I really like the series info on the screen for each game... But I'm having some trouble getting it to work right. I updated my gamelist, the series info appears on the screen, but I don't think it's right. Every game that has series info always displays the game "(Medal) Yumefuda [bET]" From Street Fighter to Metal Slug... That game shows up in every series... I've updated my gameslist about 4 times already and still the same results. I've also tried erasing gamelist.txt and it's still the same. Does anyone have a clue what it could be?
Here's a screenshot of what I see on most game screens...
If you're not using vanilla MAME, I don't think the series info displays correctly. Are you using MameFX or Mame Plus? It's just a guess...
Hi, are you using the latest version of GameEx, and the latest version of history.dat (or the one included with GameEx).
Pleast post your log.
Hi, thanks for helping me. MUCH appreciated! I'm using the lastest & official version of MAME. Windows command line version. I'm also using the lastest GameEx, history.dat, & mameinfo.dat.
Here's a copy of my log:
17:13:21.8 3/30/2007: GameEx: Version 7.97: Starting Log
17:13:21.9 3/30/2007: Operating System Platform: Win32NT
17:13:21.9 3/30/2007: Operating System Name: Windows XP
17:13:21.9 3/30/2007: Operating System Version: 5.1.2600
17:13:21.9 3/30/2007: Checking for versions of .net Framework installed
17:13:21.9 3/30/2007: .net Framework 1.1 Installed
17:13:21.9 3/30/2007: .net Framework 2.0 Installed
17:13:21.9 3/30/2007: Intel® Pentium® 4 CPU 2.60GHz
17:13:21.9 3/30/2007: 2.59Ghz
17:13:21.9 3/30/2007: Running Randomize()
17:13:21.9 3/30/2007: Loading PlugIns
17:13:22.0 3/30/2007: Checking for applications to Launch On Startup
17:13:22.0 3/30/2007: Initialising Video/MNG DLL's
17:13:22.0 3/30/2007: Running Misc startup tasks
17:13:22.0 3/30/2007: Setting Menu types
17:13:22.0 3/30/2007: Opening Configuration File
17:13:22.0 3/30/2007: Getting Configuration Values
17:13:22.0 3/30/2007: Using Theme: Default - Acidbrain Vision800x600
17:13:22.0 3/30/2007: Checking for alternate Image Directory for Theme: Default - Acidbrain Vision800x600
17:13:22.0 3/30/2007: Launching HideOS.exe
17:13:22.0 3/30/2007: Hiding Taskbar
17:13:22.0 3/30/2007: Using Cabinet Friendly Control System
17:13:22.0 3/30/2007: Is Media Center running?
17:13:22.1 3/30/2007: Checking/Creating LCD Registry values
17:13:22.1 3/30/2007: Check Media Center Exit/Start Mode
17:13:22.1 3/30/2007: Media Center Mode 2
17:13:22.1 3/30/2007: Video previews on. Warning: Only recommended on modern systems
17:13:22.1 3/30/2007: Custom Keyboard Input enabled: Getting custom codes
