Hello fellow GameEX Users! This is my first post here. AWESOME program. I registered it within a few hours of messing with the demo. Can't wait to get my cabinet up and running with GameEX.
Onto my problem:
I installed "Karaoke for DirectX" and I am able to run cdg files in Windows Media Player. However when I try to launch a playlist from GameEX karaoke fails to run (or, on rare occasions, flickers on for a second then disappears). This results in GameEX coming back on screen back where I started.
Anyone have a similar issue or any idea how to fix this? This is a brand new rig with an ArcadeVGA PCI-E card. I assume it's some sort of codec issue. I do have Xvid installed for my game AVI previews.
Thanks!
Hi, I think this is a bug in GameEx. Ill get a fixed version out shortly.
Tom,
Thanks for getting back to me. I have downloaded the latest version but I am still having the same problem. I realize you probably have a large to-do list for development, so I am just curious if this fix was already applied or if you are holding off for a later update.
Thanks,
Chris
Tom,
Thanks,
Chris
Can you post your log please. I did fix an issue with Karoake which meant it did not work at all, so this might be something else.
Here is the log (Below). Once I click a song the screen turns black, then I see a titlebar flash for a second (sometimes it flashes twice). It looks like a screen trying to resize. Then it goes black again and GameEX comes back up like nothing happened. ONE time out of many tries I saw the lyrics come on screen for a split second. Also, the CDG videos run fine in windows media player. Thanks!
22:28:56.7 4/24/2007: GameEx: Version 8.07: Starting Log
22:28:56.7 4/24/2007: Operating System Platform: Win32NT
22:28:56.7 4/24/2007: Operating System Name: Windows XP
22:28:56.7 4/24/2007: Operating System Version: 5.1.2600
22:28:56.7 4/24/2007: Checking for versions of .net Framework installed
22:28:56.7 4/24/2007: .net Framework 1.1 Installed
22:28:56.7 4/24/2007: .net Framework 2.0 Installed
22:28:56.7 4/24/2007: AMD Athlon 64 Processor 4000+
22:28:56.7 4/24/2007: 2.41Ghz
22:28:56.7 4/24/2007: Running Randomize()
22:28:56.7 4/24/2007: Loading PlugIns
22:28:56.7 4/24/2007: Checking for applications to Launch On Startup
22:28:56.7 4/24/2007: Running Misc startup tasks
22:28:56.7 4/24/2007: Setting Menu types
22:28:56.7 4/24/2007: Opening Configuration File
22:28:56.7 4/24/2007: Getting Configuration Values
22:28:56.7 4/24/2007: Using Theme: Default - Women We Love To Play
22:28:56.7 4/24/2007: Checking for alternate Image Directory for Theme: Default - Women We Love To Play
22:28:56.7 4/24/2007: Launching HideOS.exe
22:28:56.7 4/24/2007: Initialising Video/MNG DLL's
22:28:56.7 4/24/2007: Hiding Taskbar
22:28:56.7 4/24/2007: Is Media Center running?
