Hello,
I was wondering if it was possible to create custom paths to pictures. IE - Displaying pictures of playfields under visual pinball. I currently have the playfields displayed under "box", but I'd like to be able to change box to "playfields". Hope I described this well enough - any thoughts are appreciated.
I don't think there's any way to add new fields, but it may be possible to change the text for "box" to "playfield". The downside is that it would probably appear that way for all emulators. So if you had NES roms as well, they would have their boxes appear as "playfield" too. In the Advanced Setup Wizard, there is a tab called "Text" or something like that. In there, you can change pretty much all of the text stuff to whatever you want. So, you could change "MAME" to "Arcade Games" for instance.