17:13:22.1 3/30/2007: Custom Game Device Input enabled: Getting custom codes
17:13:22.1 3/30/2007: Snap Delay set to: 2
17:13:22.1 3/30/2007: Get other settings
17:13:22.1 3/30/2007: Set: Find emulator artwork on best match basis
17:13:22.1 3/30/2007: SlikStik support enabled
17:13:22.1 3/30/2007: Using DirectInput for keyboard input
17:13:22.1 3/30/2007: Start work for Form
17:13:22.1 3/30/2007: Getting Original Screen Size
17:13:22.1 3/30/2007: Initializing Component
17:13:22.3 3/30/2007: MAME Path is: C:\mame
17:13:22.3 3/30/2007: daphne Path is: C:\DAPHNE
17:13:22.3 3/30/2007: daphne EXE file is: Daphne.exe
17:13:22.3 3/30/2007: Use daphne on. Daphne.exe will launch games
17:13:22.3 3/30/2007: ZiNc Path is: C:\Zinc
17:13:22.3 3/30/2007: ZiNc EXE file is: zinc.exe
17:13:22.3 3/30/2007: Use ZiNc on. zinc.exe will launch PSX games
17:13:22.3 3/30/2007: MAME EXE file is: mame.exe
17:13:22.3 3/30/2007: ROM Path is: C:\mame\roms
17:13:22.3 3/30/2007: Catver.ini is located at: C:\Program Files\GameEx\DATA\catver.ini
17:13:22.3 3/30/2007: controls.ini is located at: C:\Program Files\GameEx\data\controls.ini
17:13:22.3 3/30/2007: History.dat is located at: C:\Program Files\GameEx\DATA\history.dat
17:13:22.3 3/30/2007: nplayers.ini is located at: C:\Program Files\GameEx\DATA\nplayers.ini
17:13:22.3 3/30/2007: MAMEinfo.dat is located at: C:\Program Files\GameEx\DATA\mameinfo.dat
17:13:22.4 3/30/2007: Loading Controls.ini map file
17:13:22.4 3/30/2007: Snap Path is: C:\mame\snap
17:13:22.4 3/30/2007: AVI Snap Path: Not Found
17:13:22.4 3/30/2007: Flyer Path is: C:\mame\flyers
17:13:22.4 3/30/2007: Cabinet Path is: C:\mame\cabinets
17:13:22.4 3/30/2007: Title Path: Not Found
17:13:22.4 3/30/2007: Panel Path: Not Found
17:13:22.4 3/30/2007: Manual Path: Not Found
17:13:22.4 3/30/2007: Icon Path is: C:\mame\icons
17:13:22.4 3/30/2007: Marquee Path is: C:\mame\marquees
17:13:22.4 3/30/2007: Loading Custom Emulators
17:13:22.4 3/30/2007: Loading Emulator 4: Nintendo NES
17:13:22.7 3/30/2007: Using 3D Alpha Blended Animations. This could be slow
17:13:22.7 3/30/2007: Using General Font: Trebuchet MS
17:13:22.7 3/30/2007: Using Title Font: Trebuchet MS
17:13:22.7 3/30/2007: Initialising DirectDraw
17:13:22.7 3/30/2007: Applying GameEx is Loading Image
17:13:22.8 3/30/2007: Creating DirectDraw Device
17:13:22.8 3/30/2007: Using Device: RADEON 9800 PRO
17:13:22.8 3/30/2007: 246mb video memory available
17:13:22.8 3/30/2007: Setting Resolution to 800x600 32 bit color
17:13:22.8 3/30/2007: Creating DirectDraw Surfaces
17:13:22.8 3/30/2007: Creating Primary Surface - Full Screen Mode
17:13:22.9 3/30/2007: Creating Back Buffer
17:13:22.9 3/30/2007: Version 2 Theme being used. Loading.
