Alright, so I finally updated my cabinet to the newest gameex. It was running something like 6.05 lol, I even had to install the framework 2.0. Anyway everything seems to be working ok except for all my emulators. When I go to them I can see the games, box art and everything but when I try to run a game I get the following error. Now I've gone in there and reimported all of my saved config files that I had setup previously, but it still seems to get this error. Any suggestion:
18:15:53.4 6/16/2007: GameEx: Version 8.16: Starting Log
18:15:53.4 6/16/2007: Operating System Platform: Win32NT
18:15:53.4 6/16/2007: Operating System Name: Windows XP
18:15:53.4 6/16/2007: Operating System Version: 5.1.2600
18:15:53.4 6/16/2007: Checking for versions of .net Framework installed
18:15:53.4 6/16/2007: .net Framework 1.1 Installed
18:15:53.4 6/16/2007: .net Framework 2.0 Installed
18:15:53.4 6/16/2007: AMD Athlon 64 Processor 3000+
18:15:53.4 6/16/2007: 2Ghz
18:15:53.4 6/16/2007: Running Randomize()
18:15:53.4 6/16/2007: Loading PlugIns
18:15:53.5 6/16/2007: Checking for applications to Launch On Startup
18:15:53.5 6/16/2007: Running Misc startup tasks
18:15:53.5 6/16/2007: Setting Menu types
18:15:53.5 6/16/2007: Opening Configuration File
18:15:53.5 6/16/2007: Getting Configuration Values
18:15:53.5 6/16/2007: Using Theme: Default - The Goonies
18:15:53.5 6/16/2007: Checking for alternate Image Directory for Theme: Default - The Goonies
18:15:53.5 6/16/2007: Launching HideOS.exe
18:15:53.5 6/16/2007: Initialising Video/MNG DLL's
18:15:53.5 6/16/2007: Hiding Taskbar
18:15:53.5 6/16/2007: Is Media Center running?
18:15:53.5 6/16/2007: Checking/Creating LCD Registry values
18:15:53.5 6/16/2007: Check Media Center Exit/Start Mode
18:15:53.5 6/16/2007: Media Center Mode 2
18:15:53.5 6/16/2007: Video previews on. Warning: Only recommended on modern systems
18:15:53.5 6/16/2007: Snap Delay set to: 1
18:15:53.5 6/16/2007: Get other settings
18:15:53.5 6/16/2007: Set: Find emulator artwork on best match basis
18:15:53.6 6/16/2007: Start work for Form
18:15:53.6 6/16/2007: Getting Original Screen Size
18:15:53.6 6/16/2007: Opening Database Connection
18:15:53.8 6/16/2007: Initializing Component
18:15:53.9 6/16/2007: Creating Radio Station Genres
18:15:54.0 6/16/2007: Succesfully created station genres
18:15:54.0 6/16/2007: Initialising Windows Media Player Component
18:15:54.0 6/16/2007: MAME Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32
18:15:54.0 6/16/2007: MAME EXE file is: Mame32.exe
18:15:54.0 6/16/2007: ROM Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\roms
18:15:54.0 6/16/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
18:15:54.0 6/16/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
18:15:54.0 6/16/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
18:15:54.0 6/16/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
18:15:54.0 6/16/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
18:15:54.0 6/16/2007: Loading Controls.ini map file
18:15:54.0 6/16/2007: Snap Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\snap
18:15:54.0 6/16/2007: AVI Snap Path: Not Found
18:15:54.0 6/16/2007: Flyer Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\flyers
18:15:54.0 6/16/2007: Cabinet Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\cabinets
18:15:54.0 6/16/2007: Title Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\titles
18:15:54.0 6/16/2007: Panel Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\cpanel
18:15:54.0 6/16/2007: Manual Path: Not Found
