please can you help
why wont favorites turn off on snes(snes9x),n64(project64),neogeo(winkawaks)
but turns of for ps1(epsxe),sega(fusion)
is there a way to disable favorites for all emulators
There's a setting to turn this off under the Emulator setup tab in your Advanced Configuration. I believe it's on the third page (next to last). You can also turn off the 'Display Last Game' setting.
If you merely want to disable the 'Add To Favorites' option in the Game Selection screen, you need to disable the Game Info page altogethter and just set GameEWx to launch the game straight away. If you use GoodMerge, I don't believe this option is possible.
I hope that helps! :)
