hi all my first post. ive just read the post to get daemon tools with ssf working and it did work great the only problem i have is that i need to launch a ipac .ipc file i have got it working for my dreamcast but not sure what to type for the two commands together :blink: any help would be great thanks all
so what would i write in the batch file do i do it in notepad and save it as .bat
Yeah thats all you do write it in notepad and save as a .bat file. Basically it allows you to do more than one command. So after the @ECHO OFF line you just have a line for each command you want to launch.
thanks for the reply so would i write what i had to write to get them working as normal just on seprate lines in the batch
like this
@echo off
c:\winipac\winipac.exe "c:\winipac\profiles\ssf.ipc"
"c:\program files\daemon tools\daemon.exe" -mount 0,"[rompath]\[romfile]
and point launch before at this batch file
like this
@echo off
Yeah thats what you do
I'm more suprised the daemon tools one doesn't work
When you send command lines to a batch file it works differently, so in GameEx, you have
LaunchBefore=C:\Wherever\MyBat.bat "[rompath]\[rom]"
Then in your MyBat.bat you have
@ECHO OFF
c:\winipac\winipac.exe c:\winipac\profiles\ssf.ipc
"c:\program files\daemon tools\daemon.exe" -mount 0,%1
I'm not sure what your doing wrong with the winipac line, but with the daemon tools line, %1 is replaced with what is sent through the first paramenter (ie. "[rompath]\[rom]")
my winipac is in program files do i have to include that too
Yes, so:
May become
"c:\program files\winipac\winipac.exe" "c:\program files\winipac\profiles\ssf.ipc"
(normally you need to put quotes around file locations that contain spaces)
