Hi,
I like to use Gameex as a frontend for some emulators. I installed Gameex 7.99 and used the setup wizard. When I start gameex it crashes with the following error:
22:00:56.0 04.04.2007: Error in the application.
22:00:56.0 04.04.2007: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
22:00:56.0 04.04.2007: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
22:00:56.0 04.04.2007: at GameEx.GameEx.mainform.DrawBackground()
22:00:56.0 04.04.2007: at GameEx.GameEx.mainform.DisplayFrame()
22:00:56.0 04.04.2007: Last Exception:
I tried some other Skins and it worked a few times very well. But after restarting my PC the error occures again. Sometimes gameex starts with the gameex animation but then it freezes and i have to reset my PC...
My system:
AMD Athlon64 3200 (?) Venice
ASUS Motherboard A8V VM
ASUS EAX1300PRO Grafic Card
160gb HD
512mb RAM
I thin I will go crazy.....
Help PLEASE!!
Please post entire log. Also does it work with either the Media Center or MCE glossy theme. You can set this in the setup wizard or advanced configuration. Please confim, and post the whole log.
thanks.
Tom
Tom,
I had a crash the first couple of times I loaded GameEx after upgrading to 7.99 also. I haven't had time to get the log off the machine yet, but will try to get it tonight (assuming the crash is still there). In any case, there wasn't much info other than that it crashed and shut down. I know it was a DirectX type error (yeah, I know that doesn't really help much :blink: ).
Like I said, I'll try to get it to crash and upload the file tonight.
Hi Tom,
I tried the MCE and the MCE Glossy Theme. The MCE Theme worked for about 10 seconds and ended in a total crash of my PC. I also got a blue screen that says "TERMINAL_SERVER_DRIVER_MADE_INCORRECT_MEMORY_REFERENCE" but I think gameex shouldn´t have caused this error...
I rebooted and started gameex again and I got the following error log:
13:38:57.6 06.04.2007: GameEx: Version 7.99: Starting Log
13:38:57.7 06.04.2007: Operating System Platform: Win32NT
13:38:57.7 06.04.2007: Operating System Name: Windows XP
13:38:57.7 06.04.2007: Operating System Version: 5.1.2600
13:38:57.7 06.04.2007: Checking for versions of .net Framework installed
13:38:57.7 06.04.2007: .net Framework 1.1 Installed
13:38:57.7 06.04.2007: .net Framework 2.0 Installed
13:38:57.7 06.04.2007: AMD Athlon 64 Processor 3800+
13:38:57.7 06.04.2007: 2,4Ghz
13:38:57.7 06.04.2007: Running Randomize()
13:38:57.7 06.04.2007: Loading PlugIns
13:38:57.8 06.04.2007: Checking for applications to Launch On Startup
13:38:57.8 06.04.2007: Initialising Video/MNG DLL's
13:38:57.8 06.04.2007: Running Misc startup tasks
13:38:57.8 06.04.2007: Setting Menu types
13:38:57.8 06.04.2007: Opening Configuration File
13:38:57.8 06.04.2007: Getting Configuration Values
13:38:57.8 06.04.2007: Using Theme: Default - Media Center
13:38:57.8 06.04.2007: Checking for alternate Image Directory for Theme: Default - Media Center
13:38:57.8 06.04.2007: Launching HideOS.exe
13:38:57.8 06.04.2007: Hiding Taskbar
13:38:57.8 06.04.2007: Is Media Center running?
