Hi, I've just downloaded GoodGB64_203 to rename all my c64 games but GoodWindows_v2.4 doesn't have c64 listed under choose a sytem, So how do I add it to goodwindows so I can pick c64 option to rename my games :blink: .
Thanks.
First of all, use GoodGUI. That works better.
Then download the dat file and set the paths in 'file->options'
I have never liked GoodWindows. It never worked right for me from the get go.
Great I'll give it a try, thanks Adultery :lol:
must be missing something, to set the options you have to point goodgui to Goodinfo.cfg file which seems to be missing in goodgu 0.952 ?
Edit** Just downloaded a newer version v1.31 and it no longer has config file needed, but my other problem is that the programe wants a .exe file for the goodc64 but mine only has Gamebase64 - Licensed V2.03.dat file in my GoodGB64_203.rar ?
