This is the error I get
Gamepad/Joystick disabled
13:44:58.7 15/06/2007: Playing Startup Video
13:45:03.5 15/06/2007: Error: Error in the application.
13:45:03.6 15/06/2007: at Microsoft.DirectX.DirectDraw.Surface.GetDc()
13:45:03.6 15/06/2007: at GameEx.GameEx.mainform.StartupVideo(Boolean relativepath)
13:45:03.6 15/06/2007: at GameEx.GameEx.mainform.InitGameEx(Boolean reinit, String ctheme, Boolean nohideos)
13:45:03.6 15/06/2007: at GameEx.GameEx.mainform..ctor()
13:45:03.6 15/06/2007: Closing database connection
13:45:03.6 15/06/2007: GameEx is exiting with errors
13:45:05.6 15/06/2007: ERRORS DETECTED: EXITING
I have no idea what it means . I'd like some help in overcoming this so that I can get this working as its seems to be the only really good games frontend available.
Please post the whole log.
14:17:31.9 15/06/2007: GameEx: Version 8.15: Starting Log
14:17:31.9 15/06/2007: Operating System Platform: Win32NT
14:17:31.9 15/06/2007: Operating System Name: Windows XP
14:17:31.9 15/06/2007: Operating System Version: 5.1.2600
14:17:31.9 15/06/2007: Checking for versions of .net Framework installed
14:17:31.9 15/06/2007: .net Framework 1.1 Installed
14:17:31.9 15/06/2007: .net Framework 2.0 Installed
14:17:31.9 15/06/2007: AMD Athlon 64 X2 Dual Core Processor 4200+
14:17:31.9 15/06/2007: 2.21Ghz - 2 Cores or CPU's
14:17:31.9 15/06/2007: Running Randomize()
14:17:31.9 15/06/2007: Loading PlugIns
14:17:31.9 15/06/2007: Checking for applications to Launch On Startup
14:17:31.9 15/06/2007: Running Misc startup tasks
14:17:31.9 15/06/2007: Setting Menu types
14:17:31.9 15/06/2007: Opening Configuration File
14:17:31.9 15/06/2007: Getting Configuration Values
14:17:31.9 15/06/2007: Using Theme: Default - GameEx
14:17:31.9 15/06/2007: Checking for alternate Image Directory for Theme: Default - GameEx
14:17:31.9 15/06/2007: Launching HideOS.exe
14:17:31.9 15/06/2007: Initialising Video/MNG DLL's
14:17:31.9 15/06/2007: Hiding Taskbar
14:17:32.0 15/06/2007: Is Media Center running?
14:17:32.0 15/06/2007: Checking/Creating LCD Registry values
14:17:32.0 15/06/2007: Check Media Center Exit/Start Mode
14:17:32.0 15/06/2007: Media Center Mode 0
14:17:32.0 15/06/2007: Snap Delay set to: 2
14:17:32.0 15/06/2007: Get other settings
14:17:32.0 15/06/2007: Set: Find emulator artwork on best match basis
14:17:32.0 15/06/2007: Start work for Form
14:17:32.0 15/06/2007: Getting Original Screen Size
14:17:32.0 15/06/2007: Opening Database Connection
14:17:32.1 15/06/2007: Initializing Component
14:17:32.2 15/06/2007: MAME Path is: C:\Emulators\Mame32
14:17:32.3 15/06/2007: MAME EXE file is: Mame32.exe
14:17:32.3 15/06/2007: ROM Path is: C:\Emulators\Mame32\roms
14:17:32.3 15/06/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
14:17:32.3 15/06/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
14:17:32.3 15/06/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
14:17:32.4 15/06/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
14:17:32.4 15/06/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
14:17:32.5 15/06/2007: Loading Controls.ini map file
14:17:32.5 15/06/2007: Snap Path is: C:\Emulators\Mame32\snap
14:17:32.5 15/06/2007: AVI Snap Path is: C:\Emulators\Mame32\avisnap
14:17:32.5 15/06/2007: Flyer Path is: C:\Emulators\Mame32\flyers
14:17:32.5 15/06/2007: Cabinet Path is: C:\Emulators\Mame32\cabinets
14:17:32.5 15/06/2007: Title Path is: C:\Emulators\Mame32\titles
14:17:32.5 15/06/2007: Panel Path is: C:\Emulators\Mame32\cpanel
14:17:32.5 15/06/2007: Manual Path is: C:\Emulators\Mame32\manuals
14:17:32.5 15/06/2007: Icon Path is: C:\Emulators\Mame32\icons
14:17:32.5 15/06/2007: Marquee Path is: C:\Emulators\Mame32\marquees
14:17:32.6 15/06/2007: Loading Custom Emulators
14:17:32.6 15/06/2007: Loading Emulator 1: Atari 2600
14:17:33.0 15/06/2007: Loading Emulator 2: Atari 5200
14:17:33.0 15/06/2007: Loading Emulator 3: Atari 7800
14:17:33.1 15/06/2007: Loading Emulator 4: Atari Jaguar
14:17:33.1 15/06/2007: Loading Emulator 6: Atari Lynx
14:17:33.2 15/06/2007: Loading Emulator 7: Colecovision
14:17:33.2 15/06/2007: Loading Emulator 8: Commodore 64
14:17:33.2 15/06/2007: Loading Emulator 9: Commodore Amiga
14:17:33.2 15/06/2007: Loading Emulator 11: Mattel Intellivision
14:17:33.3 15/06/2007: Loading Emulator 13: NEC TurboGrafx 16
