Hi. This issue was brought up before. Tom said he'd have a look at it but it may have slipped his mind (i hope so cos i don't want to sound like i'm nagging). The problem seems to be if your playing a playlist in jukebox and exit jukebox (playlist still playing) and go to emulators (or pc game setup as an emulator) and run the emulator and later exit it - the playlist instead of playing where it left off it goes to the start of the next track in the playlist. This happens when you have the audio option 'Pause Playlist And Run MAME' selected. I'm making the assumption that the audio options apply to emulators as well as MAME.
Thanks again,
iano.
Previous post: http://www.gameex.info/forums/index.php?showtopic=3808
Thanks again,
iano.
Although not ideal. Its working exactly how I meant it to. So its not a bug as such. The MAME audio is unrelated. There are seperate setting for playing the jukebox for each emulator config. I will look at it, but its not high priority for me for now. Sorry.
Wow that was quick ! Just thought for once i'd found a genuine bug and wanted to report it (didn't know about the separate audio settings for emulators - will have a look at them). No worries. Thanks for looking it into it (another good reason for donating). Carlsberg don't do Frontends but if they did, it would be ....
Thanks.
:D