22:28:56.7 4/24/2007: Checking/Creating LCD Registry values
22:28:56.7 4/24/2007: Check Media Center Exit/Start Mode
22:28:56.7 4/24/2007: Media Center Mode 0
22:28:56.7 4/24/2007: Video previews on. Warning: Only recommended on modern systems
22:28:56.7 4/24/2007: Snap Delay set to: 6
22:28:56.7 4/24/2007: Get other settings
22:28:56.7 4/24/2007: Set: Find emulator artwork on best match basis
22:28:56.7 4/24/2007: Using DirectInput for keyboard input
22:28:56.7 4/24/2007: Start work for Form
22:28:56.7 4/24/2007: Getting Original Screen Size
22:28:56.7 4/24/2007: Initializing Component
22:28:56.8 4/24/2007: Creating Radio Station Genres
22:28:57.0 4/24/2007: Succesfully created station genres
22:28:57.0 4/24/2007: MAME Path is: F:\Emulators\Mame32
22:28:57.0 4/24/2007: MAME EXE file is: Mame32.exe
22:28:57.0 4/24/2007: ROM Paths are: F:\Roms\MAME;F:\Roms\MAME CHDs
22:28:57.0 4/24/2007: Catver.ini is located at: F:\Front Ends\GameEx\DATA\catver.ini
22:28:57.0 4/24/2007: controls.ini is located at: F:\Front Ends\GameEx\data\controls.ini
22:28:57.0 4/24/2007: History.dat is located at: F:\Front Ends\GameEx\DATA\history.dat
22:28:57.0 4/24/2007: nplayers.ini is located at: F:\Front Ends\GameEx\DATA\nplayers.ini
22:28:57.0 4/24/2007: MAMEinfo.dat is located at: F:\Front Ends\GameEx\DATA\mameinfo.dat
22:28:57.0 4/24/2007: Loading Controls.ini map file
22:28:57.0 4/24/2007: Snap Path is: F:\Extras\snap
22:28:57.0 4/24/2007: AVI Snap Path is: F:\Videos\MAME
22:28:57.0 4/24/2007: Flyer Path is: F:\Extras\flyers
22:28:57.0 4/24/2007: Cabinet Path is: F:\Extras\cabinets
22:28:57.0 4/24/2007: Title Path is: F:\Extras\titles
22:28:57.0 4/24/2007: Panel Path is: F:\Extras\cpanel
22:28:57.0 4/24/2007: Manual Path: Not Found
22:28:57.0 4/24/2007: Icon Path: Not Found
22:28:57.0 4/24/2007: Marquee Path is: F:\Extras\marquees
22:28:57.1 4/24/2007: Loading Custom Emulators
22:28:57.1 4/24/2007: Loading Emulator 1: Nintendo N64 (Project 64)
22:28:57.1 4/24/2007: Loading Emulator 2: Nintendo SNES (ZSNES)
22:28:57.1 4/24/2007: Loading Emulator 4: Nintendo NES (NEStopia)
22:28:57.1 4/24/2007: Loading Emulator 6: Sega Genesis (GENS+)
22:28:57.2 4/24/2007: Loading Emulator 7: Sega CD (Fusion)
22:28:57.2 4/24/2007: Loading Emulator 8: Sega Master System (Fusion)
22:28:57.2 4/24/2007: Loading Emulator 9: NEC TurboGrafx 16 (MagicEngine)
22:28:57.3 4/24/2007: Using 2D Animations
22:28:57.3 4/24/2007: Using General Font: Trebuchet MS
22:28:57.3 4/24/2007: Using Title Font: Trebuchet MS
22:28:57.3 4/24/2007: Initialising DirectDraw
22:28:57.3 4/24/2007: Applying GameEx is Loading Image
22:28:57.4 4/24/2007: Creating DirectDraw Device
22:28:57.4 4/24/2007: Using Device: Ultimarc ArcadeVGA2
22:28:57.4 4/24/2007: 499mb video memory available
22:28:57.7 4/24/2007: Setting Resolution to 1024x768 32 bit color
22:28:57.7 4/24/2007: Creating DirectDraw Surfaces
22:28:57.7 4/24/2007: Creating Primary Surface - Full Screen Mode
22:28:57.7 4/24/2007: Creating Back Buffer
22:28:57.7 4/24/2007: Loading graphic Surfaces
22:28:57.7 4/24/2007: Creating Surfaces Misc and Dialogs
22:28:57.8 4/24/2007: Creating Surfaces Volume
22:28:57.8 4/24/2007: Creating Surfaces Arrows
22:28:57.8 4/24/2007: Creating Surfaces GameEXlogo Text
22:28:57.8 4/24/2007: Creating Surfaces Toolbar
22:28:57.8 4/24/2007: Creating Surfaces Backgrounds
22:28:57.9 4/24/2007: Creating Surfaces Toolbar Controls
22:28:57.9 4/24/2007: Creating Surfaces GameEx Logo
22:28:57.9 4/24/2007: Creating Surfaces Home & Exit
22:28:57.9 4/24/2007: Creating Surfaces Snaps
22:28:57.9 4/24/2007: Creating Surfaces Menu and List Bars
22:28:58.0 4/24/2007: Creating Fonts
22:28:58.0 4/24/2007: Creating Menu Font
22:28:58.0 4/24/2007: Restoring Menu Font From Cache
22:28:58.0 4/24/2007: Creating Game Font
22:28:58.3 4/24/2007: Creating Font Black
22:28:58.4 4/24/2007: Creating Font Black Small
22:28:58.5 4/24/2007: Creating Game Font Faded
