Hello!
I have made a motorized mekanism which turn the monitor in horizontal or vertical mode. I if a plugin for gameex can give me a signal on for example the parallell port depending on what game i choose is in wertical or horizontal mode.
Thankful for any help in this!
/Micke
That would be really cool! Or a plugin that triggers the rotation mechanism when you press the "tab" (GameEx default key for frontend screen rotation).
Emph
Yes good idea
I also have a USB board with a motor attached to it,.
It would be cool f i could send a signal or run a command to signal my own program on TAB.
Are there implementations in the plugin system to do this ?
Yes, please someone. That would be great!!
I just need a signal on the lpt port when the monitor should move to vertical position.
