Hi,
I'm using the freedowrapper with Freedo and (almost) everything works fine.
The problem is when I quit Freedo (using alt-F4), the freedowrapper.exe stays in the process list. This means I have to End it manually before starting another game.
Is there a way to do it automatically when I end a game?
Thanks for any info.
Yves
Hi,
Yves
The correct GameEx way would be to use an advanced emulator configuration file for this emu. copy the project 64 one as that will also send ALT-F4 to the emulator so it closes cleanly. In the advanced emulator config specify the freedowrapper as an additional process to monitor.