13:38:57.8 06.04.2007: Checking/Creating LCD Registry values
13:38:57.8 06.04.2007: Check Media Center Exit/Start Mode
13:38:57.8 06.04.2007: Media Center Mode 0
13:38:57.8 06.04.2007: Video previews on. Warning: Only recommended on modern systems
13:38:57.8 06.04.2007: Custom Keyboard Input enabled: Getting custom codes
13:38:57.8 06.04.2007: Snap Delay set to: 6
13:38:57.8 06.04.2007: Get other settings
13:38:57.9 06.04.2007: Set: Find emulator artwork on best match basis
13:38:57.9 06.04.2007: SlikStik support enabled
13:38:57.9 06.04.2007: Using DirectInput for keyboard input
13:38:57.9 06.04.2007: Start work for Form
13:38:57.9 06.04.2007: Getting Original Screen Size
13:38:57.9 06.04.2007: Initializing Component
13:38:58.0 06.04.2007: MAME Path is: C:\MAME
13:38:58.0 06.04.2007: Model 2 Path Path is: C:\Emulators\Model2
13:38:58.0 06.04.2007: Model 2 EXE file is: emulator.exe
13:38:58.0 06.04.2007: Use Model 2 on. m2launcher.exe will launch Sega Model 2 games
13:38:58.0 06.04.2007: ZiNc Path is: C:\Emulators
13:38:58.0 06.04.2007: ZiNc EXE file is: zinc.exe
13:38:58.0 06.04.2007: Use ZiNc on. zinc.exe will launch PSX games
13:38:58.0 06.04.2007: MAME EXE file is: mamepgui.exe
13:38:58.1 06.04.2007: ROM Path is: C:\MAME\roms
13:38:58.1 06.04.2007: Catver.ini is located at: D:\Programme\GameEx\DATA\catver.ini
13:38:58.1 06.04.2007: controls.ini is located at: D:\Programme\GameEx\data\controls.ini
13:38:58.1 06.04.2007: History.dat is located at: D:\Programme\GameEx\DATA\history.dat
13:38:58.1 06.04.2007: nplayers.ini is located at: D:\Programme\GameEx\DATA\nplayers.ini
13:38:58.1 06.04.2007: MAMEinfo.dat is located at: D:\Programme\GameEx\DATA\mameinfo.dat
13:38:58.1 06.04.2007: Loading Controls.ini map file
13:38:58.1 06.04.2007: Snap Path is: C:\MAME\snap
13:38:58.1 06.04.2007: AVI Snap Path: Not Found
13:38:58.2 06.04.2007: Flyer Path is: C:\MAME\flyers
13:38:58.2 06.04.2007: Cabinet Path is: C:\MAME\cabinets
13:38:58.2 06.04.2007: Title Path is: C:\MAME\titles
13:38:58.2 06.04.2007: Panel Path is: C:\MAME\cpanel
13:38:58.2 06.04.2007: Manual Path: Not Found
13:38:58.2 06.04.2007: Icon Path is: C:\MAME\icons
13:38:58.2 06.04.2007: Marquee Path is: C:\MAME\marquees
13:38:58.2 06.04.2007: Loading Custom Emulators
13:38:58.2 06.04.2007: Loading Emulator 1: Nintendo 64 Games
13:38:58.3 06.04.2007: Loading Emulator 2: Nintendo SNES (ZSNES)
13:38:58.3 06.04.2007: Loading Emulator 3: Nintendo NES (NEStopia)
13:38:58.4 06.04.2007: Loading Emulator 4: SNK Neo Geo (NeoRAGEx)
13:38:58.5 06.04.2007: Loading Emulator 5: Sony Playstation (ePSXe)
13:38:58.6 06.04.2007: Using 2D Animations
13:38:58.6 06.04.2007: Using General Font: Trebuchet MS
13:38:58.6 06.04.2007: Using Title Font: Trebuchet MS
13:38:58.6 06.04.2007: Initialising DirectDraw
13:38:58.6 06.04.2007: Creating DirectDraw Device
13:38:58.6 06.04.2007: Using Device: ASUS X1300 Series
13:38:58.6 06.04.2007: 374mb video memory available
13:38:58.7 06.04.2007: Setting Resolution to 800x600 32 bit color
13:38:58.7 06.04.2007: Creating DirectDraw Surfaces
13:38:58.7 06.04.2007: Creating Primary Surface - Full Screen Mode
13:38:58.7 06.04.2007: Creating Back Buffer
13:38:58.7 06.04.2007: Loading graphic Surfaces
13:38:58.8 06.04.2007: Creating Surfaces Misc and Dialogs
13:38:58.9 06.04.2007: Creating Surfaces Volume
13:38:58.9 06.04.2007: Creating Surfaces Arrows
13:38:58.9 06.04.2007: Creating Surfaces GameEXlogo Text
13:38:58.9 06.04.2007: Creating Surfaces Toolbar
13:38:59.1 06.04.2007: Creating Surfaces Backgrounds
13:38:59.2 06.04.2007: Creating Surfaces Toolbar Controls
13:38:59.2 06.04.2007: Creating Surfaces GameEx Logo
13:38:59.2 06.04.2007: Creating Surfaces Home & Exit
13:38:59.3 06.04.2007: Creating Surfaces Snaps
13:38:59.3 06.04.2007: Creating Surfaces Menu and List Bars