18:15:54.0 6/16/2007: Icon Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\icons
18:15:54.0 6/16/2007: Marquee Path is: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\marquees
18:15:54.0 6/16/2007: Loading Custom Emulators
18:15:54.0 6/16/2007: Loading Emulator 1: Nintendo
18:15:54.1 6/16/2007: Loading Emulator 2: SNES
18:15:54.1 6/16/2007: Loading Emulator 3: Nintendo 64
18:15:54.1 6/16/2007: Loading Emulator 4: Gameboy
18:15:54.2 6/16/2007: Loading Emulator 5: Gameboy Advance
18:15:54.2 6/16/2007: Loading Emulator 6: Genesis
18:15:54.2 6/16/2007: Loading Emulator 7: Sega 32X
18:15:54.3 6/16/2007: Using 2D Animations
18:15:54.3 6/16/2007: Using General Font: Digital
18:15:54.3 6/16/2007: Using Title Font: Digital
18:15:54.3 6/16/2007: MAME CMD options: -triplebuffer -nowindow -joy
18:15:54.3 6/16/2007: Attempting to load game list
18:15:54.5 6/16/2007: Initialising DirectDraw
18:15:54.6 6/16/2007: Creating DirectDraw Device
18:15:54.6 6/16/2007: Using Device: Primary Display Driver
18:15:54.6 6/16/2007: 119mb video memory available
18:15:54.6 6/16/2007: Setting Resolution to 800x600 32 bit color
18:15:54.6 6/16/2007: Creating DirectDraw Surfaces
18:15:54.6 6/16/2007: Creating Primary Surface - Full Screen Mode
18:15:54.6 6/16/2007: Creating Back Buffer
18:15:54.6 6/16/2007: Version 2 Theme being used. Loading.
18:15:54.6 6/16/2007: Loading Button Data
18:15:54.6 6/16/2007: Loading Font Data
18:15:54.6 6/16/2007: Loading Layout Data
18:15:54.6 6/16/2007: Loading Taskbar Data
18:15:54.6 6/16/2007: Loading graphic Surfaces
18:15:54.6 6/16/2007: Creating Surfaces Misc and Dialogs
18:15:54.7 6/16/2007: Creating Surfaces Volume
18:15:54.7 6/16/2007: Creating Surfaces Arrows
18:15:54.7 6/16/2007: Creating Surfaces GameEXlogo Text
18:15:54.7 6/16/2007: Creating Surfaces Toolbar
18:15:54.8 6/16/2007: Creating Surfaces Backgrounds
18:15:55.1 6/16/2007: Creating Surfaces Toolbar Controls
18:15:55.1 6/16/2007: Creating Surfaces GameEx Logo
18:15:55.1 6/16/2007: Creating Surfaces Home & Exit
18:15:55.1 6/16/2007: Creating Surfaces Snaps
18:15:55.1 6/16/2007: Creating Surfaces Menu and List Bars
18:15:55.2 6/16/2007: Creating Fonts
18:15:55.2 6/16/2007: Creating Menu Font
18:15:55.3 6/16/2007: Restoring Menu Font From Cache
18:15:55.3 6/16/2007: Creating Game Font
18:15:55.4 6/16/2007: Creating Font Black
18:15:55.5 6/16/2007: Creating Font Black Small
18:15:55.7 6/16/2007: Creating Game Font Faded
18:15:55.7 6/16/2007: Creating Title Font
18:15:55.8 6/16/2007: Restoring Title Font From Cache
18:15:56.0 6/16/2007: Fonts Created Succesfully
18:15:56.0 6/16/2007: 77mb video memory left available
18:15:56.0 6/16/2007: Creating instance of global keyboard hook
18:15:56.0 6/16/2007: Starting GameExtender Publisher
18:15:56.0 6/16/2007: Text/Language: English
18:15:56.0 6/16/2007: Applying Language/Text
18:15:56.0 6/16/2007: Initialising Bass Audio Library
18:15:56.1 6/16/2007: Loading last used Game List
18:15:56.1 6/16/2007: Setting Music Volume
18:15:56.1 6/16/2007: Creating DirectSound Device
18:15:56.1 6/16/2007: Trying: Primary Sound Driver
18:15:56.1 6/16/2007: Loading Sound Files
18:15:56.2 6/16/2007: DirectSound Device Created Successfully
18:15:56.2 6/16/2007: Creating ICONS
18:15:56.2 6/16/2007: Recreating ICONS
18:15:57.0 6/16/2007: Initialising DirectInput for Gamepad support
18:15:57.2 6/16/2007: Unable to create a joystick device
18:15:57.2 6/16/2007: Playing Startup Video
18:16:02.0 6/16/2007: Initializing MCE Remote
18:16:02.0 6/16/2007: Initialization OK! Starting GameEx!
