Hi folks. I've a pc game set up as an emulator and i created a snap folder within the game directory and placed a .png file in it. I've pointed GameEX to it when i was setting the game up as an emulator but it does not display on the games start page. I've done this before with other pc games (set up as emulators) and the snaps display fine. The only thing i noticed different is that when i look in the snap folder of another pc game it shows a kind of image/paint icon for the snap whereas in the snap folder of the game i want to display it shows the actual image. What am i doing wrong ?
Thanks in advance,
iano.
If you're trying to change the emulator logo, it has to go in the theme folder. C:\Program Files\GameEx\Themes\Media
Then point GameEx at it by typing the name of the pic in the Logo section of advanced config.
Hi Adultery. Thanks for the reply and the info. My problem was that my snap for the game wasn't being displayed. It was my fault - i thought mistakenly that the name of the snap had to be the same as the game executable and not the gametitle.txt in my rom folder. I thought the purpose of having the gametitle.txt in the rom folder was just so the game's name would be displayed on it's page. Most of the time the executable is named the same as the game title and that's how i got away with it in the past but with that game typhoon 2001 the executable is just called typhoon. I was puzzled for hours !
Thanks again,
iano.
:D
