Hello,
I have Gameex installed, Mediaplayer 9 and a couple of mp3's.
Made a playlist, and i can brows through the music files in Game-Ex.
But I can't play them ......
I have sound ( ambiant sound works fine ).
There is an option in de advanced configuration -> audio settings -> Enable media controls .....
Tries yes and no , but is doesn't do a thing ....
What is wrong ?
You can play these fine in WMP?
Hello,
What is wrong ?
Hi. I just a thought.. Have you enabled 'Media Player Library' as the 'JukeBox Mode' under 'Audio Options' in the Setup Wizard ? Also, you may have to select 'Add To Library' in WMP to get it to recognize your mp3s (and of course have the path set in WMP to your rip/music folder).
