im getting this in error
22:53:11.9 7/12/2007: GameEx: Version 8.20: Starting Log
22:53:12.0 7/12/2007: Operating System Platform: Win32NT
22:53:12.0 7/12/2007: Operating System Name: Windows XP
22:53:12.0 7/12/2007: Operating System Version: 5.1.2600
22:53:12.0 7/12/2007: Checking for versions of .net Framework installed
22:53:12.0 7/12/2007: .net Framework 1.1 Installed
22:53:12.0 7/12/2007: .net Framework 2.0 Installed
22:53:12.0 7/12/2007: Intel® Pentium® 4 CPU 3.20GHz
22:53:12.0 7/12/2007: 3.19Ghz - 2 Cores or CPU's
22:53:12.0 7/12/2007: Running Randomize()
22:53:12.0 7/12/2007: Loading PlugIns
22:53:12.0 7/12/2007: Checking for applications to Launch On Startup
22:53:12.0 7/12/2007: Running Misc startup tasks
22:53:12.0 7/12/2007: Setting Menu types
22:53:12.1 7/12/2007: Opening Configuration File
22:53:12.1 7/12/2007: Getting Configuration Values
22:53:12.1 7/12/2007: Using Theme: Default - Soul Calibur
22:53:12.1 7/12/2007: Checking for alternate Image Directory for Theme: Default - Soul Calibur
22:53:12.1 7/12/2007: Launching HideOS.exe
22:53:12.1 7/12/2007: Initialising Video/MNG DLL's
22:53:12.1 7/12/2007: Hiding Taskbar
22:53:12.1 7/12/2007: Is Media Center running?
22:53:12.2 7/12/2007: Checking/Creating LCD Registry values
22:53:12.2 7/12/2007: Check Media Center Exit/Start Mode
22:53:12.2 7/12/2007: Media Center Mode 2
22:53:12.2 7/12/2007: Video previews on. Warning: Only recommended on modern systems
22:53:12.2 7/12/2007: Snap Delay set to: 2
22:53:12.2 7/12/2007: Get other settings
22:53:12.3 7/12/2007: Set: Find emulator artwork on best match basis
22:53:12.3 7/12/2007: Start work for Form
22:53:12.3 7/12/2007: Getting Original Screen Size
22:53:12.3 7/12/2007: Opening Database Connection
22:53:12.4 7/12/2007: Initializing Component
22:53:12.5 7/12/2007: Initialising Windows Media Player Component
22:53:12.5 7/12/2007: MAME Path is: C:\Emulators\Mame32
22:53:12.5 7/12/2007: MAME EXE file is: Mame32.exe
22:53:12.6 7/12/2007: ROM Path is: C:\Emulators\Mame32\roms
22:53:12.6 7/12/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
22:53:12.6 7/12/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
22:53:12.6 7/12/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
22:53:12.6 7/12/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
22:53:12.6 7/12/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
22:53:12.6 7/12/2007: Loading Controls.ini map file
22:53:12.6 7/12/2007: Snap Path is: C:\Emulators\Mame32\snap
22:53:12.6 7/12/2007: AVI Snap Path is: C:\Emulators\Mame32\avisnap
22:53:12.7 7/12/2007: Flyer Path is: C:\Emulators\Mame32\flyers
22:53:12.7 7/12/2007: Cabinet Path is: C:\Emulators\Mame32\cabinets
22:53:12.7 7/12/2007: Title Path is: C:\Emulators\Mame32\titles
22:53:12.7 7/12/2007: Panel Path is: C:\Emulators\Mame32\cpanel
22:53:12.7 7/12/2007: Manual Path: Not Found
22:53:12.7 7/12/2007: Icon Path is: C:\Emulators\Mame32\icons
22:53:12.7 7/12/2007: Marquee Path is: C:\Emulators\Mame32\marquees
22:53:12.7 7/12/2007: Loading Custom Emulators
22:53:12.7 7/12/2007: Loading Emulator 1: Nintendo 64 Games
22:53:12.8 7/12/2007: Error: Emulator_1: WorkingPath Does Not Exist
22:53:12.8 7/12/2007: --Please correct the error above for this emulator or disable the emulator.
22:53:12.8 7/12/2007: ---------------------------------
22:53:12.8 7/12/2007: Error: Procedure call or argument is not valid.
22:53:12.8 7/12/2007: at Microsoft.VisualBasic.ErrObject.Raise(Int32 Number, Object Source, Object Description, Object HelpFile, Object HelpContext)
22:53:12.8 7/12/2007: at GameEx.GameEx.mainform.InitialEmuLoad()
22:53:12.8 7/12/2007: at GameEx.GameEx.mainform.ig(Boolean reinit, String ctheme, Boolean nohideos)
22:53:12.8 7/12/2007: at GameEx.GameEx.mainform..ctor()
22:53:12.8 7/12/2007: Closing database connection
22:53:12.9 7/12/2007: GameEx is exiting with errors
22:53:14.0 7/12/2007: ERRORS DETECTED: EXITING
dont understand what it means please email me [email protected] for info windows xp pt 4 3.0 ghz on bored video card thanks 502 ram
It's complaining that the path you specified for emulator 1 is invalid. That path needs to be corrected or emulator 1 needs to be disabled.
