All games run from Daphneloader. Only five show in GE. None of them run. Any ideas?
I noticed that too. Just manually type over the extra Cobra Command entries to adjust them to the proper games. Don't forget to put the correct -framefile entries in the options fields. Don't forget to put the romset for the version you wish to run in the rom field.
That's it. A bit of typing. Everything worked for me.
Example of Option Field --> -framefile E:\Games\Daphne\astron\astron.txt
The framefiles for each game are usually in the Framefile directory, or in the Game directory (as in the above example).
Example of Rom Field --> astron
There are sometimes several rom files for the same game. Make sure you choose one that is working.
Assuming you put in the right rom name, point to the right -framefile, and originally setup the correct daphne directory (mine is E:\Games\Daphne). Everything should work exactly as it does in Daphne, except Thayer's quest needs a -bank switch to put it into Coin mode. (Don't worry about that)
One of the extremely nice things about the way GameEx handles daphne is that you can input identical entries and just change the ROM file to get a seperate entry for a differn't version. So if I want to run the the Dragon's Lair mod that has the drawbridge scene, as well as the Original arcade. I make another entry, simply change one rom name, and then can just click on which version I wish to start. In Daphne loader you have to bring up the game configuration and manually change between rom sets.
