So I got the emulator working but when I exit I have to use the mouse and close RockNes. All the other emulators exit back to GameEx. Its kinda of annoying if Im on my couch and have to get up to close it. Thanks in advance. Heres the config.
[Emulator_4]
StartPageName=Nintendo NES Games
TitleText=NES
StartPageLogo=nes
RomFilter=*.nes;*zip
RomsInFolders=False
ROMPath=C:\Emulators\RockNESX v2.0 Final\Roms
SnapPath=C:\Emulators\RockNESX v2.0 Final\Snaps\USA\screens
WorkingPath=C:\Emulators\RockNESX v2.0 Final
MapKeys=True
WaitBeforeKeys=
SendKeys=
ReplaceDash=True
ReplaceUnder=True
Capitals=True
RemoveBrackets=True
AlsoLaunch=
ShowDesktop=True
Debug=False
MapFile=
OLDatZip=
Command=RockNESX.exe [ROMPath]\[RomFile]
TitlePath=
BoxPath=
LaunchBefore=
LaunchAfter=
CartPath=
ShoPow,
I have written a tiny script that will completely close Rocknes for you
Unzip the attached file into C:\Emulators\RockNESX v2.0 Final
then set LaunchAfter= in your Emulator 4 config t:
LaunchAfter=C:\Emulators\RockNESX v2.0 Final\killrocknesvbs.vbs
Rocknes seems to have 2 different states (launcher and emulator). GameEx closes the emulator, but then the process reloads itself as the launcher. So in effect, Rocknes really needs to be closed twice. That is what this script does for you.
killrocknes.zip
Thank you so very much. I appreciate all that you put into this. I will give it a try tonight and update on the results. Thanks again for all your help.
-ShoPow
Well I did what you said and it still doesnt exit to gameex. I installed GameEx on my friends computer and Rocknes exits fine with out the need of an extra app. Im so confused. Thanks for your help. Hopefully I can figure it out.
  • 4 months later...
