Every time i exit out of a GBA or PC game, gameex crashes. Mame and other emulators seems to be working fine. I have tried reloading directx and graphics drivers. Every thing seems to be working fine outside of gameex.
Here is my log
Shawn
Here is my log
Shawn
Is your rom filter *.bat and commandline "[rompath]/[romfile]" and your working path set to .bat file location? If not try that. Thats how I launch bat files.
How are you exiting emulator? ESC? What happens if you exit the program directly does gameex crash?
Gameex could be crashing because the game closed but the batch file is still running and is not regaining focus. Maybe.
Are you using VBA for GBA emulation?
looks like my issues was related to my theme. i changed themes (only took 8 hours of tinkering before i tried that) and it seems like everything is working now. i didn't change any theme settings on my end, but i did update gameex something might of changed? i guess i should learn my lesson if its not broke don't mess with it... i always seem to have something stop working after updates :angry:
all my PC games are run from batch files and then i make a shortcut and have them all listed under 1 emulator section.
yeah i'm using VBA, i use esc to exit out of my games.
Glad you got it sorted out..
I wouldnt have guessed that.
