hi just setup my pc with gameex after a hdd fail...
got it all running ok apart from mame32 crash's and windows error message shows up........it also does this if i try to run mame32 on its own....
before pc died it was running ok ..and i have done settings as what they were.....
using the same setup as b4 ...
xp home oem sp2(also tried xp pro sp2)
120gig hdd
320 gig hdd
1 gig ram
2800 xp processor
i have had a quick search of forum but cant find anything.....
please can some one help or point me in the right direction...
thanks
20:23:36.1 24/05/2007: GameEx: Version 8.07: Starting Log
20:23:36.1 24/05/2007: Operating System Platform: Win32NT
20:23:36.1 24/05/2007: Operating System Name: Windows XP
20:23:36.1 24/05/2007: Operating System Version: 5.1.2600
20:23:36.1 24/05/2007: Checking for versions of .net Framework installed
20:23:36.1 24/05/2007: .net Framework 1.1 Installed
20:23:36.1 24/05/2007: .net Framework 2.0 Installed
20:23:36.1 24/05/2007: AMD Duron processor
20:23:36.1 24/05/2007: 1.66Ghz
20:23:36.1 24/05/2007: Running Randomize()
20:23:36.1 24/05/2007: Loading PlugIns
20:23:36.2 24/05/2007: Checking for applications to Launch On Startup
20:23:36.2 24/05/2007: Running Misc startup tasks
20:23:36.2 24/05/2007: Setting Menu types
20:23:36.2 24/05/2007: Opening Configuration File
20:23:36.2 24/05/2007: Getting Configuration Values
20:23:36.2 24/05/2007: Using Theme: Default - BlueEx - Arcade800x600
20:23:36.2 24/05/2007: Checking for alternate Image Directory for Theme: Default - BlueEx - Arcade800x600
20:23:36.2 24/05/2007: Launching HideOS.exe
20:23:36.2 24/05/2007: Initialising Video/MNG DLL's
20:23:36.2 24/05/2007: Arcade Mode is on
20:23:36.2 24/05/2007: Hiding Taskbar
20:23:36.2 24/05/2007: Is Media Center running?
20:23:36.2 24/05/2007: Checking/Creating LCD Registry values
20:23:36.2 24/05/2007: Check Media Center Exit/Start Mode
20:23:36.2 24/05/2007: Media Center Mode 0
20:23:36.2 24/05/2007: Video previews on. Warning: Only recommended on modern systems
20:23:36.2 24/05/2007: Snap Delay set to: 2
20:23:36.2 24/05/2007: Get other settings
20:23:36.3 24/05/2007: Desktop set to Hide ICONS and set Background to Black
20:23:36.3 24/05/2007: Backing up Registry Wallpaper Settings
20:23:36.3 24/05/2007: Set: Find emulator artwork on best match basis
20:23:36.3 24/05/2007: Start work for Form
20:23:36.3 24/05/2007: Getting Original Screen Size
20:23:36.4 24/05/2007: Initializing Component
20:23:36.5 24/05/2007: MAME Path is: C:\Emulators\Mame32
20:23:36.5 24/05/2007: AdvanceMAME Path is: C:\Emulators\AdvanceMAME
20:23:36.5 24/05/2007: AdvanceMAME EXE file is: advmame.exe
20:23:36.5 24/05/2007: Use AdvanceMAME on. advmame.exe will launch games
20:23:36.5 24/05/2007: MAME EXE file is: Mame32.exe
20:23:36.5 24/05/2007: ROM Path is: C:\Emulators\Mame32\roms
20:23:36.5 24/05/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
20:23:36.5 24/05/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
20:23:36.5 24/05/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
20:23:36.5 24/05/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
20:23:36.5 24/05/2007: Loading Controls.ini map file
20:23:36.5 24/05/2007: Snap Path is: C:\Emulators\Mame32\snap
20:23:36.5 24/05/2007: AVI Snap Path is: C:\Emulators\Mame32\avisnap
20:23:36.5 24/05/2007: Flyer Path is: C:\Emulators\Mame32\flyers
20:23:36.5 24/05/2007: Cabinet Path is: C:\Emulators\Mame32\cabinets
20:23:36.5 24/05/2007: Title Path is: C:\Emulators\Mame32\titles
20:23:36.5 24/05/2007: Panel Path is: C:\Emulators\Mame32\cpanel
20:23:36.5 24/05/2007: Manual Path: Not Found
20:23:36.5 24/05/2007: Icon Path is: C:\Emulators\Mame32\icons
20:23:36.5 24/05/2007: Marquee Path is: C:\Emulators\Mame32\marquees
20:23:36.6 24/05/2007: Loading Custom Emulators
20:23:36.6 24/05/2007: Loading Emulator 1: Nintendo
20:23:36.6 24/05/2007: Loading Emulator 2: Super Nintendo
20:23:36.7 24/05/2007: Loading Emulator 3: Nintendo N64
