Money Making Opportunity to help Configure my Controls - Please
Hello all,
I cannot figure out how to configure my Player two controls for Zinc games (Using GameEx) and I am willing to pay someone to help me get them set up. I have read a lot of posts about using various Zinc front ends to configures the controls by game and then using that configuration to manage the GameEx.
I am just not Technical to do that without someone spending some time with me walking me through it step by step. I am hoping that someone on here would be willing to help me for a fair amount of compensation.
I am operating an Arcade machine with an Arcade Monitor, two player set up (joystick and six buttons each) using the Ultimarc VGA card and the J-Pac control interface.
I have been able to reprogram the J-Pac and the control configuration file with MAME 32 to match the default controls that I found for player 1 through Zinc and GameEx, however, I cannot get player two controls to work.
Again, if someone would be so kind as to help me get this working, I would be happy to compensate them fairly.
Thank you,
Thomas BeCude
[email protected]
Have you tried using Nologic's wrapper? There's a post on the forum about it here. It basically launches a custom control config for each game without having to set each one up independantly.
Read more about that here. It's pretty easy to get going, but we're here to help if you need it. :)
Hey Adultery,
Thanks for responding. I did follow the link and I don't see anything there about "wrapper"?
See, I told you I was not that technical.
Are you interested in helping me one on one, please.
Thanks,
Thomas
Okay. First things first. Download this wrapper.
Then follow these instructions:
Trying to keep this short and to the point.
This does use some of Tom's Model2 loader code in it.
This allows easy per game controller setup
This allows easy per game render setup
Please post non-bitchy feedback
Please post controller packages you happen to create (HotRod\X-Arcade\Cab\...)
To use StandAlone:
Step 01. Merge "Import.reg" from "*\Zinc\Support\" folder into your registry
(for Win2k-Vista)
Step 02. Search your MAME folder for "Tekken" open & extract "pr1data.8k" to the
root of your boot drive
Step 03. Edit & save Rom pathing in "Settings.ini" under "*\Zinc\Config\" folder
Step 04. Copy "[Arcade] Multi (ZiNc).ini" from "*\Zinc\Support\" folder to
"*\GameEx\CONFIG\EMULATORS\IMPORT-EXPORT\" folder
Step 05. Copy "[Arcade] Multi (ZiNc).ini" from "*\Zinc\Support\Advanced\" folder
to "*\GameEx\CONFIG\EMULATORS\" folder
Step 06. Launch GameEx Configuration
Step 07. Click Next until you come to a free EMU slot
Step 08. Click fee EMU slot
Step 09. Click "Import Emulator:" drop down list
Step 10. Select "[Arcade] Multi (ZiNc)" from the list then click "Import"
Step 11. Click "OK" when asked to over write dialog box
Step 12. Click "OK" on conframation dialog box
Step 13. Correct all pathing (Rom\Snap\Title\..) for your system
Step 14. Click "Next Page"
Step 15. Click "Browse" for "Map File:" Edit box entry
Step 16. Browse to "*\Zinc\Support\" and select "ZiNc.map"
Step 17. Click drop down list for "Advanced Config:" and select "[Arcade] Multi (ZiNc)"
Step 18. Click "Save"
Step 19. Click "Exit"
Step 20. Start GameEx
Step 21. Have fun :)
To use Advanced MAME Settings:
(for Win2k-Vista)
Step 04. Launch GameEx Configuration
Step 05. Click "Advanced MAME Settings"
Step 06. Click "Use Zinc:" drop down list and select "Yes"
Step 07. Click "Browse: for "Zinc Path:" and browse and select the Zinc install folder
Step 08. Enter "Zinc.exe" into "Zinc EXE:" edit box
Step 09. Clear all options in "Zinc Options:" edit box
Step 10. Click "Save"
Step 11. Click "Exit"
Step 12. Launch GameEx
Step 13. Click "MAME"
Step 14. Click "Update List"
Step 15. Click the Confirm dialog box
Step 16. Grab a beer
Step 17. Grab another beer
Step 18. Exit GameEx
Step 19. Launch GameEx Configuration
Step 20. Click "Advanced MAME Settings"
Step 21. Enter "ZiNc_Loader.exe" into "Zinc EXE:" edit box
Step 22. Click "Save"
Step 23. Click "Exit"
Step 24. Launch GameEx
Step 25. Have fun :)
Controller Plugins
WinterBlast Joystick Controller v1.6
Renamed to "Controller_JS.znc"
Zinc Keyboard Controller v?.?