13:38:59.5 06.04.2007: Creating Fonts
13:38:59.5 06.04.2007: Creating Menu Font
13:38:59.5 06.04.2007: Restoring Menu Font From Cache
13:38:59.5 06.04.2007: Creating Game Font
13:38:59.6 06.04.2007: Creating Font Black
13:38:59.7 06.04.2007: Creating Font Black Small
13:38:59.8 06.04.2007: Creating Game Font Faded
13:38:59.8 06.04.2007: Creating Title Font
13:38:59.8 06.04.2007: Restoring Title Font From Cache
13:38:59.9 06.04.2007: Fonts Created Succesfully
13:38:59.9 06.04.2007: 332mb video memory left available
13:39:23.4 06.04.2007: Text/Language: German
13:39:23.4 06.04.2007: Applying Language/Text
13:39:23.5 06.04.2007: Initialising Bass Audio Library
13:39:23.6 06.04.2007: MAME CMD options: -triplebuffer -nowindow -joy
13:39:23.6 06.04.2007: Attempting to load game list
13:39:24.0 06.04.2007: Loading last used Game List
13:39:24.0 06.04.2007: Setting Music Volume
13:39:24.0 06.04.2007: Cannot Load Play List. Check Path and filename
13:39:24.0 06.04.2007: Creating DirectSound Device
13:39:24.0 06.04.2007: Trying: Primärer Soundtreiber
13:39:24.0 06.04.2007: Loading Sound Files
13:39:24.1 06.04.2007: DirectSound Device Created Successfully
13:39:24.1 06.04.2007: Creating ICONS
13:39:24.1 06.04.2007: Restoring Cached ICONS from File
13:39:26.2 06.04.2007: Initialising DirectInput for Gamepad support
13:39:26.3 06.04.2007: Unable to create a joystick device
13:39:26.3 06.04.2007: Initialising DirectInput for Keyboard support
13:39:26.4 06.04.2007: Playing intro sound file
13:39:26.4 06.04.2007: Initializing MCE Remote
13:39:26.4 06.04.2007: Initialization OK! Starting GameEx!
13:39:26.5 06.04.2007: Testing Main Loop Once: Processing Frame
13:39:26.8 06.04.2007: Testing Main Loop Once: Main Loop ran successfully
13:39:39.7 06.04.2007: 21 Consecutive Exceptions Occured: Exiting
13:39:39.7 06.04.2007: First Exception:
13:39:39.7 06.04.2007: Error in the application.
13:39:39.8 06.04.2007: at Microsoft.DirectX.DirectDraw.Surface.DrawInternal(tagRECT* destRectangle, Surface sourceSurface, tagRECT* srcRectangle, DrawFlags flags, DrawEffects& bltEffects)
13:39:39.8 06.04.2007: at Microsoft.DirectX.DirectDraw.Surface.Draw(Rectangle destRectangle, Surface sourceSurface, Rectangle srcRectangle, DrawFlags flags)
13:39:39.8 06.04.2007: at GameEx.GameEx.mainform.DrawBackground()
13:39:39.8 06.04.2007: at GameEx.GameEx.mainform.DisplayFrame()
13:39:39.8 06.04.2007: Last Exception:
13:39:39.8 06.04.2007: Error in the application.
I have the ATI Drivers installed. Maybe this one causes the error.
Thank you for your help...
Hi Tom,
Have you got the latest ATI drivers installed I seem to recall this issue before, and installing latest drivers solved it.
I have the latest driver from the ASUS page. Should I try older ones?
Truy the actual ATI drivers from ATI.com. The Asus drivers on there site are probably ancient.
I'm using the Radeon Omega Drivers v3.8.291. I don't know off the top of my head which Catalyst drivers these are based on, but I know the new version (v3.8.330) is based on the Catalyst 7.1 drivers. What version have you experienced problems with? I could upgrade to the new Omega drivers, but I would prefer not using the actual ATI ones since they like to install a bunch of other garbage.
I really dont know, but if your using hacked drivers, its something i cant help out with unless i can trace this down to a bug in GameEx. but can you post the log so we can determine if it is actually the same issue? in addition try version 8.00
EDIT: It is possible to disable all the extra crap.
I may just try installing the regular drivers without the extra garbage and see how that goes. I noticed the newest Catalyst drivers are at v7.3 and Omega is only at v7.1.
I'll install v8.00 today and report back if I get a chance. Thanks for the reply!