14:17:33.3 15/06/2007: Loading Emulator 16: Nintendo GameBoy
14:17:33.4 15/06/2007: Loading Emulator 17: Nintendo GameBoy Advance
14:17:33.4 15/06/2007: Loading Emulator 18: Nintendo GameBoy Color
14:17:33.4 15/06/2007: Loading Emulator 20: Nintendo N64
14:17:33.5 15/06/2007: Loading Emulator 21: Nintendo NES
14:17:33.5 15/06/2007: Loading Emulator 22: Nintendo SNES
14:17:33.5 15/06/2007: Loading Emulator 23: Nintendo Virtual Boy
14:17:33.5 15/06/2007: Loading Emulator 25: Philips Odyssey 2
14:17:33.6 15/06/2007: Loading Emulator 31: Sega Genesis
14:17:33.7 15/06/2007: Loading Emulator 32: Sega Master System
14:17:33.7 15/06/2007: Loading Emulator 34: SNK Neo Geo
14:17:33.7 15/06/2007: Loading Emulator 35: SNK Neo Geo Pocket
14:17:33.8 15/06/2007: Using 2D Animations
14:17:33.8 15/06/2007: Using General Font: HandelGothic BT
14:17:33.8 15/06/2007: Using Title Font: HandelGothic BT
14:17:33.8 15/06/2007: MAME CMD options: -triplebuffer -nowindow -joy
14:17:33.8 15/06/2007: Attempting to load game list
14:17:33.8 15/06/2007: Initialising DirectDraw
14:17:33.9 15/06/2007: Creating DirectDraw Device
14:17:33.9 15/06/2007: Using Device: Primary Display Driver
14:17:33.9 15/06/2007: 247mb video memory available
14:17:34.3 15/06/2007: Setting Resolution to 800x600 32 bit color
14:17:34.5 15/06/2007: Creating DirectDraw Surfaces
14:17:34.5 15/06/2007: Creating Primary Surface - Full Screen Mode
14:17:34.6 15/06/2007: Creating Back Buffer
14:17:34.6 15/06/2007: Loading graphic Surfaces
14:17:34.7 15/06/2007: Creating Surfaces Misc and Dialogs
14:17:34.7 15/06/2007: Creating Surfaces Volume
14:17:34.7 15/06/2007: Creating Surfaces Arrows
14:17:34.7 15/06/2007: Creating Surfaces GameEXlogo Text
14:17:34.7 15/06/2007: Creating Surfaces Toolbar
14:17:34.7 15/06/2007: Creating Surfaces Backgrounds
14:17:34.7 15/06/2007: Creating Surfaces Toolbar Controls
14:17:34.7 15/06/2007: Creating Surfaces GameEx Logo
14:17:34.7 15/06/2007: Creating Surfaces Home & Exit
14:17:34.7 15/06/2007: Creating Surfaces Snaps
14:17:34.7 15/06/2007: Creating Surfaces Menu and List Bars
14:17:34.8 15/06/2007: Creating Fonts
14:17:34.8 15/06/2007: Creating Menu Font
14:17:34.8 15/06/2007: Restoring Menu Font From Cache
14:17:34.9 15/06/2007: Creating Game Font
14:17:35.2 15/06/2007: Creating Font Black
14:17:35.3 15/06/2007: Creating Font Black Small
14:17:35.4 15/06/2007: Creating Game Font Faded
14:17:35.9 15/06/2007: Creating Title Font
14:17:36.0 15/06/2007: Restoring Title Font From Cache
14:17:36.0 15/06/2007: Fonts Created Succesfully
14:17:36.0 15/06/2007: 220mb video memory left available
14:17:59.1 15/06/2007: Text/Language: English
14:17:59.1 15/06/2007: Applying Language/Text
14:17:59.1 15/06/2007: Initialising Bass Audio Library
14:17:59.3 15/06/2007: Loading last used Game List
14:17:59.3 15/06/2007: Loading Start Page
14:17:59.4 15/06/2007: Setting Music Volume
14:17:59.4 15/06/2007: Cannot Load Play List. Check Path and filename
14:17:59.4 15/06/2007: Creating DirectSound Device
14:17:59.4 15/06/2007: Trying: Primary Sound Driver
14:17:59.4 15/06/2007: Loading Sound Files
14:17:59.5 15/06/2007: DirectSound Device Created Successfully
14:17:59.5 15/06/2007: Creating ICONS
14:17:59.5 15/06/2007: Recreating ICONS
14:17:59.6 15/06/2007: Gamepad/Joystick disabled
14:17:59.6 15/06/2007: Playing Startup Video
14:18:03.2 15/06/2007: Error: Error in the application.
14:18:03.3 15/06/2007: at Microsoft.DirectX.DirectDraw.Surface.GetDc()
14:18:03.3 15/06/2007: at GameEx.GameEx.mainform.StartupVideo(Boolean relativepath)
14:18:03.3 15/06/2007: at GameEx.GameEx.mainform.InitGameEx(Boolean reinit, String ctheme, Boolean nohideos)
14:18:03.3 15/06/2007: at GameEx.GameEx.mainform..ctor()
14:18:03.3 15/06/2007: Closing database connection
14:18:03.3 15/06/2007: GameEx is exiting with errors
14:18:05.1 15/06/2007: ERRORS DETECTED: EXITING
Any help at all would be appreciated. The more I read about this prog, and the more support I see for this the better I like and want it. I also have quite a few friends that I know would be interested in this.
log added
OK, remove the startup video. That's where it is failing. Might be that you dont have codecs.
Couldn't find where the startup video thingy was, so installed ffdshow and all ok starting up now.
Off to spend some time getting it configured now.
Thanks for your help.
