I installed the m4a/mpeg4 codec for windows media player:
http://www.free-codecs.com/download/3ivx.htm
Along with the m4a tag importer for WMP (to allow WMP to see the tags of these new files):
http://www.softpointer.com/WMPTagSupport.htm
Unfortunatly there seems to be a bug with GameEx in this regard. After the file associations are set WMP plays the files flawlessly. GameEx, however, shows each of the m4a files 3 times in the list and refuses to play any of the listed files.
Any advice?? If this was fixed im sure many users would be interested in adding this functionality...
Sounds like your using File Tag mode instead of WMP mode. Anyway M4A's will be functioning in the next release in flie tag mode. Probably today.
M4A's now play perfectly...the only problem is they still appear three times in the list :(
What Jukebox mode are you using? If its windows media player it must be some kind of issue with your library or the add ins your using. Gameex basically just reads the library uysing WMP itself in media player mode.
Using file tag mode...like you guessed in your last post
Delete all the .dat files in the data directory beginning with jukebox.
(it will take a while to scan first time you load jukebox again).
works perfectly...thanks for all the help