17:13:22.9 3/30/2007: Loading Button Data
17:13:22.9 3/30/2007: Loading Font Data
17:13:22.9 3/30/2007: Loading Layout Data
17:13:22.9 3/30/2007: Loading Taskbar Data
17:13:22.9 3/30/2007: Loading graphic Surfaces
17:13:22.9 3/30/2007: Creating Surfaces Misc and Dialogs
17:13:23.0 3/30/2007: Creating Surfaces Volume
17:13:23.0 3/30/2007: Creating Surfaces Arrows
17:13:23.0 3/30/2007: Creating Surfaces GameEXlogo Text
17:13:23.0 3/30/2007: Creating Surfaces Toolbar
17:13:23.1 3/30/2007: Creating Surfaces Backgrounds
17:13:23.2 3/30/2007: Creating Surfaces Toolbar Controls
17:13:23.2 3/30/2007: Creating Surfaces GameEx Logo
17:13:23.2 3/30/2007: Creating Surfaces Home & Exit
17:13:23.2 3/30/2007: Creating Surfaces Snaps
17:13:23.2 3/30/2007: Creating Surfaces Menu and List Bars
17:13:23.3 3/30/2007: Creating Fonts
17:13:23.3 3/30/2007: Creating Menu Font
17:13:23.3 3/30/2007: Restoring Menu Font From Cache
17:13:23.4 3/30/2007: Creating Game Font
17:13:23.5 3/30/2007: Creating Font Black
17:13:23.7 3/30/2007: Creating Font Black Small
17:13:23.8 3/30/2007: Creating Game Font Faded
17:13:23.9 3/30/2007: Creating Title Font
17:13:23.9 3/30/2007: Restoring Title Font From Cache
17:13:24.0 3/30/2007: Fonts Created Succesfully
17:13:24.0 3/30/2007: 198mb video memory left available
17:13:24.0 3/30/2007: Starting GameExtender Publisher
17:13:24.3 3/30/2007: Text/Language: English
17:13:24.3 3/30/2007: Applying Language/Text
17:13:24.3 3/30/2007: Initialising Bass Audio Library
17:13:24.4 3/30/2007: MAME CMD options:
17:13:24.4 3/30/2007: Attempting to load game list
17:13:24.6 3/30/2007: Running: mame.exe -help
17:13:24.6 3/30/2007: Running: C: C:\mame\mame.exe -help > C:\mame\help.txt
17:13:25.9 3/30/2007:
17:13:25.9 3/30/2007: Detected MAME Version as: 0.113
17:13:25.9 3/30/2007: Now Outputing mame.exe - Help
17:13:25.9 3/30/2007: --BEGIN--
17:13:25.9 3/30/2007: M.A.M.E. v0.113 (Mar 5 2007) - Multiple Arcade Machine Emulator
17:13:25.9 3/30/2007: Copyright © 1997-2007 by Nicola Salmoria and the MAME Team
17:13:25.9 3/30/2007: MAME is an emulator: it reproduces, more or less faithfully, the behaviour of
17:13:25.9 3/30/2007: several arcade machines. But hardware is useless without software, so an image
17:13:25.9 3/30/2007: of the ROMs which run on that hardware is required. Such ROMs, like any other
17:13:25.9 3/30/2007: commercial software, are copyrighted material and it is therefore illegal to
17:13:25.9 3/30/2007: use them if you don't own the original arcade machine. Needless to say, ROMs
17:13:25.9 3/30/2007: are not distributed together with MAME. Distribution of MAME together with ROM
17:13:25.9 3/30/2007: images is a violation of copyright law and should be promptly reported to the
17:13:25.9 3/30/2007: authors so that appropriate legal action can be taken.
17:13:25.9 3/30/2007: Usage: MAME gamename [options]
17:13:26.0 3/30/2007:
17:13:26.0 3/30/2007: MAME -showusage for a brief list of options
17:13:26.0 3/30/2007: MAME -showconfig for a list of configuration options
17:13:26.0 3/30/2007: MAME -createconfig to create a mame.ini
17:13:26.0 3/30/2007: For usage instructions, please consult the file windows.txt
17:13:26.0 3/30/2007: --END--
17:13:26.0 3/30/2007: Loading last used Game List
17:13:26.0 3/30/2007: Setting Music Volume
17:13:26.0 3/30/2007: Cannot Load Play List. Check Path and filename
17:13:26.0 3/30/2007: Creating DirectSound Device
17:13:26.1 3/30/2007: Trying: Primary Sound Driver
17:13:26.1 3/30/2007: Loading Sound Files
17:13:26.2 3/30/2007: DirectSound Device Created Successfully
17:13:26.2 3/30/2007: Creating ICONS
17:13:26.2 3/30/2007: Restoring Cached ICONS from File
17:13:26.3 3/30/2007: Initialising DirectInput for Gamepad support
17:13:26.7 3/30/2007: Unable to create a joystick device
17:13:26.7 3/30/2007: Initialising DirectInput for Keyboard support
17:13:26.9 3/30/2007: Playing intro sound file
17:13:26.9 3/30/2007: Initializing MCE Remote
17:13:26.9 3/30/2007: Initialization OK! Starting GameEx!
