A bit help please
Guest Zilverw0lf
Every time i run gameex the nag screen comes up (of course) but then it shutdowns and gets me to donation page and didn't even touch anything anyone got solution?.
Here is the log
16:06:02.2 2007-07-14: GameEx: Version 8.45: Starting Log
16:06:02.2 2007-07-14: Operating System Platform: Win32NT
16:06:02.2 2007-07-14: Operating System Name: Windows XP
16:06:02.2 2007-07-14: Operating System Version: 5.1.2600
16:06:02.2 2007-07-14: Checking for versions of .net Framework installed
16:06:02.2 2007-07-14: .net Framework 1.1 Installed
16:06:02.2 2007-07-14: .net Framework 2.0 Installed
16:06:02.2 2007-07-14: AMD Athlon 64 Processor 3500+
16:06:02.2 2007-07-14: 2,21Ghz
16:06:02.8 2007-07-14: Running Randomize()
16:06:02.9 2007-07-14: Loading PlugIns
16:06:03.1 2007-07-14: Checking for applications to Launch On Startup
16:06:03.1 2007-07-14: Running Misc startup tasks
16:06:03.1 2007-07-14: Setting Menu types
16:06:03.1 2007-07-14: Opening Configuration File
16:06:03.1 2007-07-14: Getting Configuration Values
16:06:03.1 2007-07-14: Using Theme: Default - Dark Gloss
16:06:03.1 2007-07-14: Checking for alternate Image Directory for Theme: Default - Dark Gloss
16:06:03.1 2007-07-14: Initialising Video/MNG DLL's
16:06:03.2 2007-07-14: Is Media Center running?
16:06:03.2 2007-07-14: Checking/Creating LCD Registry values
16:06:03.2 2007-07-14: Check Media Center Exit/Start Mode
16:06:03.2 2007-07-14: Media Center Mode 2
16:06:03.2 2007-07-14: Video previews on. Warning: Only recommended on modern systems
16:06:03.2 2007-07-14: Snap Delay set to: 2
16:06:03.2 2007-07-14: Get other settings
16:06:03.2 2007-07-14: Set: Find emulator artwork on best match basis
16:06:03.2 2007-07-14: Start work for Form
16:06:03.2 2007-07-14: Getting Original Screen Size
16:06:03.4 2007-07-14: Opening Database Connection
16:06:06.8 2007-07-14: Initializing Component
16:06:07.7 2007-07-14: Retrieving resolution setting
16:06:07.7 2007-07-14: MAME Path is: C:\Emulators\Mame32
16:06:07.8 2007-07-14: Cannot Find MAME Path: MAME Disabled
16:06:07.9 2007-07-14: Loading Controls.ini map file
16:06:07.9 2007-07-14: Loading Custom Emulators
16:06:08.0 2007-07-14: Loading Emulator 10: Nintendo SNES (ZSNES)
16:06:08.1 2007-07-14: Using 2D Animations
16:06:08.1 2007-07-14: Using General Font: Trebuchet MS
16:06:08.1 2007-07-14: Using Title Font: Trebuchet MS
16:06:08.1 2007-07-14: MAME CMD options: -triplebuffer -nowindow -joy
16:06:08.1 2007-07-14: Initialising DirectDraw
16:06:08.5 2007-07-14: Creating DirectDraw Device
16:06:08.5 2007-07-14: Using Device: RADEON X700 SE
16:06:08.6 2007-07-14: 501mb video memory available
16:06:08.8 2007-07-14: Creating DirectDraw Surfaces
16:06:08.8 2007-07-14: Creating Primary Surface - Windowed Mode
16:06:08.8 2007-07-14: Creating Back Buffer
16:06:08.9 2007-07-14: Loading graphic Surfaces
16:06:09.0 2007-07-14: Creating Surfaces Misc and Dialogs
16:06:09.2 2007-07-14: Creating Surfaces Volume
16:06:09.2 2007-07-14: Creating Surfaces Arrows
16:06:09.3 2007-07-14: Creating Surfaces GameEXlogo Text
16:06:09.3 2007-07-14: Creating Surfaces Toolbar
16:06:09.4 2007-07-14: Creating Surfaces Backgrounds
16:06:11.2 2007-07-14: Creating Surfaces Toolbar Controls
16:06:11.2 2007-07-14: Creating Surfaces GameEx Logo
16:06:11.3 2007-07-14: Creating Surfaces Home & Exit
16:06:11.3 2007-07-14: Creating Surfaces Snaps
16:06:11.3 2007-07-14: Creating Surfaces Menu and List Bars
16:06:11.5 2007-07-14: Creating Fonts
16:06:11.5 2007-07-14: Creating Menu Font
16:06:11.6 2007-07-14: Restoring Menu Font From Cache
16:06:12.1 2007-07-14: Creating Game Font
16:06:12.2 2007-07-14: Creating Font Black
16:06:12.3 2007-07-14: Creating Font Black Small
16:06:12.4 2007-07-14: Creating Game Font Faded
16:06:12.4 2007-07-14: Creating Title Font
16:06:12.5 2007-07-14: Restoring Title Font From Cache
16:06:13.2 2007-07-14: Fonts Created Succesfully
16:06:13.2 2007-07-14: 466mb video memory left available
16:06:13.2 2007-07-14: Creating instance of global keyboard hook
16:06:14.2 2007-07-14: Initialization OK! Starting GameEx!
