Hi all i have a wied problem with issue
When i run Fusion Most of my games come up fine in full screen however some (such as X-Men). Come up with sound only an no video. Also on some games i have to hit escape around 3 times before i can exit out and back into Game-EX. Any help wold be appreciated.
Thanks,
Thanks,
Hi. Have you tried enabling 'Show Desktop' for that emulator ?
Where do i go to set that option at?
Thanks for the reply
Hi. If you start up the setup wizard and select 'Custom' (Setup) then 'Emulator Setup'. Then you select Fusion that you have already setup and go to the 2nd page of the 'Emulator Setup' you'll see it half way down the page. Try setting 'Show Desktop' to 'Yes' to see if it fixes your problem.
Hey that fixed the issue of the game now showing, But all games now show up in a window rather than full screen. I changed the option in the fusion.ini file to Fullscreen=1, however when i reloaded the game and exited back into GameEX it changed the option back to 0. Any thoughts? Would i have to reimport the file if i change and option like that?
Hi. I'm not sure about this. Have you tried setting the 'Full Screen Resolution' to whatever resolution you're running your desktop at (in Fusion's Frontend) ? Also, you can set it to full screen in fusion's frontend (it's under video options). Then exit fusion's frontend and try running from GameEX.
When i switched the resolution to match the desktop now when i startup fusion it automatcially goes to full screen, however i still have the same issue wiht GameEx. Under video on the menubar i see a full screen option but you have to hit escape everytime to use it. Is there a command line switch that i can use? Here is what mine looks like right now
Fusion.exe "[ROMPath]\[RomFile]"
SUCCESSS!!!!!!!!!!!!!!!!
I needed a switch added to my command line in GameEX
For Reference here is what it needs to look like, now when i hit escape it automatcially pulls back to EX,
Fusion.exe "[ROMPath]\[RomFile]" -fullscreen{nodosbox}{safelaunch}
MapKeys=yes
Command=fusion.exe -fullscreen "[ROMpath]\[RomFile]"
Hide Desktop=True
That's all you really need to use.
Good man !! That was the only other thing i could think of (but when i went to emulator setup i could only see the "[Rompath]\[Romfile]" in the command line), and i don't have any other emulators (other than MAME) setup so i couldn't say for sure. I would of thought that the -fullscreen switch should of been there by default.
