Everything was working fine then Bam! i cant reload. I keep getting this error.. any sugestions?
8:50:33.4 5/24/2007: GameEx: Version 8.12: Starting Log
18:50:33.4 5/24/2007: Operating System Platform: Win32NT
18:50:33.4 5/24/2007: Operating System Name: Windows XP
18:50:33.4 5/24/2007: Operating System Version: 5.1.2600
18:50:33.4 5/24/2007: Checking for versions of .net Framework installed
18:50:33.4 5/24/2007: .net Framework 2.0 Installed
18:50:33.4 5/24/2007: AMD Athlon XP
18:50:33.4 5/24/2007: 1.25Ghz
18:50:33.4 5/24/2007: Running Randomize()
18:50:33.4 5/24/2007: Loading PlugIns
18:50:33.4 5/24/2007: Checking for applications to Launch On Startup
18:50:33.4 5/24/2007: Running Misc startup tasks
18:50:33.4 5/24/2007: Setting Menu types
18:50:33.5 5/24/2007: Opening Configuration File
18:50:33.5 5/24/2007: Getting Configuration Values
18:50:33.5 5/24/2007: Using Theme: Default - Deep Purple
18:50:33.5 5/24/2007: Checking for alternate Image Directory for Theme: Default - Deep Purple
18:50:33.5 5/24/2007: Launching HideOS.exe
18:50:33.5 5/24/2007: Initialising Video/MNG DLL's
18:50:33.5 5/24/2007: Hiding Taskbar
18:50:33.5 5/24/2007: Is Media Center running?
18:50:33.5 5/24/2007: Checking/Creating LCD Registry values
18:50:33.5 5/24/2007: Check Media Center Exit/Start Mode
18:50:33.5 5/24/2007: Media Center Mode 0
18:50:33.5 5/24/2007: Video previews on. Warning: Only recommended on modern systems
18:50:33.5 5/24/2007: Snap Delay set to: 1
18:50:33.5 5/24/2007: Get other settings
18:50:33.5 5/24/2007: Desktop set to Hide ICONS and set Background to Black
18:50:33.5 5/24/2007: Backing up Registry Wallpaper Settings
18:50:33.6 5/24/2007: Set: Find emulator artwork on best match basis
18:50:33.6 5/24/2007: Start work for Form
18:50:33.6 5/24/2007: Getting Original Screen Size
18:50:33.6 5/24/2007: Opening Database Connection
18:50:34.1 5/24/2007: Initializing Component
18:50:34.2 5/24/2007: Creating Radio Station Genres
18:50:34.3 5/24/2007: Succesfully created station genres
18:50:34.4 5/24/2007: Initialising Windows Media Player Component
18:50:34.4 5/24/2007: MAME Path is: C:\Mame32
18:50:34.4 5/24/2007: MAME EXE file is: Mame32.exe
18:50:34.4 5/24/2007: ROM Path is: C:\Mame32\roms
18:50:34.4 5/24/2007: Catver.ini Not Found
18:50:34.4 5/24/2007: controls.ini Not Found
18:50:34.4 5/24/2007: History.dat Not Found
18:50:34.4 5/24/2007: nplayers.ini Not Found
18:50:34.4 5/24/2007: MAMEinfo.dat Not Found
18:50:34.4 5/24/2007: Loading Controls.ini map file
18:50:34.4 5/24/2007: Snap Path is: C:\Mame32\snap
18:50:34.4 5/24/2007: AVI Snap Path: Not Found
18:50:34.4 5/24/2007: Flyer Path is: C:\Mame32\flyers
18:50:34.4 5/24/2007: Cabinet Path is: C:\Mame32\cabinets
18:50:34.4 5/24/2007: Title Path is: C:\Mame32\titles
18:50:34.4 5/24/2007: Panel Path is: C:\Mame32\cpanel
18:50:34.4 5/24/2007: Manual Path: Not Found
18:50:34.4 5/24/2007: Icon Path is: C:\Mame32\icons
18:50:34.4 5/24/2007: Marquee Path is: C:\Mame32\marquees
18:50:34.5 5/24/2007: Loading Custom Emulators
18:50:34.6 5/24/2007: Using 2D Animations
18:50:34.6 5/24/2007: Using General Font: Arial
18:50:34.6 5/24/2007: Using Title Font: Arial
18:50:34.6 5/24/2007: MAME CMD options:
18:50:34.6 5/24/2007: Attempting to load game list
18:50:34.6 5/24/2007: Initialising DirectDraw
18:50:34.7 5/24/2007: Error: Conversion from string "" to type 'Double' is not valid.
18:50:34.7 5/24/2007: at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
18:50:34.7 5/24/2007: at Microsoft.VisualBasic.Conversion.Int(Object Number)
18:50:34.7 5/24/2007: at GameEx.GameEx.mainform.InitDirectDraw(Boolean FullScreenWindowed, Boolean nodispose, Boolean reinit, Boolean DontLoadSurfaces, Boolean SetSizingX, Int32 RefreshRate)
18:50:34.7 5/24/2007: at GameEx.GameEx.mainform.InitGameEx(Boolean reinit, String ctheme, Boolean nohideos)
18:50:34.7 5/24/2007: at GameEx.GameEx.mainform..ctor()
18:50:34.7 5/24/2007: Closing database connection
18:50:34.7 5/24/2007: GameEx is exiting with errors
18:50:36.2 5/24/2007: ERRORS DETECTED: EXITING
Thanks for any help you can give:)
Tried a couple things with resolution. Could you be more specific?
I looked at the code, and it would cause this error if the resolution was not set in GameEx configuration.