18:16:02.0 6/16/2007: Testing Main Loop Once: Processing Frame
18:16:02.3 6/16/2007: Testing Main Loop Once: Main Loop ran successfully
18:16:33.4 6/16/2007: Running: cmd.exe /c C: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\Mame32.exe 1944 -rompath C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\roms -triplebuffer -nowindow -joy
18:19:12.3 6/16/2007: Running: cmd.exe /c C: C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\Mame32.exe champbwl -rompath C:\Documents and Settings\Stephen\Desktop\Arcade\mame32\roms -triplebuffer -nowindow -joy -artwork -artwork_directory artwork
18:23:21.1 6/16/2007: Validating: Emulator_1: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\NES\screens
18:23:21.1 6/16/2007: Warning: Emulator_1: Custom Background Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_1: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\NES\screens
18:23:21.1 6/16/2007: Validating: Emulator_1: Database:
18:23:21.1 6/16/2007: Warning: Emulator_1: Database Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_1: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\NES\titles
18:23:21.1 6/16/2007: Validating: Emulator_1: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\NES\boxart
18:23:21.1 6/16/2007: Validating: Emulator_1: Cart Art Path:
18:23:21.1 6/16/2007: Warning: Emulator_1: Cart Art Path Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_1: Manual Path:
18:23:21.1 6/16/2007: Warning: Emulator_1: Manual Path Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_2: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SNES\screens
18:23:21.1 6/16/2007: Warning: Emulator_2: Custom Background Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_2: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SNES\screens
18:23:21.1 6/16/2007: Validating: Emulator_2: Database:
18:23:21.1 6/16/2007: Warning: Emulator_2: Database Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_2: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SNES\titles
18:23:21.1 6/16/2007: Validating: Emulator_2: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SNES\boxart
18:23:21.1 6/16/2007: Validating: Emulator_2: Cart Art Path: C:\Art\SNES\Carts
18:23:21.1 6/16/2007: Warning: Emulator_2: Cart Art Path Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_2: Manual Path:
18:23:21.1 6/16/2007: Warning: Emulator_2: Manual Path Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_3: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\N64\screens
18:23:21.1 6/16/2007: Warning: Emulator_3: Custom Background Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_3: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\N64\screens
18:23:21.1 6/16/2007: Validating: Emulator_3: Database:
18:23:21.1 6/16/2007: Warning: Emulator_3: Database Does not exist
18:23:21.1 6/16/2007: Validating: Emulator_3: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\N64\titles
18:23:21.1 6/16/2007: Validating: Emulator_3: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\N64\boxart
18:23:21.2 6/16/2007: Validating: Emulator_3: Cart Art Path:
18:23:21.2 6/16/2007: Warning: Emulator_3: Cart Art Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_3: Manual Path:
18:23:21.2 6/16/2007: Warning: Emulator_3: Manual Path Does not exist
18:23:21.2 6/16/2007: Warning: Emulator_3: MAPFile Does Not Exist
18:23:21.2 6/16/2007: Loading OfflineList Dat File for emulator: 3
18:23:21.2 6/16/2007: Cannot Find Offline List Dat File
18:23:21.2 6/16/2007: Validating: Emulator_4: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\gameboy\screens
18:23:21.2 6/16/2007: Warning: Emulator_4: Custom Background Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_4: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\gameboy\screens
18:23:21.2 6/16/2007: Validating: Emulator_4: Database:
18:23:21.2 6/16/2007: Warning: Emulator_4: Database Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_4: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\gameboy\titles
