After reinstaling Gameex i find i can access the Config app in "more games & progs" nor weather and maybe more that i can remeber all i got is Theme Picker, Statistics and Start Screensaver. Enable Config app is set to "yes" in the Config so i am bit confused but maybe im missing somthing obvious if any one can shed some light on the matter that would be gr8.
Also can u mute ambience whilst radio is playing???
Cheers... B)
Cheers... B)
If you enabled the Config App in Enable/Disable Features, I'm not sure why you can't select it. It should just be there... It is for me anyways.
Weather is under HTML Apps actually. And now that you mention it, I believe you can disable (or enable) this from the HTML Applications tab in the Advanced Configuration.
Hope that helps!