16:06:14.2 2007-07-14: Exiting GameEx!
16:06:14.2 2007-07-14: Saving Settings
16:06:14.4 2007-07-14: Disposing Plugins
16:06:14.5 2007-07-14: Closing database connection
16:06:14.6 2007-07-14: Checking for applications to Launch On Exit
This happened to me twice in the past...no clue what was the problem then...however I'm registered...and don't have a virtual PC setup to test.
My best guess is that somehow the install got damaged, so try downloading and rerunning the setup once again to see if the issue clears.
Oh next time use a more descriptive topic title, it will generally get you better and more direct help from those that may have experienced the same issue in the past.
Guest Zilverw0lf
Ok so i tried redownload it and reinstalling it but it's still the same :( .
Any chance you have a sticky button. I remember one thread a while back where a button was stuck, so it was going to the donation page on startup...
Guest Zilverw0lf
Well i tried pull on the "1" and "2" key but it's still the same damnit =/
Whether they seem stuck on not, windows is detecting either 1 or 2 being pressed. If your using a cab (which would be useful if you told us) check your wiring, if your using wireless keyboard or mouse they could interfere.
End of the day Windows (not GameEx) thinks 1 or 2 is pressed.
If you seriously want help, then provide some more detail about what you got setup there.
Thanks,
Tom.
Guest Zilverw0lf
Ok well i don't know what a cab is but neither my mouse or keyboard are wireless and i actually was so desperate that i pulled out that keyboard but it's still not working.
A cab refers to an arcade cabinet. Many of us have a computer installed in one, but not everyone. If you are using a keyboard, then the only reason GameEx SHOULD go to the donation page is if a button is pressed. The most likely cause is a stuck key. An easy way to check for this is just open notepad and see if anything gets typed on the screen.
Guest Zilverw0lf
Haha this is funny i used charprobe to see what key being pressed and none got pressed but then i kept it running and started gameex and then it shows me the number 1 key was pressed this is so strange. Lol this is even more wierd i used a key remapper to disable the key but its still going to donation page and the key still gets pressed oh my god.
Well then I suggest that you just donate..Its obvious your PC wants you too.. :lol:
This is really too funny. Maybe Tom has a since of humor :blink: Just kidding..The free version doesn't harass you that much.
Have you tried updating to the latest and greatest version yet?
To be honest, I'm finding this thread a little funny:) Its a strange one alright!
If your tying to get a free license, its an inventive way of doing it. Better than the begging emails I sometimes get :)
Seriously, Im sorry your having problems, but I have nothing else to suggest for now.
Guest Zilverw0lf
Yeah i got the newest version :P no im not trying to get free license :lol: this nag realy annoys me i bet the programming code looks like
Starting gameex.exe
Force to press button1
Succeed
well i guess my computer is really fucked up then :( .
Starting gameex.exe
Succeed
Well Since you don have an IPAC or some other hand wired setup.
Have you tried starting gameex and unpluging the keyboard..just for fun
And Iam pretty sure the code is
Launching gamex.exe
Looking for reg file....not found
Loading Nag screen......Username is Zilverw0lf adding an additional 10 sec....
Zilverw0lf appears to have deep pockets....Bringing up donate page..
Gameex is now scanning through your wallet for your CC info....PLEASE WAIT....Wallet not found
Gameex crash....
Launching gamex.exe
Gameex crash....
ROFLMA!
...And Iam pretty sure the code is
Launching gamex.exe
Gameex crash....
Must be one o them there private beta build things there...
Yea sorry bout that.....
:D