18:23:21.2 6/16/2007: Validating: Emulator_4: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\gameboy\boxart
18:23:21.2 6/16/2007: Validating: Emulator_4: Cart Art Path:
18:23:21.2 6/16/2007: Warning: Emulator_4: Cart Art Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_4: Manual Path:
18:23:21.2 6/16/2007: Warning: Emulator_4: Manual Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_5: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\GBA\screens
18:23:21.2 6/16/2007: Warning: Emulator_5: Custom Background Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_5: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\GBA\screens
18:23:21.2 6/16/2007: Validating: Emulator_5: Database:
18:23:21.2 6/16/2007: Warning: Emulator_5: Database Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_5: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\GBA\titles
18:23:21.2 6/16/2007: Validating: Emulator_5: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\GBA\boxart
18:23:21.2 6/16/2007: Validating: Emulator_5: Cart Art Path:
18:23:21.2 6/16/2007: Warning: Emulator_5: Cart Art Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_5: Manual Path:
18:23:21.2 6/16/2007: Warning: Emulator_5: Manual Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_6: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SEGA\screens
18:23:21.2 6/16/2007: Warning: Emulator_6: Custom Background Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_6: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SEGA\screens
18:23:21.2 6/16/2007: Validating: Emulator_6: Database:
18:23:21.2 6/16/2007: Warning: Emulator_6: Database Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_6: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SEGA\titles
18:23:21.2 6/16/2007: Validating: Emulator_6: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\SEGA\boxart
18:23:21.2 6/16/2007: Validating: Emulator_6: Cart Art Path:
18:23:21.2 6/16/2007: Warning: Emulator_6: Cart Art Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_6: Manual Path:
18:23:21.2 6/16/2007: Warning: Emulator_6: Manual Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_7: Custom Background: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\32x\Screens
18:23:21.2 6/16/2007: Warning: Emulator_7: Custom Background Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_7: Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\32x\Screens
18:23:21.2 6/16/2007: Validating: Emulator_7: Database:
18:23:21.2 6/16/2007: Warning: Emulator_7: Database Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_7: Title Snap Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\32x\Titles
18:23:21.2 6/16/2007: Validating: Emulator_7: Box Art Path: C:\Documents and Settings\Stephen\Desktop\Arcade\Emulators\32x\boxart
18:23:21.2 6/16/2007: Validating: Emulator_7: Cart Art Path:
18:23:21.2 6/16/2007: Warning: Emulator_7: Cart Art Path Does not exist
18:23:21.2 6/16/2007: Validating: Emulator_7: Manual Path:
18:23:21.2 6/16/2007: Warning: Emulator_7: Manual Path Does not exist
18:23:33.1 6/16/2007: 21 Consecutive Exceptions Occured: Exiting
18:23:33.1 6/16/2007: Closing database connection
18:23:33.1 6/16/2007: First Exception:
18:23:33.1 6/16/2007: Value cannot be null.
Parameter name: Argument 'Array' is Nothing.
18:23:33.1 6/16/2007: at Microsoft.VisualBasic.Information.UBound(Array Array, Int32 Rank)
18:23:33.1 6/16/2007: at GameEx.GameEx.mainform.LaunchEmu(Boolean LaunchedFromAttract)
18:23:33.1 6/16/2007: at GameEx.GameEx.mainform.processgamemenu()
18:23:33.1 6/16/2007: at GameEx.GameEx.mainform.DisplayFrame()
18:23:33.1 6/16/2007: Last Exception:
Damn.
I just deleted my MagicEngine emulator and roms because of this same issue. I assumed that MagicEngine just wasn't compatible with Windows Vista. Curiously all my other emulators seemed to be functioning properly.
I'll have to try this again when I get back home... Unless MagicEngine really isn't working with GameEx for some unknown reason. :shrug:
