Text/Language -Custom- causes GamEx to freeze when starting
Just bought GamEx and I love it. I just have one issue thats driving me nuts. I'm trying to change the name of some of the menu options ie: Changing Mame to Arcade etc. However for some reason when I do this and change the language to custom as documented, whenever I start up the program I hear the opening melody but I just get a black screen. To exit it I need to CTRL-ALT-DEL to the taskmanager and end task on it. Here is my log if it helps:
19:14:29.1 3/26/2007: GameEx: Version 7.97: Starting Log
19:14:29.1 3/26/2007: Operating System Platform: Win32NT
19:14:29.1 3/26/2007: Operating System Name: Windows XP
19:14:29.1 3/26/2007: Operating System Version: 5.1.2600
19:14:29.1 3/26/2007: Checking for versions of .net Framework installed
19:14:29.1 3/26/2007: .net Framework 1.1 Installed
19:14:29.1 3/26/2007: .net Framework 2.0 Installed
19:14:29.1 3/26/2007: Intel® Pentium® 4 CPU 3.00GHz
19:14:29.1 3/26/2007: 3Ghz - 2 Cores or CPU's
19:14:29.1 3/26/2007: Running Randomize()
19:14:29.1 3/26/2007: Loading PlugIns
19:14:29.2 3/26/2007: Checking for applications to Launch On Startup
19:14:29.2 3/26/2007: Initialising Video/MNG DLL's
19:14:29.2 3/26/2007: Running Misc startup tasks
19:14:29.2 3/26/2007: Setting Menu types
19:14:29.2 3/26/2007: Opening Configuration File
19:14:29.2 3/26/2007: Getting Configuration Values
19:14:29.2 3/26/2007: Using Theme: Default - Dark Gloss
19:14:29.2 3/26/2007: Checking for alternate Image Directory for Theme: Default - Dark Gloss
19:14:29.2 3/26/2007: Launching HideOS.exe
19:14:29.2 3/26/2007: Hiding Taskbar
19:14:29.2 3/26/2007: Using Cabinet Friendly Control System
19:14:29.2 3/26/2007: Is Media Center running?
19:14:29.2 3/26/2007: Checking/Creating LCD Registry values
19:14:29.2 3/26/2007: Check Media Center Exit/Start Mode
19:14:29.2 3/26/2007: Media Center Mode 2
19:14:29.2 3/26/2007: Video previews on. Warning: Only recommended on modern systems
19:14:29.2 3/26/2007: Snap Delay set to: 6
19:14:29.2 3/26/2007: Get other settings
19:14:29.2 3/26/2007: Set: Find emulator artwork on best match basis
19:14:29.2 3/26/2007: SlikStik support enabled
19:14:29.2 3/26/2007: Using DirectInput for keyboard input
19:14:29.3 3/26/2007: Start work for Form
19:14:29.3 3/26/2007: Getting Original Screen Size
19:14:29.3 3/26/2007: Initializing Component
19:14:29.5 3/26/2007: MAME Path is: E:\Emulators\Arcade\Mame32b
19:14:29.5 3/26/2007: MAME EXE file is: Mame32.exe
19:14:29.5 3/26/2007: ROM Path is: E:\Emulators\Arcade
19:14:29.5 3/26/2007: Catver.ini is located at: E:\GameEx\DATA\catver.ini
19:14:29.5 3/26/2007: controls.ini is located at: E:\GameEx\data\controls.ini
19:14:29.5 3/26/2007: History.dat is located at: E:\GameEx\DATA\history.dat
19:14:29.5 3/26/2007: nplayers.ini is located at: E:\GameEx\DATA\nplayers.ini
19:14:29.5 3/26/2007: MAMEinfo.dat is located at: E:\GameEx\DATA\mameinfo.dat
19:14:29.5 3/26/2007: Loading Controls.ini map file
19:14:29.6 3/26/2007: Snap Path is: E:\Emulators\Arcade\Mame32b\snap
19:14:29.6 3/26/2007: AVI Snap Path is: e:\Emulators\arcade\Mame32b\ingame
19:14:29.6 3/26/2007: Flyer Path is: E:\Emulators\Arcade\Mame32b\flyers
19:14:29.6 3/26/2007: Cabinet Path is: E:\Emulators\Arcade\Mame32b\cabinets
19:14:29.6 3/26/2007: Title Path is: E:\Emulators\Arcade\Mame32b\titles
19:14:29.6 3/26/2007: Panel Path is: E:\Emulators\Arcade\Mame32b\cpanel
19:14:29.6 3/26/2007: Manual Path: Not Found
19:14:29.6 3/26/2007: Icon Path is: E:\Emulators\Arcade\Mame32b\icons
19:14:29.6 3/26/2007: Marquee Path is: E:\Emulators\Arcade\Mame32b\marquees
19:14:29.6 3/26/2007: Loading Custom Emulators
19:14:29.6 3/26/2007: Loading Emulator 1: Colecovision
19:14:29.7 3/26/2007: Loading Emulator 2: Nintendo 64
19:14:29.7 3/26/2007: Loading Emulator 3: Nintendo Entertainment System
19:14:29.8 3/26/2007: Loading Emulator 4: PC Games
19:14:29.9 3/26/2007: Loading Emulator 5: Sega Genesis
19:14:29.9 3/26/2007: Loading Emulator 6: Sony Playstation
19:14:30.0 3/26/2007: Loading Emulator 7: Super Nintendo Entertainment System
19:14:30.2 3/26/2007: Using 2D Animations
19:14:30.2 3/26/2007: Using General Font: Trebuchet MS
19:14:30.2 3/26/2007: Using Title Font: Trebuchet MS
19:14:30.2 3/26/2007: Initialising DirectDraw
19:14:30.3 3/26/2007: Applying GameEx is Loading Image
19:14:30.3 3/26/2007: Creating DirectDraw Device
19:14:30.3 3/26/2007: Using Device: NVIDIA GeForce 6800 GT
19:14:30.3 3/26/2007: 248mb video memory available
19:14:30.3 3/26/2007: Setting Resolution to 1168x640 32 bit color
19:14:30.3 3/26/2007: Creating DirectDraw Surfaces
19:14:30.3 3/26/2007: Creating Primary Surface - Full Screen Mode
19:14:30.4 3/26/2007: Creating Back Buffer
19:14:30.4 3/26/2007: Loading graphic Surfaces
19:14:30.5 3/26/2007: Creating Surfaces Misc and Dialogs
19:14:30.6 3/26/2007: Creating Surfaces Volume
19:14:30.6 3/26/2007: Creating Surfaces Arrows
19:14:30.6 3/26/2007: Creating Surfaces GameEXlogo Text
19:14:30.6 3/26/2007: Creating Surfaces Toolbar
19:14:30.6 3/26/2007: Creating Surfaces Backgrounds
19:14:30.9 3/26/2007: Creating Surfaces Toolbar Controls
19:14:30.9 3/26/2007: Creating Surfaces GameEx Logo
19:14:30.9 3/26/2007: Creating Surfaces Home & Exit
19:14:30.9 3/26/2007: Creating Surfaces Snaps
19:14:30.9 3/26/2007: Creating Surfaces Menu and List Bars
19:14:31.0 3/26/2007: Creating Fonts
19:14:31.0 3/26/2007: Creating Menu Font
19:14:31.0 3/26/2007: Restoring Menu Font From Cache
19:14:31.1 3/26/2007: Creating Game Font
19:14:31.2 3/26/2007: Creating Font Black
19:14:31.3 3/26/2007: Creating Font Black Small
19:14:31.4 3/26/2007: Creating Game Font Faded
19:14:31.5 3/26/2007: Creating Title Font
19:14:31.5 3/26/2007: Restoring Title Font From Cache
19:14:31.7 3/26/2007: Fonts Created Succesfully
19:14:31.7 3/26/2007: 217mb video memory left available
19:14:31.7 3/26/2007: Starting GameExtender Publisher
19:14:31.7 3/26/2007: Text/Language: Custom
19:14:31.7 3/26/2007: Applying Language/Text
19:14:31.8 3/26/2007: Initialising Bass Audio Library
19:14:31.9 3/26/2007: MAME CMD options: -triplebuffer -nowindow -joy
19:14:31.9 3/26/2007: Attempting to load game list
19:14:32.0 3/26/2007: Loading last used Game List
19:14:32.0 3/26/2007: Loading Start Page
19:14:32.1 3/26/2007: Setting Music Volume
19:14:32.1 3/26/2007: Cannot Load Play List. Check Path and filename
19:14:32.2 3/26/2007: Creating DirectSound Device
19:14:32.2 3/26/2007: Trying: Primary Sound Driver
19:14:32.2 3/26/2007: Loading Sound Files
19:14:32.2 3/26/2007: DirectSound Device Created Successfully
19:14:32.2 3/26/2007: Creating ICONS
19:14:32.2 3/26/2007: Recreating ICONS
19:14:32.5 3/26/2007: Initialising DirectInput for Gamepad support
19:14:32.5 3/26/2007: Using Device Logitech Dual Action USB
19:14:32.5 3/26/2007: Using Device Logitech Cordless RumblePad 2 USB
19:14:32.5 3/26/2007: Initialising DirectInput for Keyboard support
19:14:32.6 3/26/2007: Playing intro sound file
19:14:32.6 3/26/2007: Initializing MCE Remote
19:14:32.6 3/26/2007: Initialization OK! Starting GameEx!
19:14:32.6 3/26/2007: Testing Main Loop Once: Processing Frame
19:14:33.2 3/26/2007: Testing Main Loop Once: Main Loop ran successfully
When I revert the language back to English and with the default menu options it works again without trouble. What could be causing this? Currently I'm using Windows XP with the latest service packs/updates. Geforce 6800GT, P4 3ghz, 1gb ram, Creative X-fi sound card. Any help would be greatly appreciate.
It works fine for me. Its likely because you have a blank entry somewhere.
If you still cant figure it out post your gameex.ini and Ill take a further look.
It's fixed now, thanks!!
