choose between: Import media / create capture / avi preview ?
Hi Tom,
I have almost finish my set up for gameex (Emulators and multimedia features) and I was wondering if it was possible to add some features on the multimedia section.
Here is my problem:
I have a huge movie collection with all the covers in the media folder of gameex.
If I want to keep all these covers I can't use the fonction "create snap" for the new added avi (recent download) because It will delete and create new snap for all "avi" in the video directory.
Is it possible to specify gameex in which path or folder it have to create snap (or run avi preview)?
In the folder directory the option will be: 1/ create snap for this folder 2/ view avipreview 3/ Search media
Or maybe it's possible to use same feature as the jukebox (automatic search for media content)?
Thanks in advance for your answer!
(and thanks again for making my mkv movies works into gameex)
Create snaps only creates snaps for games that don't already have snaps, so it won't overwrite your current snaps... well when working with rom sets thats how it works anyway... is this not the same for avi's? I don't bother with films in GameEx but I thought the same would apply
Hey thanks for your repply!
I have just launched the process to create capture over one specified folder (Anime Manga). it seems that gameex run through all the video path (I have four hardrives, one for each category: movies, documentary,manga... ).
This time gameex didn't overwrite the previous capture and has created capture for all "avi" which didn't have attached jpg or png.
It works almost perfect but for some movies which have already a .jpg file , gameex has created a png file. It seems to appear randomly and by default gameex take the png files...
First I thought it was because I had jpg files and gameex replace them by a png files but it's not the case for all...
Maybe it's caused by the name length or certain characters...
This feature is awesome but if it's messy after a new process (new added avi)...it's a lot of manipulation to clean after...
I will try to rename all my jpg in png to see what happens
Tom, any advice will help...
