What's up!
I set up Project 64 and everything works fine. But when I start a game, the mouse cursor is in the center of the screen. Is there a way to hide it?
One option is to set up the hidden mouse cursor from the autosheller program. If you do that, then it makes the mouse a single pixel so it's not really visible. The mouse should disapear within a few seconds, so this would make it much less noticable for the time it's displayed.
My mouse never appears when launching roms through Project64 though I'm running the latest 1.7 beta so maybe thats an added feature for donators?
I can't remember it doing it before when I was using 1.6 though either but maybe it did
im using version 1.6 and dont have this problem, im only using a standard setup
