Hi all, I have two questions about GameEx:
1-Is there any way to configure GameEx to start up with the emulators menu? I solely use gameex as an emulator frontend, so this option would be nice.
2-Where can I input my own text for game descriptions? A lot of games are covered, but some are not. Where can I add this text?
Cheers,
Arjen
1) I don't think this is possible at the moment. You could request it in feature requests and it would probably be pretty simple for Tom to add. Alternately, you could use "Flat Menus" which will put everything on the front page so it's all accessable.
2) Are you asking about the text like "MAME" and wanting to change it to "Arcade Games" for example? If so, that's under text or something like that. It's on the first page of the advanced configuration wizard near the bottom.
The text I mean is the short summary of the game, I attached a screenshot to show what I mean,
Arjen
Ahhh, that text is in a database in the C:\Program Files\GameEx\DATA\EMULATORS directory. Just open the system you are looking at changing and edit the text in the description column. Good to go!
