specific i'm sure someone can help you). You have an arcade cab ? Are you using a keyboard encoder (ipac4) for example ? I think (although i could be wrong 'L' on the keyboard brings up the control panel in MAME). You'll need to find out what keys (on the keyboard) player 3 is mapped to start to solve your problem.
ah yeah its an I pac 4, I think you solved my issue tho.
I think that key is set to L
Ill try remapping it and see if that works
Thanks again!
