Hey guys,
Thanks in advance for your continued patience with me. I realize that my ignorance drives many of you crazy, but we all have to learn somehow.
Anyway. I am running Zinc (Playstation) within GameEx. I am having two main issues:
Issue 1 : All of the S11 Games, I am having a controller issue. The issue is that the Player 2 Joystick and buttons do not work. (Player 1 works fine?)
Issue 2 : All of the KN1 Games do not work. When I select any one of these games, the screen goes dark like it is trying to initialize that game, but then returns to the menu without the game player.
Any help would be greatly appreciated. All of the other format games work perfectly?
Thanks,
Thomas
[email protected]
Issue 1) In order to use a joystick, you have to use the Winterblast plugin. You obviously are using one (hence issue 2), so it comes down to how you are setting it up. As I recall, this is one time that Joy2Key is needed to send the joystick commands to keyboard. If I get a chance, I'll look at my config to remember how I did it.
Issue 2) These games apparently don't work with the Winterblast plugin. There is a thread that was just posted that covers this. Look here.
I have to be honest with you, if I am using a plugin, my friend installed it and I did not even know it was there. I saw the post for issue 2 and had asked if there was any work around within GameEx to make these run?
On issue 1, it is only the s11 games, all of the other games work fine. ie Street Fighter EX, etc....
Thanks for your help.
Thomas
S11 and ZN1 and 2 games all use seperate configs on a per-BIOS basis, as well as a per-game basis. You have to make sure you change all your controller.cfg files to suit your setup. All these files are already included in the wrapper I told you to download earlier. :)
I responded to your KN1 games problem in the other thread, but you should probably be aware that if you don't have the chd's you can't run them at all. Also, be advised that most (if not all) of these games aren't even in English, so unless you're persuing a full ROM set, you probably won't ever play KN1 games anyways.