Renamed to "Controller_KB.znc"
Renderer Plugins
P.E.Op.S. Soft GPU v1.76
Renamed to "Renderer_Soft.znc"
Pete's OpenGL2 GPU v2.08
Renamed to "Renderer_GL2.znc"
ZiNc D3D GPU v1.18
Renamed to "Renderer_D3D.znc"
ZiNc Glide GPU v1.4
Renamed to "Renderer_Glide.znc"
ZiNc OpenGL GPU v1.17
Renamed to "Renderer_GL.znc"
Sound Plugins
P.E.Op.S. DSound v1.9
Renamed to "sound.znc"
Changing Render's
This can be set in the Settings.ini in the "*\Zinc\Config\" folder, under the GFX
entry for the game.
Options are:
ZiNc_D3D.cfg
ZiNc_GL.cfg (Not GameEx friendly)
ZiNc_GL2.cfg (Not GameEx friendly)
ZiNc_Glide.cfg (Voodoo cards only)
ZiNc_Soft.cfg
It's a lot easier than you're making it on yourself. Just take a deep breath and give it a try.
Use the Advanced MAME settings if you want this to work with your MAME games, or use the Standalone if you want to set it up like a seperate emulator.
Hey Adultery,
I am giving it a try.....
I am not sure if I am supposed to take any action with the item below? I am trying to just do the steps for the Advanced Mame Setup so far? Is that correct?
Thanks,
Thomas
Controller Plugins
Renderer Plugins
ZiNc D3D GPU v1.18
ZiNc Glide GPU v1.4
Sound Plugins
Changing Render's
entry for the game.
Options are:
ZiNc_D3D.cfg
ZiNc_Soft.cfg
Hey again Adultery,
I went through each of the steps in the Advanced MAME setttings portion of the instructions and now when I go to load a Playstation (Zinc) game within GameEx the screen goes black and then returns to the menu?
Help.... (At least before, I could play the games with one player?)
Thanks for all of your help. I am sure it is something simple, but I have no idea.
Thomas
Using Nologic's wrapper will probably let you setup controls closer to how the real games were played, but if you just wanted to get your P2 controls working in Zinc, then you should be able to use the Setup Wizard to download it with everything you need for basic controller config. It has a FE in there (called ZincFE.exe) which you launch, then select Options->Controller Setup. I believe I may have the defaults setup already using default Mame buttons.
Thanks for the response HeadKaze.
I am trying to get it all working withing GameEx. I like the concept of having one Menu drive my MAME completely.
It is very weird whats happening now. I have been fooling around with it for a couple of hours. It seems like the ZN1 and ZN2 controls are properly configured. I can play Streetfighter on my MAME within GameEx and both the player one and player two controls are working perfectly.
When I try to play Souls Edge (Version 2), I can only seem to get the player one controls to work, Same with Xevious. I tried to copy the controller data from within the "Streetfighter.cfg" file within the Zinc Controller folder over to the Souls Edge, but that did not solve the player 2? Is there a place that holds some controller info for the Game grouping? Like S11 games?
Thanks,
Thomas
If you run ZincFE then select Options->Setup there is a setting there called "Use Settings per Game". This will allow you to go through each game and configure it manually. I must admit, it's pretty damn confusing though!
Actually, I have tried to Map out the correct Keys using ZincFE, but it does not seem to be working for me.
I am able to go to the Options - Controls and re-map the keys. I then tell it to save (or whatever) it says. I then Load GameEx and it is like I did nothing?
Do you have a set up with a computer set up as a MAME machine in an arcade cabinet with Joystick and button support for two players?
Thanks,
Thomas
  • 1 month later...
Ok, so any ideas on this? I can get all the games that have controller files in the folders configured. But Bloody Roar doesn't show up with a file in any of the folders. Is there a way to add it so It can be configured? It is detected in Game EX, but wont run.
