Hello all.
I just recently started using GameEx (awesome so far). Only problem which I couldnt find by a search in the forums here is that when I set up the PC Games in advanced settings. I leave everything default except to enable it, and then I change the directory of the *.lnk files (or rom location). This directory I have set up as c:\games\pc
Once I set that, and run gameex it crashes. If I disable the PC Apps load in advanced settings all is fine.
I do have the above mentioned directory and I have several shortcuts in it to games. Any idea why this would be causing crash?
Attached is my log file.
Any help would be gratly appreciated. Thanks!
---Edit---
So I found this users great database of PC games http://www.gameex.info/forums/index.php?sh...amp;#entry23195
So that solved this problem. Though i had another q I posed in the above thread linked. =)