17:13:27.0 3/30/2007: Testing Main Loop Once: Processing Frame
17:13:27.5 3/30/2007: Testing Main Loop Once: Main Loop ran successfully
17:13:48.8 3/30/2007: Running: cmd.exe /c C: C:\mame\mame.exe 1942 -rompath C:\mame\roms -bezel -artwork_directory artwork
17:14:23.1 3/30/2007: Running: cmd.exe /c C: C:\mame\mame.exe airattck -rompath C:\mame\roms -bezel -artwork_directory artwork
17:14:41.3 3/30/2007: Running: cmd.exe /c C: C:\mame\mame.exe apb -rompath C:\mame\roms -bezel -artwork_directory artwork
17:15:04.5 3/30/2007: Running: cmd.exe /c C: C:\mame\mame.exe battleg -rompath C:\mame\roms -bezel -artwork_directory artwork
17:15:29.5 3/30/2007: Running: cmd.exe /c C: C:\mame\mame.exe bking -rompath C:\mame\roms -bezel -artwork_directory artwork
17:15:55.8 3/30/2007: Writing Game List to disk
17:15:56.1 3/30/2007: Updating MAME Game List
17:15:56.2 3/30/2007: Running: C: C:\mame\mame.exe -listxml > C:\mame\listinfo.dat
17:16:09.1 3/30/2007: Opening Listinfo.dat
17:16:10.6 3/30/2007: Reading ListInfo.dat
17:17:01.1 3/30/2007: Reading ListInfo.dat - DONE
17:17:01.1 3/30/2007: Getting Zinc Game list (50%)
17:17:01.1 3/30/2007: Running: C: C:\Zinc\zinc.exe --list-games > C:\mame\zinclist.dat"
17:17:02.3 3/30/2007: Running: C: C:\mame\mame.exe -verifysets -rompath "C:\mame\roms" > C:\mame\verify.dat
17:21:19.6 3/30/2007: Opening Verify.dat
17:21:20.6 3/30/2007: Processing Verify.dat
17:21:20.8 3/30/2007: Processing ListInfo.dat
17:21:27.2 3/30/2007: Listinfo.dat Processing Complete
17:21:27.2 3/30/2007: Sorting MAME Game List
17:21:27.5 3/30/2007: Writing MAME Game List To File
17:21:33.0 3/30/2007: Adding History.dat info to gamelist
17:22:03.1 3/30/2007: Adding Catver.ini info to gamelist
17:22:15.3 3/30/2007: Adding Nplayers.ini info to gamelist
17:22:26.8 3/30/2007: Adding History.dat Series info to gamelist
17:29:06.6 3/30/2007: Adding MAMEInfo.dat info to gamelist
17:31:26.1 3/30/2007: Writing MAME Game List To File
17:31:37.6 3/30/2007: Updating Year List
17:31:37.6 3/30/2007: Updating Manufacturer List
17:31:37.7 3/30/2007: Updating Category List
17:31:37.7 3/30/2007: Updating Custom Folders
17:31:37.7 3/30/2007: Writing Year List To File
17:31:37.8 3/30/2007: Writing Manufacturer List To File
17:31:37.8 3/30/2007: Writing Category List To File
17:31:37.8 3/30/2007: Loading Game List
17:31:38.4 3/30/2007: Importing MAME32 Favorites
17:31:38.4 3/30/2007: Recreating ICONS
17:36:20.4 3/30/2007: Exiting GameEx!
17:36:20.4 3/30/2007: Saving Settings
17:36:22.3 3/30/2007: Disposing Plugins
17:36:22.3 3/30/2007: Checking for applications to Launch On Exit