22:28:59.0 4/24/2007: Creating Title Font
22:28:59.0 4/24/2007: Restoring Title Font From Cache
22:28:59.1 4/24/2007: Fonts Created Succesfully
22:28:59.1 4/24/2007: 442mb video memory left available
22:28:59.2 4/24/2007: Starting GameExtender on: 127.0.0.1:8383
22:28:59.4 4/24/2007: Text/Language: English
22:28:59.4 4/24/2007: Applying Language/Text
22:28:59.4 4/24/2007: Initialising Bass Audio Library
22:28:59.5 4/24/2007: MAME CMD options: -triplebuffer -nowindow -joy
22:28:59.5 4/24/2007: Attempting to load game list
22:29:00.6 4/24/2007: Loading last used Game List
22:29:00.6 4/24/2007: Setting Music Volume
22:29:00.7 4/24/2007: Cannot Load Play List. Check Path and filename
22:29:00.7 4/24/2007: Creating DirectSound Device
22:29:00.7 4/24/2007: Trying: Primary Sound Driver
22:29:00.7 4/24/2007: Loading Sound Files
22:29:00.7 4/24/2007: DirectSound Device Created Successfully
22:29:00.7 4/24/2007: Initialising DirectInput for Gamepad support
22:29:00.7 4/24/2007: Unable to create a joystick device
22:29:00.7 4/24/2007: Initialising DirectInput for Keyboard support
22:29:00.8 4/24/2007: Initializing MCE Remote
22:29:00.8 4/24/2007: Initialization OK! Starting GameEx!
22:29:00.9 4/24/2007: Testing Main Loop Once: Processing Frame
22:29:01.1 4/24/2007: Testing Main Loop Once: Main Loop ran successfully
22:29:12.7 4/24/2007: Loading Karaoke Cache
22:29:29.0 4/24/2007: Exiting GameEx!
22:29:29.0 4/24/2007: Saving Settings
22:29:31.1 4/24/2007: Disposing Plugins
22:29:31.1 4/24/2007: Checking for applications to Launch On Exit
I tried the default theme but I still had no luck.
I ran karaoke many times in a row to try to read the title bar of the screen that flashed before game EX comes back up. It says:
"Game EX | Karaoke | [filename of song] | [##]/60"
The digits before "/60" change each time I run it. Don't know if that extra info is useful.
  • 5 weeks later...
I experience this same problem, i bought gameex quite a while ago, however i only use gamex for the karaoke function, as there is no other decent alternative for Media Center.
i did have MCE 2005 and i experienced this problem when i tried to upgrade to later versions, only the version that i downloaded when i first purchased it worked, and all subsequent versions produced this error.
I have sinced upgraded to Vista, and i am using the latest build of gameex. and this problem is also not working, so now the only feature i purchased gameex for cannot be used.
worth noting, when i first installed gameex and tried to play a CDG file i got a message saying that the file type is not recognised and it asked me if i want to try to play the file anyway, i said yes and the sond played ok, however upon subsequent retries the songs will not play resulting in the same error above.
Can you please assist me with this? the log file does not show any errors as far as the logfile displays, it says it has started the file for playback and ended without error.
also just another question would it be possible to add a startup setting to load the Karaoke player directly without going to the mame frontend.
Regards
Stuart Buchanan
Regards
Stuart Buchanan
Hi, I have been looking at this but its a bit difficult because I cant duplicate it. What would help though is if you could both post gameex.ini in the config folder zipping it first. If I can get it to do it for me it should be no problem getting it fixed.
Thanks.
Tom
Tom Thanks For he Offer Of Help, but i tried a few different configurations f gameex and had the same problems, and since you cold not replicate it i figured that it must be something specific to my Setup, it turns out this was due to ffdshow so i put an exception in the audio and video decoder configuration to not use ffdshow in gameex.exe and this works.
now i am trying to suss out why in vista the microphone does not playback realtime but it does record ok. ahh well :(