20:23:36.8 24/05/2007: Loading Emulator 4: Master System
20:23:37.0 24/05/2007: Loading Emulator 5: Megadrive
20:23:37.1 24/05/2007: Loading Emulator 6: Sega CD
20:23:37.1 24/05/2007: Loading Emulator 7: NeoGeo
20:23:37.3 24/05/2007: Loading Emulator 8: NEC TurboGrafx 16
20:23:37.6 24/05/2007: Using 2D Animations
20:23:37.6 24/05/2007: Using General Font: Trebuchet MS
20:23:37.6 24/05/2007: Using Title Font: Joystix
20:23:37.6 24/05/2007: Initialising DirectDraw
20:23:38.9 24/05/2007: Creating DirectDraw Device
20:23:38.9 24/05/2007: Using Device: Primary Display Driver
20:23:39.0 24/05/2007: 124mb video memory available
20:23:39.6 24/05/2007: Setting Resolution to 800x600 32 bit color
20:23:39.8 24/05/2007: Creating DirectDraw Surfaces
20:23:39.8 24/05/2007: Creating Primary Surface - Full Screen Mode
20:23:40.1 24/05/2007: Creating Back Buffer
20:23:40.2 24/05/2007: Loading graphic Surfaces
20:23:40.2 24/05/2007: Creating Surfaces Misc and Dialogs
20:23:40.3 24/05/2007: Creating Surfaces Volume
20:23:40.3 24/05/2007: Creating Surfaces Arrows
20:23:40.3 24/05/2007: Creating Surfaces GameEXlogo Text
20:23:40.3 24/05/2007: Creating Surfaces Toolbar
20:23:40.4 24/05/2007: Creating Surfaces Backgrounds
20:23:40.7 24/05/2007: Creating Surfaces Toolbar Controls
20:23:40.7 24/05/2007: Creating Surfaces GameEx Logo
20:23:40.7 24/05/2007: Creating Surfaces Home & Exit
20:23:40.7 24/05/2007: Creating Surfaces Snaps
20:23:40.8 24/05/2007: Creating Surfaces Menu and List Bars
20:23:40.9 24/05/2007: Creating Fonts
20:23:40.9 24/05/2007: Creating Menu Font
20:23:41.0 24/05/2007: Restoring Menu Font From Cache
20:23:41.0 24/05/2007: Creating Game Font
20:23:41.7 24/05/2007: Creating Font Black
20:23:42.0 24/05/2007: Creating Font Black Small
20:23:42.1 24/05/2007: Creating Game Font Faded
20:23:43.2 24/05/2007: Creating Title Font
20:23:43.3 24/05/2007: Restoring Title Font From Cache
20:23:43.5 24/05/2007: Fonts Created Succesfully
20:23:43.5 24/05/2007: 83mb video memory left available
20:24:06.9 24/05/2007: Text/Language: English
20:24:06.9 24/05/2007: Applying Language/Text
20:24:07.0 24/05/2007: Initialising Bass Audio Library
20:24:07.0 24/05/2007: MAME CMD options:
20:24:07.0 24/05/2007: Attempting to load game list
20:24:07.0 24/05/2007: Loading last used Game List
20:24:07.0 24/05/2007: Setting Music Volume
20:24:07.0 24/05/2007: Cannot Load Play List. Check Path and filename
20:24:07.0 24/05/2007: Sound Disabled
20:24:07.0 24/05/2007: Creating ICONS
20:24:07.1 24/05/2007: Recreating ICONS
20:24:07.5 24/05/2007: Initialising DirectInput for Gamepad support
20:24:07.6 24/05/2007: Unable to create a joystick device
20:24:07.6 24/05/2007: Initializing MCE Remote
20:24:07.6 24/05/2007: Initialization OK! Starting GameEx!
20:24:07.6 24/05/2007: Testing Main Loop Once: Processing Frame
20:24:08.3 24/05/2007: Testing Main Loop Once: Main Loop ran successfully
20:24:29.7 24/05/2007: Running: cmd.exe /c C: C:\Emulators\AdvanceMAME\advmame.exe ts2j -device_video_output fullscreen -quiet -dir_rom "C:\Emulators\Mame32\roms"
20:24:53.7 24/05/2007: Exiting GameEx!
20:24:53.7 24/05/2007: Saving Settings
20:24:55.1 24/05/2007: Disposing Plugins
20:24:55.1 24/05/2007: Checking for applications to Launch On Exit
this is the log....but as i say i cant get it to run out side of gameex as well
Oh I see, I didnt realise it was not a specific GameEx problem.
What I notice in your log though, is your actually trying to run AdvanceMAME here, but in your post you say MAME32 wont run. AdvanceMAME.exe is not MAME32 or regular MAME. Other thing is older version of GameEx.
Tom.
ok turn advancedmame off in settings and updated gameex.....still didnt work...
but then i tried and downloaded mame32 from here....http://tomspeirs.com/MAMEDownloads/default.htm...MAME32 0.99
and it worked.......
the one i downloaded using setup wizard dont work...... any thanks for trying
gameex is fantastic frontend
